udevadm test
udevadm test /block/sdb/sdb1 calling: test version 219 This program is for debugging only, it does not run any program specified by a RUN key. It may show incorrect results, because some values may be different, or not available at a simulation run. === trie on-disk === tool version: 219 file size: 9013079 bytes header size 80 bytes strings 2306191 bytes nodes 6706808 bytes Load module index Created link configuration context. timestamp of '/etc/udev/rules.d' changed timestamp of '/usr/lib/udev/rules.d' changed Reading rules file: /usr/lib/udev/rules.d/01-md-raid-creating.rules Reading rules file: /usr/lib/udev/rules.d/10-dm.rules Reading rules file: /usr/lib/udev/rules.d/11-dm-lvm.rules Reading rules file: /usr/lib/udev/rules.d/11-dm-mpath.rules Reading rules file: /usr/lib/udev/rules.d/13-dm-disk.rules Reading rules file: /usr/lib/udev/rules.d/39-usbmuxd.rules Reading rules file: /usr/lib/udev/rules.d/40-libgphoto2.rules IMPORT found builtin 'usb_id --export %%p', replacing /usr/lib/udev/rules.d/40-libgphoto2.rules:11 Reading rules file: /usr/lib/udev/rules.d/40-redhat-disable-dell-ir-camera.rules Reading rules file: /usr/lib/udev/rules.d/40-redhat-disable-lenovo-ir-camera.rules Reading rules file: /usr/lib/udev/rules.d/40-redhat.rules Reading rules file: /usr/lib/udev/rules.d/40-usb_modeswitch.rules Reading rules file: /usr/lib/udev/rules.d/42-usb-hid-pm.rules Reading rules file: /usr/lib/udev/rules.d/50-rbd.rules Reading rules file: /usr/lib/udev/rules.d/50-udev-default.rules Reading rules file: /usr/lib/udev/rules.d/56-hpmud.rules Reading rules file: /usr/lib/udev/rules.d/60-alias-kmsg.rules Reading rules file: /usr/lib/udev/rules.d/60-cdrom_id.rules Reading rules file: /usr/lib/udev/rules.d/60-drm.rules Reading rules file: /usr/lib/udev/rules.d/60-evdev.rules Reading rules file: /usr/lib/udev/rules.d/60-fprint-autosuspend.rules Reading rules file: /usr/lib/udev/rules.d/60-keyboard.rules Reading rules file: /usr/lib/udev/rules.d/60-net.rules Reading rules file: /usr/lib/udev/rules.d/60-persistent-alsa.rules Reading rules file: /usr/lib/udev/rules.d/60-persistent-input.rules Reading rules file: /usr/lib/udev/rules.d/60-persistent-serial.rules Reading rules file: /usr/lib/udev/rules.d/60-persistent-storage-tape.rules Reading rules file: /usr/lib/udev/rules.d/60-persistent-storage.rules Reading rules file: /usr/lib/udev/rules.d/60-persistent-v4l.rules Reading rules file: /usr/lib/udev/rules.d/60-raw.rules Reading rules file: /usr/lib/udev/rules.d/60-rdma-ndd.rules Reading rules file: /usr/lib/udev/rules.d/60-srp_daemon.rules Reading rules file: /usr/lib/udev/rules.d/61-accelerometer.rules Reading rules file: /usr/lib/udev/rules.d/61-gdm.rules Reading rules file: /usr/lib/udev/rules.d/61-gnome-bluetooth-rfkill.rules Reading rules file: /usr/lib/udev/rules.d/61-gnome-settings-daemon-rfkill.rules Reading rules file: /usr/lib/udev/rules.d/62-multipath.rules Reading rules file: /usr/lib/udev/rules.d/63-fc-wwpn-id.rules Reading rules file: /usr/lib/udev/rules.d/63-md-raid-arrays.rules Reading rules file: /usr/lib/udev/rules.d/64-btrfs-dm.rules Reading rules file: /usr/lib/udev/rules.d/64-btrfs.rules Reading rules file: /usr/lib/udev/rules.d/65-libwacom.rules Reading rules file: /usr/lib/udev/rules.d/65-md-incremental.rules Reading rules file: /usr/lib/udev/rules.d/65-sane-backends.rules Reading rules file: /usr/lib/udev/rules.d/66-saned.rules Reading rules file: /usr/lib/udev/rules.d/69-cd-sensors.rules Reading rules file: /usr/lib/udev/rules.d/69-dm-lvm-metad.rules Reading rules file: /usr/lib/udev/rules.d/69-libmtp.rules Reading rules file: /usr/lib/udev/rules.d/69-md-clustered-confirm-device.rules Reading rules file: /etc/udev/rules.d/69-vdo-start-by-dev.rules Reading rules file: /usr/lib/udev/rules.d/69-xorg-vmmouse.rules Reading rules file: /usr/lib/udev/rules.d/70-hypervfcopy.rules Reading rules file: /usr/lib/udev/rules.d/70-hypervkvp.rules Reading rules file: /usr/lib/udev/rules.d/70-hypervvss.rules Reading rules file: /usr/lib/udev/rules.d/70-mouse.rules Reading rules file: /etc/udev/rules.d/70-persistent-ipoib.rules Reading rules file: /usr/lib/udev/rules.d/70-power-switch.rules Reading rules file: /usr/lib/udev/rules.d/70-printers.rules Reading rules file: /usr/lib/udev/rules.d/70-spice-vdagentd.rules Reading rules file: /usr/lib/udev/rules.d/70-touchpad-quirks.rules Reading rules file: /usr/lib/udev/rules.d/70-touchpad.rules Reading rules file: /usr/lib/udev/rules.d/70-uaccess.rules Reading rules file: /usr/lib/udev/rules.d/70-wacom.rules Reading rules file: /usr/lib/udev/rules.d/71-biosdevname.rules Reading rules file: /usr/lib/udev/rules.d/71-seat.rules Reading rules file: /usr/lib/udev/rules.d/73-idrac.rules Reading rules file: /usr/lib/udev/rules.d/73-seat-late.rules Reading rules file: /usr/lib/udev/rules.d/75-net-description.rules Reading rules file: /usr/lib/udev/rules.d/75-probe_mtd.rules Reading rules file: /usr/lib/udev/rules.d/75-rdma-description.rules Reading rules file: /usr/lib/udev/rules.d/75-tty-description.rules Reading rules file: /usr/lib/udev/rules.d/76-phys-port-name.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-cinterion-port-types.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-dell-port-types.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-ericsson-mbm.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-haier-port-types.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-huawei-net-port-types.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-longcheer-port-types.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-mtk-port-types.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-nokia-port-types.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-pcmcia-device-blacklist.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-simtech-port-types.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-telit-port-types.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-usb-device-blacklist.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-usb-serial-adapters-greylist.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-x22x-port-types.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-zte-port-types.rules Reading rules file: /usr/lib/udev/rules.d/78-sound-card.rules Reading rules file: /usr/lib/udev/rules.d/80-drivers.rules Reading rules file: /usr/lib/udev/rules.d/80-kvm.rules Reading rules file: /usr/lib/udev/rules.d/80-libinput-device-groups.rules Reading rules file: /usr/lib/udev/rules.d/80-mm-candidate.rules Reading rules file: /usr/lib/udev/rules.d/80-net-name-slot.rules Reading rules file: /usr/lib/udev/rules.d/80-net-setup-link.rules Reading rules file: /usr/lib/udev/rules.d/80-udisks2.rules Reading rules file: /usr/lib/udev/rules.d/81-kvm-rhel.rules Reading