Инициализация сервера (первый опыт)
ОС - Microsoft Windows Server 2003 R2 Standart Edition SP2, IDS 9.4 - только что проинсталеный, oninit -ivy - работает уже 6 часов, вот что я вижу все это время: C:\Informix>oninit -ivy Checking group membership to determine server run modesucceeded Reading configuration file 'C:\Informix/etc/ONCONFIG.ol_newodg'...succeeded Creating INFXTMP/.infxdirs ... succeeded Creating infos file "C:\Informix/etc/.infos.ol_newodg" ... "C:\Informix/etc/.con f.ol_newodg" ... succeededage select=1251 Writing to infos file ... succeeded Checking config parameters...succeeded Allocating and attaching to shared memory...succeeded Creating resident pool 179368 kbytes...succeeded Creating buffer pool 320004 kbytes...succeeded Initializing rhead structure...succeeded Initializing ASF ...succeeded Initializing Dictionary Cache and SPL Routine Cache...succeeded Bringing up ADM VP...succeeded Creating VP classes...succeeded Onlining 7 additional cpu vps...succeeded Onlining 1 IO vps...succeeded for INFORMIXSERVER 'ol_newodg' Initialization of Encryption...succeeded Forking main_loop thread...succeeded Initializing DR structures...succeeded Forking 1 'soctcp' listener threads...succeeded Starting tracing...succeeded Initializing 1 flushers...succeeded Initializing log/checkpoint information...succeeded Opening primary chunks...succeeded Opening mirror chunks...succeeded Initializing dbspaces...succeeded Validating chunks...succeeded Creating database partition Initialize Async Log Flusher...succeeded Forking btree cleaner...succeeded Initializing DBSPACETEMP list Checking database partition index...succeeded Checking location of physical log...succeeded Initializing dataskip structure...succeeded Checking for temporary tables to drop Forking onmode_mon thread...succeeded Verbose output complete: mode = 5 Есть два (пока) вопроса: 1. Сколько ЭТО будет продолжаться? 2. Где посмотреть, что именно происходит? (в Диспетчере задач видно, что oninit что-то все-таки читает, и что-то пишет. Но ЧТО?) ... |
| 22.04.2008, 18:22 |
Вообще-то он у вас работает. Если вам надоело это дело, то дайте в консоле onmode -k, только не забудьте перед этим настроить среду, выполнив в консоле c:\informix\ol_newodg.cmd ... |
| 22.04.2008, 22:22 |
Файл с логом можно почитать в каталоге c:\informix (у него расширение log). Можете в консоле попускать onstat, dbaccess или начать уже создавать dbspace-ы. ... |
| 22.04.2008, 22:25 |
Вообщето когда он у вас написал строку ... Verbose output complete: mode = 5 это значит что он проинициализировался и уже работает. ... |
| 23.04.2008, 08:51 |
Чтобы не висел в консоле под виндой и запускаю так starts ol_newodg ... |
| 23.04.2008, 10:36 |
Большое всем спасибо ... |
| 23.04.2008, 12:10 |
Имейте только ввиду, что запустив еще раз oninit -ivy вы убьете все, что сделали до этого на сервере (если вы создавали и загружали базы, создавали новые ДБ-пространства и т.п.) Эта команда нужна ТОЛЬКО для первой инициализации дискового пространства сервера. Под Виндовс сервер Инофрмикс должен запускаться как служба (service) и никак иначе. starts <имя сервера Информикс> или net start <имя сервера Информикс> ... |
| 23.04.2008, 15:32 |
start [/forum/search_topic.php?author=cdrem&author_mode=last_topics&do_search=1]: |
48ms |
41ms |
| others: | 645ms |
| total: | 800ms |
