Oracle number issue
Hi, I occur some problem. In Oracle column type defined as 'Number' and I can save 0.987 into it. But when I use dbeaver to do this, it save as 0. Does there any body occurs such situation? Or is there any miss setting in my dbeaver or DB? Any help will be apprecited. I didn't find the right solution from the Internet. References: https://dbeaver.jkiss.org/forum/viewtopic.php?f=2&t=644 Animated Explainer Video Company Thank you. ... |
| 07.05.2018, 16:35:47 |
Oracle number issue
Can you show us your testcase? ... |
| 07.05.2018, 18:22:11 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1884022]: |
212ms |
31ms |
| others: | 192ms |
| total: | 473ms |
