GROUP BY
Добрый день всем! Хотел объединить все одинаковые строки (например: все строки Александр Пушкин Сергеевич хочу объединить) не смог, помогите пожалуйста. Заранее спасибо ЗАПРОС: SELECT tbl.lastName, tbl.firstName, tbl.middleName, tbl.birthYear, tbl.Telefon, tbl.diagnoz, tbl.Address, tbl.lpu_name, tbl.GrupBlood, tbl.id, SUM(tbl.dose) as dose, SUM(tbl.SZPvolume) as SZPvolume, SUM(tbl.ERZvolume) as ERZvolume, SUM(tbl.OTMITIvolume) as OTMITIvolume, SUM(tbl.TMdose) as TMdose, SUM(tbl.CNPvolume) as CNPvolume, MONTH(tbl.ProcessEnd) as ProcessEnd, YEAR(tbl.ProcessEnd) as GOD FROM ( SELECT RP.lastName, RP.firstName, RP.middleName, RP.birthYear as birthYear, RP.idNumber as Telefon, RP.comment as diagnoz, Ad.visibleName as Address, lpu.id as id, Cast(pr.endDate as Date) as ProcessEnd, CASE WHEN lpu.id in (2164530) THEN 111 WHEN lpu.id in (175156057) THEN 222 ELSE 333 END as lpu_name, CASE WHEN A.id in (225038) THEN CCV.name END as GrupBlood, CASE WHEN pt.id in (11450,224786,158635140) THEN 1 ELSE 0 END as dose, CASE WHEN pt.id in (11444,238156,380903) THEN p.volume ELSE 0 END as SZPvolume, CASE WHEN pt.id in (223671,379098,87912287,224759,224765) THEN p.volume ELSE 0 END as ERZvolume, CASE WHEN pt.id in (224762) THEN p.volume ELSE 0 END as OTMITIvolume, CASE WHEN pt.id in (11447,238216,158633675) THEN 1 ELSE 0 END as TMdose, CASE WHEN pt.id in (378960,158635096) THEN p.volume ELSE 0 END as CNPvolume FROM Conversion pr Join Conversion_Unit pp on pp.ConversionId = pr.id Join Unit p on p.id = pp.UnitId Join UnitType pt on pt.id=p.UnitTypeId Left Join Recipient RP on RP.id = pr.RecipientId Join Customer lpu on lpu.id=pr.CustomerId Join Address Ad on Ad.id=RP.LivingAddressId Join AntigenValue AV on AV.RecipientId=RP.id Join Antigen A on A.id=AV.AntigenId Join CustomCatalogValue CCV on CCV.id=AV.CustomCatalogValueId Where pr.ConversionRuleId in (348691,15450246,15474394) and pr.endDate between '@sdate' and '@edate 23:59:59' ) AS tbl WHERE tbl.GrupBlood is not null GROUP BY tbl.lastName, tbl.firstName, tbl.middleName, tbl.birthYear, tbl.Telefon, tbl.diagnoz, tbl.Address, tbl.GrupBlood, tbl.lpu_name, tbl.id, tbl.ProcessEnd ORDER BY tbl.lpu_name ... |
| 20.07.2019, 08:47 |
GROUP BY
IKT_TUT, На вскидку в GROUP BY добавить Код: sql 1. 2. ... |
| 20.07.2019, 09:04 |
GROUP BY
IKT_TUTне работает)Ошибка "не работаю"? Пишите про требуемые и фактические данные более подробно, ну и про ошибки. Вообще, тут всё должно быть просто - те поля, по которым делается агрегация, указываются в GROUP BY, а остальные поля должны использоваться в SELECT в агрегатных функциях. ... |
| 20.07.2019, 10:46 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1687524]: |
147ms |
62ms |
| others: | 204ms |
| total: | 461ms |
