Нужна помощь, ora-06502
Всем привет, ситуация следующая, если курсор пустой PersAccOrgInfo, то выдает ошибку ora-06502 ----ошибка числа или значения ora-06512 line 131 ora-06512 line 233 Ошибку бьет из-за того, что приходит пустое значение сюда p_in(i):=t_obj(p_contid(i).mtsaccountid,p_contid(i).mtscontractid,null,null); begin --List of values for where condition for i in p_contid.first..p_contid.count loop p_in.extend(); p_in(i):=t_obj(p_contid(i).mtsaccountid,p_contid(i).mtscontractid,null,null); end loop; Есть идеи как обойти это? -------------------------------------------- declare --to declare %rowtype for lookups cursor lookups is select "Id" cid,"MTSForisId" cfid from "Job" where 1=2; --to declare %rowtype for cursor contracts is select "Id" contractid,"ContactId" clientid,"MTSContractId" forisid from "Contract" where 1=2; cursor PersAccOrgInfo is select mtsname, mtsnotes, mtsaccountid, mtscontractid, mtsstatusid, mtsclosingreasonid, mtsblocktypeid, mtsmethodcalculationid, mtscodeword, --mtsmethodinvdeliveryid, --mtsinvoicedeliveryaddress, --mtsdocumentformatid, mtscreditlimit, mtsnotdisconnectcrlim, mtsbillinggroupid, mtspaymentday, mtscreditcalctypeid, mtspersonalaccountid, wstrustcathegoryid from ocrm.mtsinvoicepersorgtmp@crm_ocrm where exists (select 1 from "Contract" inner join "Account" on "Contract"."AccountId" = "Account"."Id" where "MTSContractId" = mtscontractid and "Account"."MTSForisID" = mtsaccountid) and not exists (select 1 from "MTSInvoicePers" INNER JOIN "Account" ON "MTSInvoicePers"."MTSAccountId" = "Account"."Id" where "MTSPersonalAccId"=mtspersonalaccountid and "Account"."MTSForisID" = mtsaccountid and "MTSForisContractId" = mtscontractid); --AND ROWNUM < 2; type t_rec is table of lookups%rowtype index by varchar2(30); type t_contracts is table of contracts%rowtype index by varchar2(30); l_contract t_contracts; l_contractid t_rec; --l_persaccnoid t_rec; l_status t_rec; l_calcmethod t_rec; l_invoicedelivery t_rec; l_documentformat t_rec; l_billinggroup t_rec; l_persacctype t_rec; l_trustcateg t_rec; type t_PersAccOrgInfo is table of PersAccOrgInfo%rowtype index by binary_integer; l_persaccno t_PersAccOrgInfo; l_SuperVisor varchar2(100):='{410006E1-CA4E-4502-A9EC-E54D922D2C00}'; dml_errors exception; pragma exception_init(dml_errors, -24381); l_errors number; l_errno number; l_msg varchar2(4000); l_idx number; l_contr_err varchar2(1000); v_accountid "SysLanguage"."Id"%type; v_contractid "SysLanguage"."Id"%type; v_status "SysLanguage"."Id"%type; v_calcmethod "SysLanguage"."Id"%type; v_invoicedelivery "SysLanguage"."Id"%type; v_documentformat "SysLanguage"."Id"%type; v_billinggroup "SysLanguage"."Id"%type; v_persacctype "SysLanguage"."Id"%type; v_trustcateg "SysLanguage"."Id"%type; /*Function of getting Uid by Foris value*/ function fn_GetId(p_contype in t_contracts,v_idx in varchar2,p int) return "ContactType"."Id"%type is begin if p=1 then --contract if p_contype.exists(v_idx) then return p_contype(v_idx).contractid; else return null; end if; elsif p=2 then if p_contype.exists(v_idx) then return