Java Oracle 18
на 18 оракле не компилится Java вот такого синтаксиса: Код: java 1. Как теперь нужно писать? ... |
| 09.04.2019, 17:00:39 |
Java Oracle 18
Это какбэ не джава... ... |
| 09.04.2019, 17:32:04 |
Java Oracle 18
Петров Андрей, sqlj для хранимок desupported с версии 12.2 ... |
| 09.04.2019, 17:43:13 |
Java Oracle 18
Петров Андрей, https://docs.oracle.com/database/121/UPGRD/deprecated.htm#UPGRD60075 Oracle 12.1 Deprecation of SQLJ Inside the Server8.1.17.1 Deprecation of SQLJ Inside the Server SQLJ usage inside the database server is deprecated in this release. The capability of translating and running SQLJ applications inside the database will not be available in later releases. SQLJ can only be used as a client tool to translate the applications that can connect to Oracle Database and run as a client. SQLJ cannot be used inside stored procedures, functions, or triggers. ... |
| 09.04.2019, 17:46:25 |
Java Oracle 18
Петров Андрей, используйте теперь обычный ojdbc: https://docs.oracle.com/cd/B28359_01/java.111/b31224/ssid.htm ... |
| 09.04.2019, 17:48:03 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1882598]: |
186ms |
35ms |
| others: | 224ms |
| total: | 483ms |