rules file: /usr/lib/udev/rules.d/84-nm-drivers.rules Reading rules file: /usr/lib/udev/rules.d/85-nm-unmanaged.rules Reading rules file: /usr/lib/udev/rules.d/85-regulatory.rules Reading rules file: /usr/lib/udev/rules.d/89-alsa-ucm.rules Reading rules file: /usr/lib/udev/rules.d/90-alsa-restore.rules Reading rules file: /usr/lib/udev/rules.d/90-alsa-tools-firmware.rules Reading rules file: /usr/lib/udev/rules.d/90-bolt.rules Reading rules file: /usr/lib/udev/rules.d/90-fwupd-devices.rules Reading rules file: /usr/lib/udev/rules.d/90-iprutils.rules Reading rules file: /usr/lib/udev/rules.d/90-iwpmd.rules Reading rules file: /usr/lib/udev/rules.d/90-libinput-model-quirks.rules Reading rules file: /usr/lib/udev/rules.d/90-nm-thunderbolt.rules Reading rules file: /usr/lib/udev/rules.d/90-pulseaudio.rules Reading rules file: /usr/lib/udev/rules.d/90-rdma-hw-modules.rules Reading rules file: /usr/lib/udev/rules.d/90-rdma-ulp-modules.rules Reading rules file: /usr/lib/udev/rules.d/90-rdma-umad.rules Reading rules file: /usr/lib/udev/rules.d/90-spice-guest-streaming.rules Reading rules file: /usr/lib/udev/rules.d/90-vconsole.rules Reading rules file: /usr/lib/udev/rules.d/91-drm-modeset.rules Reading rules file: /usr/lib/udev/rules.d/95-cd-devices.rules Reading rules file: /usr/lib/udev/rules.d/95-dm-notify.rules Reading rules file: /usr/lib/udev/rules.d/95-udev-late.rules Reading rules file: /usr/lib/udev/rules.d/95-upower-csr.rules Reading rules file: /usr/lib/udev/rules.d/95-upower-hid.rules Reading rules file: /usr/lib/udev/rules.d/95-upower-wup.rules Reading rules file: /usr/lib/udev/rules.d/98-kexec.rules Reading rules file: /usr/lib/udev/rules.d/98-rdma.rules Reading rules file: /usr/lib/udev/rules.d/99-qemu-guest-agent.rules Reading rules file: /usr/lib/udev/rules.d/99-systemd.rules Reading rules file: /etc/udev/rules.d/99-vmware-scsi-timeout.rules Reading rules file: /usr/lib/udev/rules.d/99-vmware-scsi-udev.rules rules contain 393216 bytes tokens (32768 * 12 bytes), 42737 bytes strings 47314 strings (385038 bytes), 43286 de-duplicated (346330 bytes), 4029 trie nodes used GROUP 6 /usr/lib/udev/rules.d/50-udev-default.rules:53 IMPORT builtin 'usb_id' /usr/lib/udev/rules.d/56-hpmud.rules:10 unable to access usb_interface device of '/sys/block/sdb/sdb1' IMPORT builtin 'usb_id' returned non-zero LINK 'disk/by-path/pci-0000:03:00.0-scsi-0:0:1:0-part1' /usr/lib/udev/rules.d/60-persistent-storage.rules:71 IMPORT builtin 'blkid' /usr/lib/udev/rules.d/60-persistent-storage.rules:89 probe /dev/sdb1 raid offset=0 LINK 'disk/by-label/DISK01' /usr/lib/udev/rules.d/60-persistent-storage.rules:96 RUN '/bin/sh -c 'echo 180 > /sys$DEVPATH/timeout'' /etc/udev/rules.d/99-vmware-scsi-timeout.rules:1 handling device node '/dev/sdb1', devnum=b8:17, mode=0660, uid=0, gid=6 preserve permissions /dev/sdb1, 060660, uid=0, gid=6 preserve already existing symlink '/dev/block/8:17' to '../sdb1' found 'b8:17' claiming '/run/udev/links/\x2fdisk\x2fby-label\x2fDISK01' creating link '/dev/disk/by-label/DISK01' to '/dev/sdb1' preserve already existing symlink '/dev/disk/by-label/DISK01' to '../../sdb1' found 'b8:17' claiming '/run/udev/links/\x2fdisk\x2fby-path\x2fpci-0000:03:00.0-scsi-0:0:1:0-part1' creating link '/dev/disk/by-path/pci-0000:03:00.0-scsi-0:0:1:0-part1' to '/dev/sdb1' preserve already existing symlink '/dev/disk/by-path/pci-0000:03:00.0-scsi-0:0:1:0-part1' to '../../sdb1' created db file '/run/udev/data/b8:17' for '/block/sdb/sdb1' .ID_FS_TYPE_NEW=oracleasm ACTION=add DEVLINKS=/dev/disk/by-label/DISK01 /dev/disk/by-path/pci-0000:03:00.0-scsi-0:0:1:0-part1 DEVNAME=/dev/sdb1 DEVPATH=/block/sdb/sdb1 DEVTYPE=partition ID_BUS=scsi ID_FS_LABEL=DISK01 ID_FS_LABEL_ENC=DISK01 ID_FS_TYPE=oracleasm ID_FS_USAGE=filesystem ID_MODEL=Virtual_disk ID_MODEL_ENC=Virtual\x20disk\x20\x20\x20\x20 ID_PART_ENTRY_DISK=8:16 ID_PART_ENTRY_NUMBER=1 ID_PART_ENTRY_OFFSET=2048 ID_PART_ENTRY_SCHEME=dos ID_PART_ENTRY_SIZE=1572861952 ID_PART_ENTRY_TYPE=0x83 ID_PART_TABLE_TYPE=dos ID_PATH=pci-0000:03:00.0-scsi-0:0:1:0 ID_PATH_TAG=pci-0000_03_00_0-scsi-0_0_1_0 ID_REVISION=2.0 ID_SCSI=1 ID_TYPE=disk ID_VENDOR=VMware ID_VENDOR_ENC=VMware\x20\x20 MAJOR=8 MINOR=17 SUBSYSTEM=block TAGS=:systemd: USEC_INITIALIZED=49234642 run: '/bin/sh -c 'echo 180 > /sys$DEVPATH/timeout'' Unload module index Unloaded link configuration context. 2-ой диск , норм прошел тест udevadm test /block/sdb/sdc1 calling: test version 219 This program is for debugging only, it does not run any program specified by a RUN key. It may show incorrect results, because some values may be different, or not available at a simulation run. === trie on-disk === tool version: 219 file size: 9013079 bytes header size 80 bytes strings 2306191 bytes nodes 6706808 bytes Load module index Created link configuration context. timestamp of '/etc/udev/rules.d' changed timestamp of '/usr/lib/udev/rules.d' changed Reading rules file: /usr/lib/udev/rules.d/01-md-raid-creating.rules Reading rules file: /usr/lib/udev/rules.d/10-dm.rules Reading rules file: /usr/lib/udev/rules.d/11-dm-lvm.rules Reading rules file: /usr/lib/udev/rules.d/11-dm-mpath.rules Reading rules file: /usr/lib/udev/rules.d/13-dm-disk.rules Reading rules file: /usr/lib/udev/rules.d/39-usbmuxd.rules Reading rules file: /usr/lib/udev/rules.d/40-libgphoto2.rules IMPORT found builtin 'usb_id --export %%p', replacing /usr/lib/udev/rules.d/40-libgphoto2.rules:11 Reading rules file: /usr/lib/udev/rules.d/40-redhat-disable-dell-ir-camera.rules Reading rules file: /usr/lib/udev/rules.d/40-redhat-disable-lenovo-ir-camera.rules Reading rules file: /usr/lib/udev/rules.d/40-redhat.rules Reading rules file: /usr/lib/udev/rules.d/40-usb_modeswitch.rules Reading rules file: /usr/lib/udev/rules.d/42-usb-hid-pm.rules Reading rules file: /usr/lib/udev/rules.d/50-rbd.rules Reading rules file: /usr/lib/udev/rules.d/50-udev-default.rules Reading rules file: /usr/lib/udev/rules.d/56-hpmud.rules Reading rules file: /usr/lib/udev/rules.d/60-alias-kmsg.rules Reading rules file: /usr/lib/udev/rules.d/60-cdrom_id.rules Reading rules file: /usr/lib/udev/rules.d/60-drm.rules Reading rules file: /usr/lib/udev/rules.d/60-evdev.rules Reading rules file: /usr/lib/udev/rules.d/60-fprint-autosuspend.rules Reading rules file: /usr/lib/udev/rules.d/60-keyboard.rules Reading rules file: /usr/lib/udev/rules.d/60-net.rules Reading rules file: /usr/lib/udev/rules.d/60-persistent-alsa.rules Reading rules file: /usr/lib/udev/rules.d/60-persistent-input.rules Reading rules file: /usr/lib/udev/rules.d/60-persistent-serial.rules Reading rules file: /usr/lib/udev/rules.d/60-persistent-storage-tape.rules Reading rules file: /usr/lib/udev/rules.d/60-persistent-storage.rules Reading rules file: /usr/lib/udev/rules.d/60-persistent-v4l.rules