p_contype(v_idx).clientid; else return null; end if; end if; end; /*Function of getting Uid by Foris value*/ function fn_GetId(p_contype in t_rec,v_idx in varchar2) return "ContactType"."Id"%type is begin if p_contype.exists(v_idx) then return p_contype(v_idx).cid; else return null; end if; end; /*Function of getting Uids for bulk colletion of ContactIds*/ procedure Pr_getContractId(p_contid in t_PersAccOrgInfo,p_out out t_contracts) is p_in t_tab_obj:=t_tab_obj(null,null,null,null); type t_contractid is table of "Contract"."Id"%type index by pls_integer; type t_clientid is table of "Contract"."MTSForisOwnerId"%type index by pls_integer; type t_forisid is table of "Contract"."MTSContractId"%type index by pls_integer; l_contractid t_contractid; l_clientid t_clientid; l_forisid t_forisid; begin --List of values for where condition for i in p_contid.first..p_contid.count loop p_in.extend(); p_in(i):=t_obj(p_contid(i).mtsaccountid,p_contid(i).mtscontractid,null,null); end loop; begin select contractid,clientid,forisid bulk collect into l_contractid,l_clientid,l_forisid from ( select "Id" contractid,"AccountId" clientid,"MTSForisOwnerId"||'~'||"MTSContractId" forisid --!!! contract~client key value from "Contract" --where ("MTSForisOwnerId","MTSContractId") in (select contactid,contractid from table(p_in) where 1=1) --List of values --where ("MTSContractId") in (SELECT contractid from table(p_in) where 1=1) where ("MTSForisOwnerId","MTSContractId") in (select TO_CHAR(contactid),TO_CHAR(contractid) from table(p_in) where 1=1) --List of values ); p_out.delete;--erase out collection --populate out collection for i in l_contractid.first..l_contractid.last loop p_out(l_forisid(i)).contractid:=l_contractid(i); p_out(l_forisid(i)).clientid:=l_clientid(i); p_out(l_forisid(i)).forisid:=l_forisid(i); end loop; exception when no_data_found then dbms_output.put_line('No ForsiId at ContactTab'); when others then dbms_output.put_line('fn_getContactId_errors:'||sqlerrm); dbms_output.put_line('fn_getContactId_Stack:'||dbms_utility.format_error_stack); dbms_output.put_line('fn_getContactId_BackTrace:'||dbms_utility.format_error_backtrace); end; end; -----------------------------Main------------------------------------- begin --MTSStatusId for c1 in (select "Id" cid,"MTSForisId" cfid from "MTSInvoiceStateForCS" where "MTSForisId" is not null) loop l_status(c1.cfid).cid:=c1.cid; l_status(c1.cfid).cfid:=c1.cfid; end loop; --!NoData for MTSClosingReasonId --!NoData for MTSBlockTypeId --MTSMethodCalculationId for c1 in (select "Id" cid,"MTSForisId" cfid from "MTSCalculationMethod" where "MTSForisId" is not null) loop l_calcmethod(c1.cfid).cid:=c1.cid; l_calcmethod(c1.cfid).cfid:=c1.cfid; end loop; --MTSMethodInvDeliveryId for c1 in (select "Id" cid,"MTSForisId" cfid from "MTSInvoiceDeliveryType" where "MTSForisId" is not null) loop l_invoicedelivery(c1.cfid).cid:=c1.cid; l_invoicedelivery(c1.cfid).cfid:=c1.cfid; end loop; --MTSDocumentFormatId for c1 in (select "Id" cid,"MTSForisId" cfid from "MTSDocumentFormat" where "MTSForisId" is not