Упала БД. помогите починить!
Оракл шел в составе софта. ничего в нем руками не настраивал. система отработала более 5 лет! и вот дала сбой! ОС windows xp. Прошу помощи в восстановлении работоспособности! вот лог: Sat Mar 05 09:11:45 2016 ORACLE V9.2.0.4.0 - Production vsnsta=0 vsnsql=12 vsnxtr=3 Windows 2000 Version 5.1 Service Pack 3, CPU type 586 Sat Mar 05 09:11:45 2016 Starting ORACLE instance (normal) LICENSE_MAX_SESSION = 0 LICENSE_SESSIONS_WARNING = 0 SCN scheme 2 Using log_archive_dest parameter default value LICENSE_MAX_USERS = 0 SYS auditing is disabled Starting up ORACLE RDBMS Version: 9.2.0.4.0. System parameters with non-default values: processes = 150 timed_statistics = TRUE shared_pool_size = 67108864 large_pool_size = 8388608 java_pool_size = 0 control_files = C:\Oracle\ORCL\control01.ctl, C:\Oracle\ORCL\control02.ctl, C:\Oracle\ORCL\control03.ctl db_block_size = 8192 db_cache_size = 192937984 compatible = 9.2.0.0.0 db_file_multiblock_read_count= 16 fast_start_mttr_target = 300 undo_management = AUTO undo_tablespace = UNDOTBS undo_retention = 0 O7_DICTIONARY_ACCESSIBILITY= TRUE remote_login_passwordfile= EXCLUSIVE db_domain = instance_name = ORCL job_queue_processes = 10 hash_join_enabled = TRUE background_dump_dest = C:\Oracle\admin\ORCL\bdump user_dump_dest = C:\Oracle\admin\ORCL\udump core_dump_dest = C:\Oracle\admin\ORCL\cdump sort_area_size = 524288 db_name = ORCL open_cursors = 300 star_transformation_enabled= FALSE query_rewrite_enabled = FALSE pga_aggregate_target = 82837504 aq_tm_processes = 1 PMON started with pid=2 DBW0 started with pid=3 LGWR started with pid=4 CKPT started with pid=5 SMON started with pid=6 RECO started with pid=7 CJQ0 started with pid=8 QMN0 started with pid=9 Sat Mar 05 09:11:53 2016 alter database mount exclusive Sat Mar 05 09:11:59 2016 Successful mount of redo thread 1, with mount id 1433476057. Sat Mar 05 09:11:59 2016 Database mounted in Exclusive Mode. Completed: alter database mount exclusive Sat Mar 05 09:11:59 2016 alter database open Sat Mar 05 09:12:00 2016 Beginning crash recovery of 1 threads Sat Mar 05 09:12:00 2016 Started first pass scan Sat Mar 05 09:12:01 2016 Completed first pass scan 3259 redo blocks read, 106 data blocks need recovery Sat Mar 05 09:12:01 2016 Started recovery at Thread 1: logseq 1335, block 155163, scn 0.0 Recovery of Online Redo Log: Thread 1 Group 3 Seq 1335 Reading mem 0 Mem# 0 errs 0: C:\ORACLE\ORCL\REDO03.LOG RECOVERY OF THREAD 1 STUCK AT BLOCK 9 OF FILE 6 Sat Mar 05 09:12:32 2016 Restarting dead background process QMN0 QMN0 started with pid=9 Sat Mar 05 09:18:19 2016 Restarting dead background process QMN0 QMN0 started with pid=11 Sat Mar 05 09:23:50 2016 Restarting dead background process QMN0 QMN0 started with pid=9 Sat Mar 05 09:29:31 2016 Restarting dead background process QMN0 QMN0 started with pid=11 Sat Mar 05 09:34:40 2016 Restarting dead background process QMN0 QMN0 started with pid=11 Sat Mar 05 09:39:44 2016 Restarting dead background process QMN0 QMN0 started with pid=11 Sat Mar 05 09:45:34 2016 Restarting dead background process QMN0 QMN0 started with pid=9 Sat Mar 05 09:50:59 2016 Errors in file c:\oracle\admin\orcl\udump\orcl_ora_2224.trc: ORA-00333: ?????? ?????? ?????????, ???? 59394 ??????? 6144 ORA-00334: ?????????????? ????????: 'C:\ORACLE\ORCL\REDO03.LOG' ORA-27070: skgfdisp: ???? ???????????? ?/? OSD-04016: Ошибка организации очереди запросов асинхронного вв./выв. O/S-Error: (OS 23) Ошибка в данных (CRC). Sat Mar 05 09:51:02 2016 Errors in file c:\oracle\admin\orcl\udump\orcl_ora_2224.trc: ORA-00333: ?????? ?????? ?????????, ???? 57346 ??????? 8192 ORA-00334: ?????????????? ????????: 'C:\ORACLE\ORCL\REDO03.LOG' ORA-27091: skgfqio: ?????????? ??????????????? ????/????? ORA-27070: skgfdisp: ???? ???????????? ?/? OSD-04006: сбой ReadFile(), чтение из файла невозможно O/S-Error: (OS 23) Ошибка в данных (CRC). Sat Mar 05 09:51:04 2016 Errors in file c:\oracle\admin\orcl\udump\orcl_ora_2224.trc: ORA-00333: ?????? ?????? ?????????, ???? 57346 ??????? 8192 ORA-00334: ?????????????? ????????: 'C:\ORACLE\ORCL\REDO03.LOG' ORA-27091: skgfqio: ?????????? ??????????????? ????