(не)Установка Oracle BI 12c
устанавливаю под CentOS 7 1 jdk 2 fmw_12.2.1.4.0_infrastructure.jar все без ошибок bi_platform-12.2.1.4.0.linux64.bin возникает ошибка Cause:Not all dependent featuresets for install type "BI Platform Distribution" could be found. The following prerequisites were found to be missing:[[install2019-11-08_01-57-06PM.log-jrf_wlsFmw - 12.2.1.3.0glcm_opatchauto_fmw - 13.9.2.0.0 Как Лечить? Заранее Благодарю ... |
| 08.11.2019, 13:19:06 |
babidna The following prerequisites were found to be missing: ... install....log Вроде ж все написал: необходимы пакеты, см. лог. ... |
| 08.11.2019, 13:25:03 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1881891]: |
28ms |
55ms |
| others: | 225ms |
| total: | 365ms |