null) loop l_documentformat(c1.cfid).cid:=c1.cid; l_documentformat(c1.cfid).cfid:=c1.cfid; end loop; --MTSBillingGroupId for c1 in (select "Id" cid,"MTSForisID" cfid from "MTSBillingGroup" where "MTSForisID" is not null) loop l_billinggroup(c1.cfid).cid:=c1.cid; l_billinggroup(c1.cfid).cfid:=c1.cfid; end loop; --MTSPersonalAccountType(!MTSCreditCalcTypeId) for c1 in (select "Id" cid,"MTSForisId" cfid from "MTSPersonalAccountType" where "MTSForisId" is not null) loop l_persacctype(c1.cfid).cid:=c1.cid; l_persacctype(c1.cfid).cfid:=c1.cfid; end loop; --WSTrustCathegoryId for c1 in (select "Id" cid,"MTSForisId" cfid from "MTSTrustCategory" where "MTSForisId" is not null) loop l_trustcateg(c1.cfid).cid:=c1.cid; l_trustcateg(c1.cfid).cfid:=c1.cfid; end loop; dbms_output.put_line('Open PersAccOrgInfo'); open PersAccOrgInfo; loop fetch PersAccOrgInfo bulk collect into l_persaccno limit 1000; begin Pr_getContractId(l_persaccno,l_contract);--l_contract - out var.Populatig a collection of Contract\Contact ForisId->Uid values for i in 1 .. l_persaccno.count loop v_contractid:=fn_getid(l_contract,l_persaccno(i).mtsaccountid||'~'||l_persaccno(i).mtscontractid,1);--ContractGuid v_accountid:=fn_getid(l_contract,l_persaccno(i).mtsaccountid||'~'||l_persaccno(i).mtscontractid,2); --AccountGuid v_status:=fn_getid(l_status,l_persaccno(i).mtsstatusid); v_calcmethod:=fn_getid(l_calcmethod,l_persaccno(i).mtsmethodcalculationid); --v_invoicedelivery:=fn_getid(l_invoicedelivery,l_persaccno(i).mtsmethodinvdeliveryid); --v_documentformat:=fn_getid(l_documentformat,l_persaccno(i).mtsdocumentformatid); v_billinggroup:=fn_getid(l_billinggroup,l_persaccno(i).mtsbillinggroupid); v_persacctype:=fn_getid(l_persacctype,l_persaccno(i).mtscreditcalctypeid); v_trustcateg:=fn_getid(l_trustcateg,l_persaccno(i).wstrustcathegoryid); l_contr_err:='persacc : '||l_persaccno(i).mtspersonalaccountid||' contr: '||l_persaccno(i).mtscontractid||' account: '||l_persaccno(i).mtsaccountid; insert into "MTSInvoicePers" ( "MTSName", "MTSNotes", "MTSAccountId", "MTSContractId", "MTSStatusId", --"MTSClosingReasonId", --"MTSBlockTypeId", "MTSMethodCalculationId", --"MTSCodeword", --"MTSMethodInvDeliveryId", --"MTSInvoiceDeliveryAddress", --"MTSDocumentFormatId", "MTSCreditLimit", "MTSNotDisconnectCrLim", "MTSBillingGroupId", "MTSPaymentDay", "MTSPersonalAccountTypeId",--"MTSCreditCalcTypeId", "MTSPersonalAccId", "WSTrustCathegoryId", "CreatedById", "ModifiedById", "MTSForisContractId", "MTSForisOwnerId" ) values ( l_persaccno(i).mtsname, l_persaccno(i).mtsnotes, v_accountid,--MTSForisOwnerId v_contractid,--mtscontractid v_status,--mtsstatusid --mtsclosingreasonid, --mtsblocktypeid, v_calcmethod,--mtsmethodcalculationid --l_persaccno(i).mtscodeword, --v_invoicedelivery,--mtsmethodinvdeliveryid --l_persaccno(i).mtsinvoicedeliveryaddress, --v_documentformat,--mtsdocumentformatid l_persaccno(i).mtscreditlimit, l_persaccno(i).mtsnotdisconnectcrlim, v_billinggroup,--mtsbillinggroupid l_persaccno(i).mtspaymentday, v_persacctype,--mtscreditcalctypeid, l_persaccno(i).mtspersonalaccountid, v_trustcateg,--wstrustcathegoryid l_SuperVisor, l_SuperVisor, l_persaccno(i).mtscontractid, l_persaccno(i).mtsaccountid ); end loop; commit; exit when PersAccOrgInfo%notfound; end loop; end loop; close PersAccOrgInfo; dbms_output.put_line('Done'); end; / ... |
