СРОЧНО нужна помощь по восстановлению БД Oracle 11g. Рассчитаемся.
Starting restore at 07-MAY-19 using target database control file instead of recovery catalog allocated channel: ORA_DISK_1 channel ORA_DISK_1: SID=161 device type=DISK channel ORA_DISK_1: starting validation of datafile backup set channel ORA_DISK_1: reading from backup piece /home/oracle/backup_ssh/SVFE_FULL_HOT_egu0qi0r_1_1 channel ORA_DISK_1: piece handle=/home/oracle/backup_ssh/SVFE_FULL_HOT_egu0qi0r_1_1 tag=FULL_HOT channel ORA_DISK_1: restored backup piece 1 channel ORA_DISK_1: reading from backup piece /home/oracle/backup_ssh/SVFE_FULL_HOT_egu0qi0r_2_1 ^[[Cchannel ORA_DISK_1: piece handle=/home/oracle/backup_ssh/SVFE_FULL_HOT_egu0qi0r_2_1 tag=FULL_HOT channel ORA_DISK_1: restored backup piece 2 channel ORA_DISK_1: reading from backup piece /home/oracle/backup_ssh/SVFE_FULL_HOT_egu0qi0r_3_1 channel ORA_DISK_1: piece handle=/home/oracle/backup_ssh/SVFE_FULL_HOT_egu0qi0r_3_1 tag=FULL_HOT channel ORA_DISK_1: restored backup piece 3 channel ORA_DISK_1: reading from backup piece /home/oracle/backup_ssh/SVFE_FULL_HOT_egu0qi0r_4_1 ^[[Cchannel ORA_DISK_1: piece handle=/home/oracle/backup_ssh/SVFE_FULL_HOT_egu0qi0r_4_1 tag=FULL_HOT channel ORA_DISK_1: restored backup piece 4 channel ORA_DISK_1: reading from backup piece /home/oracle/backup_ssh/SVFE_FULL_HOT_egu0qi0r_5_1 ^[[C^[[C^[[Cchannel ORA_DISK_1: piece handle=/home/oracle/backup_ssh/SVFE_FULL_HOT_egu0qi0r_5_1 tag=FULL_HOT channel ORA_DISK_1: restored backup piece 5 channel ORA_DISK_1: reading from backup piece /home/oracle/backup_ssh/SVFE_FULL_HOT_egu0qi0r_6_1 ^[[Cchannel ORA_DISK_1: piece handle=/home/oracle/backup_ssh/SVFE_FULL_HOT_egu0qi0r_6_1 tag=FULL_HOT channel ORA_DISK_1: restored backup piece 6 channel ORA_DISK_1: validation complete, elapsed time: 01:03:20 Finished restore at 07-MAY-19 ... |
| 08.05.2019, 01:48:22 |
RMAN> blockrecover corruption list; Starting recover at 07-MAY-19 using target database control file instead of recovery catalog allocated channel: ORA_DISK_1 channel ORA_DISK_1: SID=161 device type=DISK starting media recovery media recovery complete, elapsed time: 00:00:00 Finished recover at 07-MAY-19 ... |
| 08.05.2019, 01:50:39 |
пробовать восстановить файл? restore datafile '/oradata/svfe/curtrans02.dbf' ? ... |
| 08.05.2019, 01:52:44 |
rman> VALIDATE DATAFILE 17 BLOCK 3017980; ... |
| 08.05.2019, 01:56:36 |
Это можно выполнить в параллельной сессии rman? Там уже восстановление идет. Сорри, что побежал вперед, но чат через форум - это большой лаг :( ... |
| 08.05.2019, 01:58:17 |
ВадиманЭто можно выполнить в параллельной сессии rman? Там уже восстановление идет. Сорри, что побежал вперед, но чат через форум - это большой лаг :( Нет, уже позно. Поспешишь, людей насмешишь )) А вы полностью вывод команды validate привели? Нету статистики по файлам и блокам. И ошибок нету, странно... ... |
| 08.05.2019, 02:01:31 |
полностью ... |
| 08.05.2019, 02:04:43 |
Тут не до смеха :( ... |
| 08.05.2019, 02:05:02 |
а ну да. validate она бекап проверяет на предмет восстановления, а не файл базы. будем ждать восстановления. ... |
| 08.05.2019, 02:09:44 |
3-ой piece только начался ... |
| 08.05.2019, 02:15:00 |
raid есть? ... |
| 08.05.2019, 02:16:25 |
Вадиман3-ой piece только началсяможно было RECOVER ... BLOCK сделать, но увы.. ... |
| 08.05.2019, 02:18:05 |
