Работа с sqlplus, запуск через готовый образ с офф сайта oracle, ужасно много текста...
Скачал с офф сайта готовый образ со всеми пакетами для администрирования БД, но не могу зайти в sqlplus. Прошу не кидаться камнями. при вводе sqlplus почта указанная при заходе в терминал и на раб. столе в файле readme выводит следущее * All passwords are oracle or noted if otherwise. * All the Hands on Labs can be accessed by opening the ODDHandsOnLabs.html file on the Desktop. * Oracle SQL Developer, Data Modeler, SQLcl and Rest Client can be found in the desktop menu Applications/Other. The SQL Developer and Data Modeler scripts are in the directory: /home/oracle/Desktop/Database_Track/sqldevdm and /home/oracle/Desktop/Database_Track/sqldev The Application Express scripts are in the directory: /home/oracle/Desktop/APEX_Track/files To Reset the labs: SQL Developer: /home/oracle/reset_sqldev (includes ORDS, Data Modeler, Unit Test) Application Express: /home/oracle/reset_apex REST Data Services : /home/oracle/reset_rest (APEX related) SODA4REST : /home/oracle/reset_soda4rest Soup to Nuts : /home/oracle/reset_soup — APEX Labs Only /home/oracle/reset_soup_apex_only Database Information: Oracle SID : orclcdb Pluggable DB : orcl Pluggable DB : ords create if required by running: 'newpdbords' in the terminal - for ORDS pdb creation. (if 'sqlplus system/oracle@ORDS' connects ORDS pdb has already been installed) 'loadstorm' in the terminal for spatial demo data - takes a few minutes. ALL PASSWORDS ARE : oracle *** Please note that this appliance is for testing purposes only, as such it is unsupported and should not be used as a production environment. /////////////////////////////// при вводе sqlplus выдаёт следущее и выкидывает обратно в терминал(т.е служба sql не запускается) oracle@localhost ~]$ sql * plus /nolog Oracle SQL Developer Command-Line (SQLcl) help Usage 1: sql -H | -V -H Displays the SQLcl version and the usage help. -V Displays the SQLcl version. Usage 2: sql [<option>] [{ <logon> | /nolog}] [<start>] <option> is: [-R <level>] [-S] [-verbose] [-oci] [-L[OGON] ] -R <level> Sets restricted mode to disable SQLcl commands that interact with the file system. The level can be 1, 2, 3 or 4. The most restrictive is -R 4 which disables all user commands interacting with the file system. -S Sets silent mode which suppresses the display of the SQLcl banner, prompts, and echoing of commands. -verbose Set this to show logging messages inline. By default these messages are suppressed. -nohistory Switch off history logging. -noupdates Do not check update site for newer versions available. -oci Set this to use an Oracle Instant Client installation. If this option is set, then SQLcl will use the drivers from the first Installation on the path. -L[OGON] Specifies not to reprompt for username or password if the initial connection does not succeed. <logon> is: {<username>[/<password>][@<connect_identifier>] | / } [AS {SYSDBA | SYSOPER | SYSASM}] Specifies the database account username, password and connect identifier for the database connection. Without a connect identifier, SQLcl connects to the default database. The AS SYSDBA, AS SYSOPER and AS SYSASM options are database administration privileges. <connect_identifier> can be in the form of Net Service Name or Easy Connect. @[<net_service_name> | [//]Host[:Port]/<service_name>] <net_service_name> is a simple name for a service that resolves to a connect descriptor. Example: Connect to database using Net Service Name and the database net service name is ORCL. sql myusername/mypassword@ORCL Host specifies the host name or IP address of the database server computer. Port specifies the listening port on the database server. <service_name> specifies the service name of the database you want to access. Example: Connect to database using Easy Connect and the Service name is ORCL. sql myusername/mypassword@Host/ORCL The /NOLOG option starts SQLcl without connecting to a database. <start> is: @<URL>|<filename>[.<ext>] [<parameter> ...] Runs the specified SQLcl script from a web server (URL) or the local file system (filename.ext) with specified parameters that will be assigned to substitution variables in the script. When SQLcl starts, and after CONNECT commands, the site profile (e.g. $ORACLE_HOME/sqlplus/admin/glogin.sql) and the user profile (e.g. login.sql in the working directory) are run. The files may contain SQLcl commands. Refer to the SQLDeveloper User's Guide and Reference for more information. [oracle@localhost ~]$ /////////////////////////// при вводе [oracle@localhost ~]$ sqlplus system/oracle@ORDS SQL*Plus: Release 19.0.0.0.0 - Production on Mon Apr 6 10:20:58 2020 Version 19.3.0.0.0 Copyright (c) 1982, 2019, Oracle. All rights reserved. и нет строки sql или ещё чего-то просто весит пока не введшь команду ctrl+z/c ///// В итоге из вариантов обратится на форум, мониторить интернет, или работать в sql developer, в последнем случае по идее позволяет работать с теми же инструментами sql / PL/SQL, первое наиболее быстро разобраться с проблемой и получить нужный експириенс ... |
| 06.04.2020, 17:30:59 |
deadpunch, Начните с opening the ODDHandsOnLabs.html file on the Desktop Там должно быть написано всё нужное для подключения к БД. ... |
| 06.04.2020, 17:36:32 |
deadpunch $ sql * plus ... |
| 06.04.2020, 17:41:19 |
Elic, Аналогичная команда sqlplus и далее лог@**.** ... |
| 06.04.2020, 18:30:58 |
SQL*Plus deadpunch, Начните с opening the ODDHandsOnLabs.html file on the Desktop Там должно быть написано всё нужное для подключения к БД. ... |
| 06.04.2020, 19:33:26 |
SQL*Plus, Да, я зашёл на сайд и с помощью переводчика, скупых знаний английского и чей то матери пытаюсь познать SQL)) ... |
| 06.04.2020, 19:50:21 |
при вводе sqlplus почта указанная Непонятно. sql * plus /nolog Пробелы имеют значение. Аналогичная команда sqlplus и далее лог@**.** Непонятно. при вводе [oracle@localhost ~]$ sqlplus system/oracle@ORDS просто весит пока не введшь команду ctrl+z/c В и сит. Сколько ждали? Больше 15 секунд? ... |
| 06.04.2020, 20:06:22 |
deadpunch SQL*Plus, Да, я зашёл на сайд и с помощью переводчика, скупых знаний английского и чей то матери пытаюсь познать SQL)) [spoiler] Говорила мама: "Учи английский, сынок, учи!" ... |
| 06.04.2020, 20:36:47 |
| 06.04.2020, 22:42:08 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1881377]: |
48ms |
58ms |
| others: | 218ms |
| total: | 385ms |