| 02.03.2021, 13:33:16 |
ivnchui ora-06502 ----ошибка числа или значения ivnchui Есть идеи как обойти это? ... |
| 02.03.2021, 16:58:36 |
ivnchui Всем привет, ситуация следующая, если курсор пустой PersAccOrgInfo, то выдает ошибку ora-06502 ----ошибка числа или значения ora-06512 line 131 ora-06512 line 233 Ошибку бьет из-за того, что приходит пустое значение сюда p_in(i):=t_obj(p_contid(i).mtsaccountid,p_contid(i).mtscontractid,null,null); Код: plsql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68. 69. 70. 71. 72. 73. 74. 75. 76. 77. 78. 79. 80. 81. 82. 83. 84. 85. 86. 87. 88. 89. 90. 91. 92. 93. 94. 95. 96. 97. 98. 99. 100. 101. 102. 103. 104. 105. 106. 107. 108. 109. 110. 111. 112. 113. 114. 115. 116. 117. 118. 119. 120. 121. 122. 123. 124. 125. 126. 127. 128. 129. 130. 131. 132. 133. 134. 135. 136. 137. 138. 139. 140. 141. 142. 143. 144. 145. 146. 147. 148. 149. 150. 151. 152. 153. 154. 155. 156. 157. 158. 159. 160. 161. 162. 163. 164. 165. 166. 167. 168. 169. 170. 171. 172. 173. 174. 175. 176. 177. 178. 179. 180. 181. 182. 183. 184. 185. 186. 187. 188. 189. 190. 191. 192. 193. 194. 195. 196. 197. 198. 199. 200. 201. 202. 203. 204. 205. 206. 207. 208. 209. 210. 211. 212. 213. 214. 215. 216. 217. 218. 219. 220. 221. 222. 223. 224. 225. 226. 227. 228. 229. 230. 231. 232. 233. 234. 235. 236. 237. 238. 239. 240. 241. 242. 243. 244. 245. 246. 247. 248. 249. 250. 251. 252. 253. 254. 255. 256. 257. 258. 259. 260. 261. 262. 263. 264. 265. 266. 267. 268. 269. 270. 271. 272. 273. 274. 275. 276. 277. 278. 279. 280. 281. 282. 283. 284. 285. 286. 287. 288. 289. 290. 291. 292. 293. 294. 295. 296. 297. 298. 299. 300. 301. 302. 303. 304. 305. 306. 307. 308. 309. 310. 311. 312. 313. 314. 315. 316. 317. 318. 319. 320. 321. 322. 323. Насчет форматирования кода - это выглядит вот так. Правда удобнее читать? Что-то у вас не так в t_obj. ... |
| 02.03.2021, 19:43:05 |
SQL*Plus, Да, действительно удобнее, на платформе первый раз, поэтому не знаю всех тонкостей. Если в курсоре PersAccOrgInfo есть какие-либо данные, то все записывается. Если же данные отсутствуют, сразу бьется ошибка.... ... |
| 03.03.2021, 08:42:40 |
Вам уже намекнули - подготовьте простой test case. Который каждый может запустить у себя без привязки к вашим объектам. Как правило, 95% вопросов снимается при его подготовке. Читать простыни ни у кого желания нет. ... |
| 03.03.2021, 09:09:28 |
ivnchui SQL*Plus, Да, действительно удобнее, на платформе первый раз, поэтому не знаю всех тонкостей. Если в курсоре PersAccOrgInfo есть какие-либо данные, то все записывается. Если же данные отсутствуют, сразу бьется ошибка.... Еще раз повторю: Что-то у вас не так в t_obj. ... |
| 03.03.2021, 21:51:06 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1880399]: |
61ms |
31ms |
| others: | 185ms |
| total: | 311ms |
