Ошибка обновления Patch 29124511 - Windows Database Bundle Patch 18.5.0.0.190115
В процессе обновления наткнулся на ошибку ORA-29548: Java system class reported: release of Java system classes in database (18.1.0.0.0 1.8) does not match that of the oracle executable (18.3.0.0.0 1.8) ORA-06512: at line 10 ORA-06512: at "SYS.DBMS_JAVA", line 705 ORA-06512: at line 2 ORA-06512: at line 4 Подозреваю что нужен патч еще на Java . Просьба сбросить ссылку на патч. ... |
| 07.02.2019, 14:02:27 |
Critical Patch Update (CPU) Program January 2019 Patch Availability Document (PAD) (Doc ID 2466391.1) Master Note for Database Proactive Patch Program (Doc ID 756671.1) Assistant: Download Reference for Oracle Database/GI Update, Revision, PSU, SPU(CPU), Bundle Patches, Patchsets and Base Releases (Doc ID 2118136.2) ... |
| 07.02.2019, 15:22:29 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1882821]: |
26ms |
38ms |
| others: | 226ms |
| total: | 336ms |
