Informix Feature List
FYI ... Informix Feature List - http://www.iiug.org/library/ids_11/technical/FeatureList3.pdf Quick Reference: Configuration Parameters in the onconfig.std File - http://www.iiug.org/library/ids_11/technical/onconfigQRC.pdf Quick Reference: onstat Utility Commands Sorted by Functional Category - http://www.iiug.org/library/ids_11/technical/onstatQRC.pdf Kind regards, Vadim Golovsky. ... |
| 17.06.2011, 09:07 |
start [/forum/topic.php?fid=44&gotonew=1&tid=1607331]: |
74ms |
43ms |
| others: | 234ms |
| total: | 398ms |