Reading rules file: /usr/lib/udev/rules.d/60-raw.rules Reading rules file: /usr/lib/udev/rules.d/60-rdma-ndd.rules Reading rules file: /usr/lib/udev/rules.d/60-srp_daemon.rules Reading rules file: /usr/lib/udev/rules.d/61-accelerometer.rules Reading rules file: /usr/lib/udev/rules.d/61-gdm.rules Reading rules file: /usr/lib/udev/rules.d/61-gnome-bluetooth-rfkill.rules Reading rules file: /usr/lib/udev/rules.d/61-gnome-settings-daemon-rfkill.rules Reading rules file: /usr/lib/udev/rules.d/62-multipath.rules Reading rules file: /usr/lib/udev/rules.d/63-fc-wwpn-id.rules Reading rules file: /usr/lib/udev/rules.d/63-md-raid-arrays.rules Reading rules file: /usr/lib/udev/rules.d/64-btrfs-dm.rules Reading rules file: /usr/lib/udev/rules.d/64-btrfs.rules Reading rules file: /usr/lib/udev/rules.d/65-libwacom.rules Reading rules file: /usr/lib/udev/rules.d/65-md-incremental.rules Reading rules file: /usr/lib/udev/rules.d/65-sane-backends.rules Reading rules file: /usr/lib/udev/rules.d/66-saned.rules Reading rules file: /usr/lib/udev/rules.d/69-cd-sensors.rules Reading rules file: /usr/lib/udev/rules.d/69-dm-lvm-metad.rules Reading rules file: /usr/lib/udev/rules.d/69-libmtp.rules Reading rules file: /usr/lib/udev/rules.d/69-md-clustered-confirm-device.rules Reading rules file: /etc/udev/rules.d/69-vdo-start-by-dev.rules Reading rules file: /usr/lib/udev/rules.d/69-xorg-vmmouse.rules Reading rules file: /usr/lib/udev/rules.d/70-hypervfcopy.rules Reading rules file: /usr/lib/udev/rules.d/70-hypervkvp.rules Reading rules file: /usr/lib/udev/rules.d/70-hypervvss.rules Reading rules file: /usr/lib/udev/rules.d/70-mouse.rules Reading rules file: /etc/udev/rules.d/70-persistent-ipoib.rules Reading rules file: /usr/lib/udev/rules.d/70-power-switch.rules Reading rules file: /usr/lib/udev/rules.d/70-printers.rules Reading rules file: /usr/lib/udev/rules.d/70-spice-vdagentd.rules Reading rules file: /usr/lib/udev/rules.d/70-touchpad-quirks.rules Reading rules file: /usr/lib/udev/rules.d/70-touchpad.rules Reading rules file: /usr/lib/udev/rules.d/70-uaccess.rules Reading rules file: /usr/lib/udev/rules.d/70-wacom.rules Reading rules file: /usr/lib/udev/rules.d/71-biosdevname.rules Reading rules file: /usr/lib/udev/rules.d/71-seat.rules Reading rules file: /usr/lib/udev/rules.d/73-idrac.rules Reading rules file: /usr/lib/udev/rules.d/73-seat-late.rules Reading rules file: /usr/lib/udev/rules.d/75-net-description.rules Reading rules file: /usr/lib/udev/rules.d/75-probe_mtd.rules Reading rules file: /usr/lib/udev/rules.d/75-rdma-description.rules Reading rules file: /usr/lib/udev/rules.d/75-tty-description.rules Reading rules file: /usr/lib/udev/rules.d/76-phys-port-name.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-cinterion-port-types.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-dell-port-types.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-ericsson-mbm.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-haier-port-types.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-huawei-net-port-types.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-longcheer-port-types.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-mtk-port-types.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-nokia-port-types.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-pcmcia-device-blacklist.