Закончилось: RMAN> restore datafile '/oradata/svfe/curtrans02.dbf'; Starting restore at 07-MAY-19 using target database control file instead of recovery catalog allocated channel: ORA_DISK_1 channel ORA_DISK_1: SID=161 device type=DISK channel ORA_DISK_1: starting datafile backup set restore channel ORA_DISK_1: specifying datafile(s) to restore from backup set channel ORA_DISK_1: restoring datafile 00017 to /oradata/svfe/curtrans02.dbf channel ORA_DISK_1: reading from backup piece /home/oracle/backup_ssh/SVFE_FULL_HOT_egu0qi0r_1_1 ^[[C^[[Cchannel ORA_DISK_1: piece handle=/home/oracle/backup_ssh/SVFE_FULL_HOT_egu0qi0r_1_1 tag=FULL_HOT channel ORA_DISK_1: restored backup piece 1 channel ORA_DISK_1: reading from backup piece /home/oracle/backup_ssh/SVFE_FULL_HOT_egu0qi0r_2_1 ^[[Cchannel ORA_DISK_1: piece handle=/home/oracle/backup_ssh/SVFE_FULL_HOT_egu0qi0r_2_1 tag=FULL_HOT channel ORA_DISK_1: restored backup piece 2 channel ORA_DISK_1: reading from backup piece /home/oracle/backup_ssh/SVFE_FULL_HOT_egu0qi0r_3_1 ^[[C^[[C^[[Cchannel ORA_DISK_1: piece handle=/home/oracle/backup_ssh/SVFE_FULL_HOT_egu0qi0r_3_1 tag=FULL_HOT channel ORA_DISK_1: restored backup piece 3 channel ORA_DISK_1: reading from backup piece /home/oracle/backup_ssh/SVFE_FULL_HOT_egu0qi0r_4_1 ^[[C^[[C^[[Cchannel ORA_DISK_1: piece handle=/home/oracle/backup_ssh/SVFE_FULL_HOT_egu0qi0r_4_1 tag=FULL_HOT channel ORA_DISK_1: restored backup piece 4 channel ORA_DISK_1: reading from backup piece /home/oracle/backup_ssh/SVFE_FULL_HOT_egu0qi0r_5_1 ^[[C^[[Cchannel ORA_DISK_1: piece handle=/home/oracle/backup_ssh/SVFE_FULL_HOT_egu0qi0r_5_1 tag=FULL_HOT channel ORA_DISK_1: restored backup piece 5 channel ORA_DISK_1: restore complete, elapsed time: 00:51:45 Finished restore at 07-MAY-19 ... |
| 08.05.2019, 02:46:51 |
При стартапе ошибка: ORA-01113: file 17 needs media recovery ORA-01110: data file 17: '/oradata/svfe/curtrans02.dbf' ... |
| 08.05.2019, 02:47:24 |
Теперь VALIDATE BLOCK выдает следующее: RMAN> VALIDATE DATAFILE 17 BLOCK 3017980; Starting validate at 07-MAY-19 using target database control file instead of recovery catalog allocated channel: ORA_DISK_1 channel ORA_DISK_1: SID=160 device type=DISK channel ORA_DISK_1: starting validation of datafile channel ORA_DISK_1: specifying datafile(s) for validation input datafile file number=00017 name=/oradata/svfe/curtrans02.dbf channel ORA_DISK_1: validation complete, elapsed time: 00:00:01 List of Datafiles ================= File Status Marked Corrupt Empty Blocks Blocks Examined High SCN ---- ------ -------------- ------------ --------------- ---------- 17 OK 0 0 1 0 File Name: /oradata/svfe/curtrans02.dbf Block Type Blocks Failing Blocks Processed ---------- -------------- ---------------- Data 0 0 Index 0 0 Other 0 1 Finished validate at 07-MAY-19 ... |
| 08.05.2019, 02:49:10 |
запустил recover datafile ... |
| 08.05.2019, 02:53:15 |
Relic Hunter, напиши мне, плиз, на ffx dot blues at gmail dot com ... |
| 08.05.2019, 03:15:14 |
договоримся ) В итоге все успешно, БД поднялась ... |
| 08.05.2019, 03:15:36 |
Вадимандоговоримся ) В итоге все успешно, БД подняласьну вот и славно. ... |
| 08.05.2019, 03:49:02 |
Я отблагодарить хочу за отклик и участие ) Чтоб не быть голословным. Глядишь, в следующий раз (не дай бог) у меня будет на 1 шанс больше ) Так что пиши ... |
| 08.05.2019, 05:33:30 |
ВадиманТак что пиши ткни в его профиль, там у него в профиле почта, напиши сам и договорись как отблагодарить, зачем засорять форум? ... |
| 08.05.2019, 10:01:15 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1882520]: |
287ms |
58ms |
| others: | 203ms |
| total: | 590ms |
