База не открывается и не работает
123йй, SYSTEM as SYSDBA alter database open * ошибка в строке 1: ORA-01034: ORACLE not available По третьему пункту и контрольному можно подробнее?) ... |
| 03.10.2018, 13:53:30 |
Роман7214ORA-01034: ORACLE not available startup ? ... |
| 03.10.2018, 13:59:50 |
123йй, почему не sqlplus / as sysdba ? ... |
| 03.10.2018, 14:01:59 |
123йй, Прописываю в SQL*Plus Worksheet Соединено При попытке открыть базу сразу уходит в Shutdown и все ... |
| 03.10.2018, 14:05:46 |
123йй, Wed Oct 03 13:53:49 2018 Starting ORACLE instance (normal) LICENSE_MAX_SESSION = 0 LICENSE_SESSIONS_WARNING = 0 SCN scheme 2 Using log_archive_dest parameter default value LICENSE_MAX_USERS = 0 SYS auditing is disabled Starting up ORACLE RDBMS Version: 9.2.0.6.0. System parameters with non-default values: processes = 150 timed_statistics = TRUE shared_pool_size = 192937984 large_pool_size = 142606336 java_pool_size = 33554432 control_files = C:\oracle\oradata\GAS\control01.ctl, C:\oracle\oradata\GAS\control02.ctl, C:\oracle\oradata\GAS\control03.ctl db_block_size = 8192 db_cache_size = 578813952 compatible = 9.2.0.0.0 db_file_multiblock_read_count= 16 fast_start_mttr_target = 300 undo_management = AUTO undo_tablespace = UNDOTBS1 undo_retention = 10800 remote_login_passwordfile= EXCLUSIVE db_domain = instance_name = GAS dispatchers = (PROTOCOL=TCP) (SERVICE=GASXDB) job_queue_processes = 10 hash_join_enabled = TRUE background_dump_dest = C:\oracle\admin\GAS\bdump user_dump_dest = C:\oracle\admin\GAS\udump core_dump_dest = C:\oracle\admin\GAS\cdump sort_area_size = 524288 db_name = GAS open_cursors = 300 star_transformation_enabled= FALSE query_rewrite_enabled = FALSE pga_aggregate_target = 513802240 aq_tm_processes = 1 PMON started with pid=2 DBW0 started with pid=3 LGWR started with pid=4 CKPT started with pid=5 SMON started with pid=6 RECO started with pid=7 CJQ0 started with pid=8 QMN0 started with pid=9 Wed Oct 03 13:53:52 2018 starting up 1 shared server(s) ... starting up 1 dispatcher(s) for network address '(ADDRESS=(PARTIAL=YES)(PROTOCOL=TCP))'... Wed Oct 03 13:53:53 2018 /* OracleOEM */ ALTER DATABASE MOUNT Wed Oct 03 13:53:57 2018 Successful mount of redo thread 1, with mount id 1491708337 Wed Oct 03 13:53:57 2018 Database mounted in Exclusive Mode. ORA-1991 signalled during: /* OracleOEM */ ALTER DATABASE MOUNT... Wed Oct 03 13:59:53 2018 Restarting dead background process QMN0 QMN0 started with pid=9 Wed Oct 03 14:04:10 2018 /* OracleOEM */ ALTER DATABASE OPEN Wed Oct 03 14:04:11 2018 Beginning crash recovery of 1 threads Wed Oct 03 14:04:11 2018 Started redo scan Wed Oct 03 14:04:11 2018 Completed redo scan 388 redo blocks read, 130 data blocks need recovery Wed Oct 03 14:04:11 2018 Started recovery at Thread 1: logseq 3251, block 3, scn 0.0 Wed Oct 03 14:04:12 2018 Recovery of Online Redo Log: Thread 1 Group 1 Seq 3251 Reading mem 0 Mem# 0 errs 0: C:\ORACLE\ORADATA\GAS\REDO01.LOG Wed Oct 03 14:04:12 2018 Completed redo application Wed Oct 03 14:04:13 2018 Ended recovery at Thread 1: logseq 3251, block 391, scn 0.544335645 130 data blocks read, 130 data blocks written, 388 redo blocks read Crash recovery completed successfully Wed Oct 03 14:04:14 2018 Thread 1 advanced to log sequence 3252 Thread 1 opened at log sequence 3252 Current log# 2 seq# 3252 mem# 0: C:\ORACLE\ORADATA\GAS\REDO02.LOG Successful open of redo thread 1 Wed Oct 03 14:04:14 2018 SMON: enabling cache recovery Wed Oct 03 14:04:15 2018 Successfully onlined Undo Tablespace 1. Wed Oct 03 14:04:15 2018 SMON: enabling tx recovery Wed Oct 03 14:04:15 2018 Database Characterset is CL8MSWIN1251 Wed Oct 03 14:04:15 2018 SMON: Restarting fast_start parallel rollback SMON: ignoring slave err,downgrading to serial rollback ORACLE Instance gas (pid = 6) - Error 1578 encountered while recovering transaction (9, 16) on object 33423. Wed Oct 03 14:04:15 2018 Errors in file c:\oracle\admin\gas\bdump\gas_smon_5044.trc: ORA-01578: ORACLE data block corrupted (file # 1, block # 2115854) ORA-01110: data file 1: 'C:\ORACLE\ORADATA\GAS\SYSTEM01.DBF' Wed Oct 03 14:04:16 2018 Errors in file c:\oracle\admin\gas\bdump\gas_smon_5044.trc: ORA-00600: internal error code, arguments: [17182], [0x425834C], [], [], [], [], [], [] ORA-01578: ORACLE data block corrupted (file # 1, block # 2115854) ORA-01110: data file 1: 'C:\ORACLE\ORADATA\GAS\SYSTEM01.DBF' Wed Oct 03 14:04:16 2018 replication_dependency_tracking turned off (no async multimaster replication found) Wed Oct 03 14:04:20 2018 Errors in file c:\oracle\admin\gas\bdump\gas_pmon_5268.trc: ORA-00474: SMON process terminated with error Wed Oct 03 14:04:20 2018 PMON: terminating instance due to error 474 Instance terminated by PMON, pid = 5268 И снова все вот так ... |