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-simtech-port-types.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-telit-port-types.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-usb-device-blacklist.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-usb-serial-adapters-greylist.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-x22x-port-types.rules Reading rules file: /usr/lib/udev/rules.d/77-mm-zte-port-types.rules Reading rules file: /usr/lib/udev/rules.d/78-sound-card.rules Reading rules file: /usr/lib/udev/rules.d/80-drivers.rules Reading rules file: /usr/lib/udev/rules.d/80-kvm.rules Reading rules file: /usr/lib/udev/rules.d/80-libinput-device-groups.rules Reading rules file: /usr/lib/udev/rules.d/80-mm-candidate.rules Reading rules file: /usr/lib/udev/rules.d/80-net-name-slot.rules Reading rules file: /usr/lib/udev/rules.d/80-net-setup-link.rules Reading rules file: /usr/lib/udev/rules.d/80-udisks2.rules Reading rules file: /usr/lib/udev/rules.d/81-kvm-rhel.rules Reading rules file: /usr/lib/udev/rules.d/84-nm-drivers.rules Reading rules file: /usr/lib/udev/rules.d/85-nm-unmanaged.rules Reading rules file: /usr/lib/udev/rules.d/85-regulatory.rules Reading rules file: /usr/lib/udev/rules.d/89-alsa-ucm.rules Reading rules file: /usr/lib/udev/rules.d/90-alsa-restore.rules Reading rules file: /usr/lib/udev/rules.d/90-alsa-tools-firmware.rules Reading rules file: /usr/lib/udev/rules.d/90-bolt.rules Reading rules file: /usr/lib/udev/rules.d/90-fwupd-devices.rules Reading rules file: /usr/lib/udev/rules.d/90-iprutils.rules Reading rules file: /usr/lib/udev/rules.d/90-iwpmd.rules Reading rules file: /usr/lib/udev/rules.d/90-libinput-model-quirks.rules Reading rules file: /usr/lib/udev/rules.d/90-nm-thunderbolt.rules Reading rules file: /usr/lib/udev/rules.d/90-pulseaudio.rules Reading rules file: /usr/lib/udev/rules.d/90-rdma-hw-modules.rules Reading rules file: /usr/lib/udev/rules.d/90-rdma-ulp-modules.rules Reading rules file: /usr/lib/udev/rules.d/90-rdma-umad.rules Reading rules file: /usr/lib/udev/rules.d/90-spice-guest-streaming.rules Reading rules file: /usr/lib/udev/rules.d/90-vconsole.rules Reading rules file: /usr/lib/udev/rules.d/91-drm-modeset.rules Reading rules file: /usr/lib/udev/rules.d/95-cd-devices.rules Reading rules file: /usr/lib/udev/rules.d/95-dm-notify.rules Reading rules file: /usr/lib/udev/rules.d/95-udev-late.rules Reading rules file: /usr/lib/udev/rules.d/95-upower-csr.rules Reading rules file: /usr/lib/udev/rules.d/95-upower-hid.rules Reading rules file: /usr/lib/udev/rules.d/95-upower-wup.rules Reading rules file: /usr/lib/udev/rules.d/98-kexec.rules Reading rules file: /usr/lib/udev/rules.d/98-rdma.rules Reading rules file: /usr/lib/udev/rules.d/99-qemu-guest-agent.rules Reading rules file: /usr/lib/udev/rules.d/99-systemd.rules Reading rules file: /etc/udev/rules.d/99-vmware-scsi-timeout.rules Reading rules file: /usr/lib/udev/rules.d/99-vmware-scsi-udev.rules rules contain 393216 bytes tokens (32768 * 12 bytes), 42737 bytes strings 47314 strings (385038 bytes), 43286 de-duplicated (346330 bytes), 4029 trie nodes used unable to open device '/sys/block/sdb/sdC1' Unload module index Unloaded link configuration context. Что не так с /dev/sdb1 ? Спасибо ... |
| 01.10.2021, 13:24:24 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1879857]: |
209ms |
26ms |
| others: | 266ms |
| total: | 552ms |
