Can't allocate space for object 'Syslogs' in database 'RKOtest' because the 'log
Помогите справиться с ошибкой Can't allocate space for object 'Syslogs' in database 'RKOtest' because the 'logsegment' segment is full. If you ran out of space in Syslogs, dump the transaction log. Otherwise, use ALTER DATABASE or sp_extendsegment to increase the size of the segment. Если нельзя выделить больше места Sql 6.5 ... |
| 25.11.2002, 14:10:51 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1818528]: |
42ms |
27ms |
| others: | 203ms |
| total: | 314ms |