/????? ORA-27070: skgfdisp: ???? ???????????? ?/? OSD-04006: сбой ReadFile(), чтение из файла невозможно O/S-Error: (OS 23) Ошибка в данных (CRC). Sat Mar 05 09:51:06 2016 Errors in file c:\oracle\admin\orcl\udump\orcl_ora_2224.trc: ORA-00333: ?????? ?????? ?????????, ???? 57346 ??????? 8192 ORA-00334: ?????????????? ????????: 'C:\ORACLE\ORCL\REDO03.LOG' ORA-27091: skgfqio: ?????????? ??????????????? ????/????? ORA-27070: skgfdisp: ???? ???????????? ?/? OSD-04006: сбой ReadFile(), чтение из файла невозможно O/S-Error: (OS 23) Ошибка в данных (CRC). Sat Mar 05 09:51:06 2016 Errors in file c:\oracle\admin\orcl\udump\orcl_ora_2224.trc: ORA-00333: ?????? ?????? ?????????, ???? 57346 ??????? 8192 Sat Mar 05 09:51:07 2016 ORA-1172 signalled during: alter database open... Sat Mar 05 09:51:28 2016 Restarting dead background process QMN0 QMN0 started with pid=9 Sat Mar 05 09:57:07 2016 Restarting dead background process QMN0 QMN0 started with pid=9 Sat Mar 05 10:03:02 2016 Restarting dead background process QMN0 QMN0 started with pid=9 Sat Mar 05 10:08:52 2016 Restarting dead background process QMN0 QMN0 started with pid=9 Sat Mar 05 10:14:41 2016 Restarting dead background process QMN0 QMN0 started with pid=9 Sat Mar 05 10:20:28 2016 Restarting dead background process QMN0 QMN0 started with pid=9 Sat Mar 05 10:25:34 2016 Restarting dead background process QMN0 QMN0 started with pid=9 Sat Mar 05 10:31:28 2016 Restarting dead background process QMN0 QMN0 started with pid=9 Sat Mar 05 10:37:18 2016 Restarting dead background process QMN0 QMN0 started with pid=9 Sat Mar 05 10:43:08 2016 Restarting dead background process QMN0 QMN0 started with pid=9 Sat Mar 05 10:48:46 2016 Restarting dead background process QMN0 QMN0 started with pid=9 ... |
| 05.03.2016, 11:03:21 |
djeday84, Если можно распишите чуть более подробно что нужно сделать! я не администратор БД. Блок-схема хоть и понятна, но как и что делается ((( ... |
| 05.03.2016, 11:27:05 |
Последний выхлоп умирающего oracle Код: plsql 1. 2. 3. 4. 5. 6. У Вас посыпался диск (5 лет солидный срок) Битый файл: C:\ORACLE\ORCL\REDO03.LOG Ну что сказать, всё плохо, файл важный 1) Останавливаете службу windows OracleServiceORCL 2) Делаете backup c:\oracle в надежное место Скорее всего у Вас не получится скопировать файл C:\ORACLE\ORCL\REDO03.LOG 3) Запускаете восстановление диска на уровне ОС 4) Пытаетесь еще раз скопировать битый файл (в котором скорее всего будет мусор) Далее Вам лучше нанять специалиста, или разбираться самому Но самое главное сначала сохранить что еще осталось. Вариант что получится поднять и сохранить данные есть, но есть вероятность что остался только мусор - нужно разбираться ... |
| 05.03.2016, 11:54:09 |
Сначала стоит попробовать остановить (чисто) экземпляр C:\> sqlplus "/ as sysdba" SQL> shutdown immediate Если получилось -- иммитировать неполное восстановление и открыть со сбросом оперативных журналов (они как раз и пересоздадутся) SQL> startup mount SQL> recover database using backup controlfile until cancel ... cancel SQL> alter database open resetlogs; ... |
| 05.03.2016, 12:25:15 |
Вячеслав Любомудров, Вячеслав, ТС - э-э-э администратор весьма начального уровня. База уже падает при старте. Ну и сбой на уровне ОС никто не отменял... пока не починит ничего не взлетит. ... |
| 05.03.2016, 12:34:27 |
Не увидел, что она падает ... |
| 05.03.2016, 12:52:28 |
Хотя, да, увидел Но, в NOARCHIVELOG выбор у него, собственно говоря, небольшой А сбойный блок -- да и хрен с ним, если весь остальной диск работает ... |
| 05.03.2016, 12:56:21 |
Вячеслав ЛюбомудровХотя, да, увидел Но, в NOARCHIVELOG выбор у него, собственно говоря, небольшой А сбойный блок -- да и хрен с ним, если весь остальной диск работает При попытке обратиться к этому файлу, база упадет еще раз нужен chkdsk чтобы хотя бы ошибка ОС не выпадала ... |
| 05.03.2016, 16:24:33 |
Вячеслав Любомудров, помогите пожалуйста http://www.sql.ru/forum/1301960-a/vosstanovlenie-bd-oracl ... |
| 04.09.2018, 03:57:41 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1883512]: |
23ms |
29ms |
| others: | 228ms |
| total: | 314ms |
