Не выполняется RUN oracle duplicate между базами с разными именами
run { allocate channel pri1 type disk; allocate channel pri2 type disk; allocate channel prmy4 type disk; allocate auxiliary channel stby type disk; duplicate target database for standby from active database db_file_name_convert="C:\ORACLE\ORADATA\TEST\","D:\oradata\bTEST\BTEST\","C:\ORACLE\PRODUCT\11.2.0\DBHOME_1\DATABASE\","D:\oradata\bTEST\BTEST\" dorecover spfile parameter_value_convert 'TEST','BTEST set db_unique_name='BTEST' set db_file_name_convert="C:\ORACLE\ORADATA\TEST\","D:\oradata\bTEST\BTEST\","C:\ORACLE\PRODUCT\11.2.0\DBHOME_1\DATABASE\","D:\oradata\bTEST\BTEST\" set log_file_name_convert="C:\oracle\flash_recovery_area\","c:\oracle\flash_recovery_area\" set control_files="C:\ORACLE\ORADATA\TEST\CONTROL01.CTL", "C:\ORACLE\FLASH_RECOVERY_AREA\TEST\CONTROL02.CTL" set log_archive_max_processes="30" set fal_client="BTEST" set fal_server="TEST" set standby_file_management="AUTO" set log_archive_config="dg_config=(TEST,BTEST)" nofilenamecheck; } При вставке команды в RMAN Ошибка 24> } 25> 26> RMAN-00571: =========================================================== RMAN-00569: =============== ERROR MESSAGE STACK FOLLOWS =============== RMAN-00571: =========================================================== RMAN-00558: error encountered while parsing input commands RMAN-01006: error signaled during parse RMAN-02002: unexpected end of input file reached ... |
| 28.03.2018, 18:20:48 |
ChertRUS, rman checksyntax попробуйте ... |
| 28.03.2018, 23:34:06 |
Rman checksyntax говорит что все нормально ... ... |
| 29.03.2018, 10:49:31 |
ChertRUSparameter_value_convert 'TEST','BTESTкавычка? ... |
| 29.03.2018, 10:58:17 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1884211]: |
120ms |
47ms |
| others: | 229ms |
| total: | 458ms |
