После обновления не стартует SQL
Есть MS SQL 2017 Standard RTM 14.0.1000.169, была проблема с SQL VSS Writer, из-за чего сервак не мог забэкапиться.. Решили накатить обновления для SQL, после CU 1 для SQL Server 2017 RTM (KB4038634), служба сервера не запускается. В еррор логе ошибка: 2019-09-19 10:28:21.87 spid11s Uploading data collector package from disk: C:\Program Files\Microsoft SQL Server\MSSQL14.MSSQLSERVER\MSSQL\Install\SqlTraceCollect.dtsx 2019-09-19 10:28:21.87 spid11s Error: 4860, Severity: 16, State: 1. 2019-09-19 10:28:21.87 spid11s Cannot bulk load. The file "C:\Program Files\Microsoft SQL Server\MSSQL14.MSSQLSERVER\MSSQL\Install\SqlTraceCollect.dtsx" does not exist or you don't have file access rights. 2019-09-19 10:28:21.87 spid11s Error: 912, Severity: 21, State: 2. 2019-09-19 10:28:21.87 spid11s Script level upgrade for database 'master' failed because upgrade step 'msdb110_upgrade.sql' encountered error 200, state 7, severity 25. This is a serious error condition which might interfere with regular operation and the database will be taken offline. If the error happened during upgrade of the 'master' database, it will prevent the entire SQL Server instance from starting. Examine the previous errorlog entries for errors, take the appropriate corrective actions and re-start the database so that the script upgrade steps run to completion. 2019-09-19 10:28:21.87 spid11s Error: 3417, Severity: 21, State: 3. 2019-09-19 10:28:21.87 spid11s Cannot recover the master database. SQL Server is unable to run. Restore master from a full backup, repair it, or rebuild it. For more information about how to rebuild the master database, see SQL Server Books Online. 2019-09-19 10:28:21.87 spid11s SQL Server shutdown has been initiated 2019-09-19 10:28:21.87 spid11s SQL Trace was stopped due to server shutdown. Trace ID = '1'. This is an informational message only; no user action is required. 2019-09-19 10:28:22.88 spid11s Error: 25725, Severity: 16, State: 1. 2019-09-19 10:28:22.88 spid11s An error occurred while trying to flush all running Extended Event sessions. Some events may be lost. Резервной копии master нет, как и теневых копий, бэкапы только пользовательских баз. Что посоветуете, как запустить или только полная переустановка? ... |
| 19.09.2019, 09:18 |
rahzer, пробуйте стартовать с TF 902 ... |
| 19.09.2019, 09:21 |
rahzerЧто посоветуете, как запустить или только полная переустановка?Так может, дать права на этот SqlTraceCollect.dtsx, или на всю папку? ... |
| 19.09.2019, 09:26 |
alexeyvg, Давал на всю папку - не помогло. Файла такого в папке нет..( ... |
| 19.09.2019, 09:34 |
TaPaKrahzer, пробуйте стартовать с TF 902 Запустилось. Дальнейшие рекомендации по восстановлению будут или так оставлять? ... |
| 19.09.2019, 09:51 |
rahzerTaPaKrahzer, пробуйте стартовать с TF 902 Запустилось. Дальнейшие рекомендации по восстановлению будут или так оставлять? ну пробовать что не получилось ... |
| 19.09.2019, 10:00 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1687261]: |
397ms |
47ms |
| others: | 238ms |
| total: | 730ms |
