XE не могу подключиться в SQL Developer
В SQL Developer не могу подключиться ни к одной схеме. Результат всегда Status : Failure -Test failed: ORA-00604: error occurred at recursive SQL level 1 ORA-12705: Cannot access NLS data files or invalid environment specified Screenshot В sqlplus подключается нормально. Screenshot Результат lsnrctl status: авторLSNRCTL for 64-bit Windows: Version 11.2.0.2.0 - Production on 2CT-2018 16:52:08 Copyright (c) 1991, 2014, Oracle. All rights reserved. Connecting to (DESCRIPTION=(ADDRESS=(PROTOCOL=IPC)(KEY=EXTPROC1))) STATUS of the LISTENER ------------------------ Alias LISTENER Version TNSLSNR for 64-bit Windows: Version 11.2.0.2.0 - Production Start Date 2CT-2018 16:45:19 Uptime 0 days 0 hr. 6 min. 49 sec Trace Level off Security ON: Local OS Authentication SNMP OFF Default Service XE Listener Parameter File C:\oraclexe\app\oracle\product\11.2.0\server\network\admin\listener.ora Listener Log File C:\oraclexe\app\oracle\diag\tnslsnr\DESKTOP-5FME5IB\listener\alert\log.xml Listening Endpoints Summary... (DESCRIPTION=(ADDRESS=(PROTOCOL=ipc)(PIPENAME=\\.\pipe\EXTPROC1ipc))) (DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=DESKTOP-5FME5IB)(PORT=1521))) (DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=DESKTOP-5FME5IB)(PORT=8080))(Presentation=HTTP)(Session=RAW)) Services Summary... Service "CLRExtProc" has 1 instance(s). Instance "CLRExtProc", status UNKNOWN, has 1 handler(s) for this service... Service "PLSExtProc" has 1 instance(s). Instance "PLSExtProc", status UNKNOWN, has 1 handler(s) for this service... Service "XEXDB" has 1 instance(s). Instance "xe", status READY, has 1 handler(s) for this service... Service "xe" has 1 instance(s). Instance "xe", status READY, has 1 handler(s) for this service... The command completed successfully В sqldeveloper.conf добавил строки: авторAddVMOption -Duser.language=en AddVMOption -Duser.region=us В реестре: авторNLS_LANG=AMERICAN_AMERICA.CL8MSWIN1251 Уже вроде много всего перепробовал, а воз и ныне там. Подскажите что делать, а то время уходит, а я даже приступить не могу( ... |
| 28.10.2018, 17:11:27 |
Можно и в реестре ошибиться, и в PATH, и в TNSNAMES. Не видно, с какими параметрами подключается sqlplus. Протестируйте через EZCONNECT. Код: powershell 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. ... |
| 28.10.2018, 17:41:32 |
dmdmdm, вроде со стандартными параметрами подключается авторsqlplus Roman/19891989@localhost:1521/xe SQL*Plus: Release 11.2.0.2.0 Production on ╨Т╤Б ╨Ю╨║╤В 28 19:13:15 2018 Copyright (c) 1982, 2014, Oracle. All rights reserved. Connected to: Oracle Database 11g Express Edition Release 11.2.0.2.0 - 64bit Production ... |
| 28.10.2018, 19:13:45 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1883276]: |
35ms |
34ms |
| others: | 223ms |
| total: | 339ms |