| 03.10.2018, 14:06:58 |
Мне просто интересно возможно ли каким либо образом вытащить только то, что нужно? Есть вот в списке, который я приложил таблица, которая нужна (видимо, и какая-то часть из других системных файлов). Остальное можно потерять. ... |
| 03.10.2018, 15:23:04 |
Роман7214Мне просто интересно возможно ли каким либо образом вытащить только то, что нужно? Есть вот в списке, который я приложил таблица, которая нужна (видимо, и какая-то часть из других системных файлов). Остальное можно потерять. Без открытия базы ты ничего не вытащишь , без valid system ты ничего не откроешь . Посмотри что за сегмент умер . ... |
| 03.10.2018, 15:26:12 |
Роман7214, короткая память 21682144 ? ... |
| 03.10.2018, 15:26:13 |
123йй, Нет, не короткая, это вопрос в дополнение. С Вашими ответами я полезной информации не получил то ли из-за непонимания (взаимного), то ли из-за моей непрофессиональности. ... |
| 03.10.2018, 15:30:41 |
| 03.10.2018, 15:41:03 |
maverick2104, Я честно говоря думал, что форумы созданы для помощи) Ну такое себе, конечно. В каждой теме нет практически ни одного дельного совета, только "тыканье котенка". В общем-то снова все понятно, спасибо, что хотя бы не послали. На форумах по Firebird поговорим) Если можно, закройте тему. ... |
| 03.10.2018, 15:45:41 |
Роман7214maverick2104, Я честно говоря думал, что форумы созданы для помощи) Ну такое себе, конечно. В каждой теме нет практически ни одного дельного совета, только "тыканье котенка". В общем-то снова все понятно, спасибо, что хотя бы не послали. На форумах по Firebird поговорим) Если можно, закройте тему. Вот краткий ответ на твой вопрос. Если нет бэкапа и умер системный тп , да еще в noarchivelog , базу практически не восстановить . ... |
| 03.10.2018, 15:51:04 |
Роман7214, сделать копию БД в init.ora добавить строку event = "10231 trace name context forever, level 10". перезапустить БД ... |
| 03.10.2018, 15:57:20 |
несешь чушь Нужно просто запретить черезчур активничать SMON-у (даже какой-то ивент подсказали), вычислить битый объект (очень похож таки на SYSTEM-rollback сегмент) и понять как его починить Даже в ТП SYSTEM есть совершенно поддающиеся лечению сегменты ... |
| 03.10.2018, 15:58:17 |
maverick2104Если нет бэкапа и умер системный тп , да еще в noarchivelog , базу практически не восстановить . Базу - сложно. Данные из одной таблицы вытянуть - шансы есть. Зависит от ценности данных и разумного выбора между стратегиями "стать профессионалом"/"нанять профессионала"/"смириться с потерей". ... |
| 03.10.2018, 16:00:05 |
Вячеслав Любомудровнесешь чушь Нужно просто запретить черезчур активничать SMON-у (даже какой-то ивент подсказали), вычислить битый объект (очень похож таки на SYSTEM-rollback сегмент) и понять как его починить Даже в ТП SYSTEM есть совершенно поддающиеся лечению сегментыДа, это ролбек и блок нужен для отката транзакции. Как "лечение" поможет? ... |
| 03.10.2018, 23:39:22 |
Relic HunterДа, это ролбек и блок нужен для отката транзакции. Как "лечение" поможет?Телепат? Сначала таки нужно убедиться Ставим event 10513 level 2 (приостанавливает SMON recovery) Затем смотрим, что это за сегмент (file # 1, block # 2115854) Объект 33423 -- тоже смотрим что это, на системный мало похоже, возможно, его можно грохнуть PS. Естественно, как неоднократно говорилось, сначала копию того, что осталось PPS. Еще желательно избавиться от "ORA-1991 signalled during: /* OracleOEM */ ALTER DATABASE MOUNT" ... |
| 04.10.2018, 02:42:49 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1883377]: |
45ms |
58ms |
| others: | 219ms |
| total: | 377ms |
