ORA-00997 illegal use of LONG datatype
Код: plaintext Код: plsql 1. 2. 3. 4. 5. 6. Код: plaintext Код: plsql 1. 2. 3. 4. 5. 6. Код: plaintext Как? Почему? Зачем? Что делать и кто виноват. ... |
| 19.06.2019, 19:00:29 |
https://docs.oracle.com/database/121/SQLRF/sql_elements001.htm#SQLRF0021 LONG Data Type Do not create tables with LONG columns. Use LOB columns (CLOB, NCLOB, BLOB) instead. LONG columns are supported only for backward compatibility. ... Oracle also recommends that you convert existing LONG columns to LOB columns . LOB columns are subject to far fewer restrictions than LONG columns. Further, LOB functionality is enhanced in every release, whereas LONG functionality has been static for several releases. See the modify_col_properties clause of ALTER TABLE and TO_LOB for more information on converting LONG columns to LOB. You can reference LONG columns in SQL statements in these places: SELECT lists SET clauses of UPDATE statements VALUES clauses of INSERT statements The use of LONG values is subject to these restrictions: A table can contain only one LONG column. You cannot create an object type with a LONG attribute. LONG columns cannot appear in WHERE clauses or in integrity constraints (except that they can appear in NULL and NOT NULL constraints). LONG columns cannot be indexed. LONG data cannot be specified in regular expressions. A stored function cannot return a LONG value. You can declare a variable or argument of a PL/SQL program unit using the LONG data type. However, you cannot then call the program unit from SQL. Within a single SQL statement, all LONG columns, updated tables, and locked tables must be located on the same database. LONG and LONG RAW columns cannot be used in distributed SQL statements and cannot be replicated. If a table has both LONG and LOB columns, then you cannot bind more than 4000 bytes of data to both the LONG and LOB columns in the same SQL statement. However, you can bind more than 4000 bytes of data to either the LONG or the LOB column. In addition, LONG columns cannot appear in these parts of SQL statements: GROUP BY clauses, ORDER BY clauses, or CONNECT BY clauses or with the DISTINCT operator in SELECT statements The UNIQUE operator of a SELECT statement The column list of a CREATE CLUSTER statement The CLUSTER clause of a CREATE MATERIALIZED VIEW statement SQL built-in functions, expressions, or conditions SELECT lists of queries containing GROUP BY clauses SELECT lists of subqueries or queries combined by the UNION, INTERSECT, or MINUS set operators SELECT lists of CREATE TABLE ... AS SELECT statements ALTER TABLE ... MOVE statements SELECT lists in subqueries in INSERT statements Triggers can use the LONG data type in the following manner: A SQL statement within a trigger can insert data into a LONG column. If data from a LONG column can be converted to a constrained data type (such as CHAR and VARCHAR2), then a LONG column can be referenced in a SQL statement within a trigger. Variables in triggers cannot be declared using the LONG data type. :NEW and :OLD cannot be used with LONG columns. You can use Oracle Call Interface functions to retrieve a portion of a LONG value from the database. ... |
| 19.06.2019, 19:09:57 |
andrey_anonymous, Спасибо. А то было желание сделать поля "как раньше". Желание прошло. ... |
| 19.06.2019, 20:31:28 |
Victor CookinСпасибо. А то было желание сделать поля "как раньше". Желание прошло.Умения самостоятельно полистать документацию совсем нет? Или чукча не читатель? ... |
| 19.06.2019, 23:27:06 |
Elic, никогда в жизни ничего не листал, даже в 80-х уже были микрофильмы ... |
| 26.06.2019, 20:04:53 |
Victor Cookinникогда в жизни ничего не листал Не верю ( C ) Victor Cookin, даже в 80-х уже были микрофильмы в Самаре, в школах учебники тоже в микрофильмах выдаются? какой продвинутый город! и газеты в микрофильмах? прям аж с 80-х? ... |
| 26.06.2019, 20:49:01 |
Victor Cookinдаже в 80-х уже были микрофильмы Ты часом микрофильмы с диафильмами не попутал? Да, первые микрофильмы я увидел в 80-х. Коды VAX/VMS и других DECовских продуктов добытые доблестными совковыми офицерами плаща и кинжала. Их нам первый отдел выдавал для просмотра в спец. комнате. SY. ... |
| 26.06.2019, 21:07:45 |
Микрофиши были, а не микрофильмы. И очень не массово - я, например, читал про "устройство и преимущества" в научно-популярном журнале ("Наука и жизнь"), но в реальной жизни не сталкивался. ... |
| 27.06.2019, 05:42:09 |
Victor Cookinникогда в жизни ничего не листал, даже в 80-х уже были микрофильмыТакой самовлюблённый из себя тормозной дурак... ... |
| 27.06.2019, 07:56:29 |
Victor Cookin, в древней версии експортнуть табличку с лонг, импортнуть в 12-ку тоже не даст? ..... stax ... |
| 27.06.2019, 12:54:49 |
Staxв древней версии експортнуть табличку с лонгзачем? ... |
| 27.06.2019, 13:39:03 |
Stax, старый код работает, кто ж мне ( к тому ж самовлюблённому дураку:) его править даст? ... |
| 27.06.2019, 21:22:05 |
Stax, к тому ж это всё наверно можно сделать и в Оракле, никуда не экспортируя ... |
| 27.06.2019, 21:23:31 |
Victor Cookinэто всё наверно можно сделать и в Оракле, никуда не экспортируя Более того, почти наверняка это можно делать и не создавая новых таблиц или других объектов в базе. Но тут программист нужен. Posted via ActualForum NNTP Server 1.5 ... |
| 27.06.2019, 21:49:45 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1882348]: |
31ms |
| others: | 179ms |
| total: | 264ms |
