думаю что повторюсь но shared memory no initialized for INFORMIXSERVER
Поставил информикс 11.5 но при выполнении onstat - выдает ошибку shared memory no initialized for INFORMIXSERVER 'ol_svr_custom' при выполнении oninit -v выдает: Checking group membership to determine server run mode...succeeded Reading configuration file 'C:\PROGRA~1\ibm\IBMINF~1\11.50/etc/ONCONFIG.ol_svr_custom'...succeeded Creating infos file "C:\PROGRA~1\ibm\IBMINF~1\11.50/etc/.infos.ol_svr_custom"...succeeded Linking conf file "C:\PROGRA~1\ibm\IBMINF~1\11.50/etc/.conf.ol_svr_custom"...succeeded Checking config parameters...succeeded Writing to infos file...succeeded Allocating and attaching to shared memory...succeeded Creating resident pool 4928 kbytes...succeeded Allocating 40016 kbytes for buffer pool of 4K page size...succeeded Initializing rhead structure...succeeded Initialization of Encryption...succeeded Initializing ASF...succeeded Initializing Dictionary Cache and SPL Routine Cache...succeeded Bringing up ADM VP...succeeded Creating VP classes...succeeded Onlining 0 additional cpu vps...succeeded Onlining 1 IO vps...succeeded Forking main_loop thread...succeeded Initializing DR structures...succeeded Forking 1 'soctcp' listener threads...succeeded Forking 1 'soctcp' listener threads...succeeded Starting tracing...succeeded Initializing 8 flushers...succeeded лог сервера: 14:59:56 Warning: ONCONFIG dump directory (DUMPDIR) 'C:\PROGRA~1\ibm\IBMINF~1\11.50\tmp' has insecure permissions 14:59:56 Booting Language <c> from module <> 14:59:56 Loading Module <CNULL> 14:59:56 Booting Language <builtin> from module <> 14:59:56 Loading Module <BUILTINNULL> 14:59:56 Could not disable priority aging: errno = 0 15:00:01 DR: DRAUTO is 0 (Off) 15:00:01 DR: ENCRYPT_HDR is 0 (HDR encryption Disabled) 15:00:01 IBM Informix Dynamic Server Version 11.50.TC1 Software Serial Number AAA#B000000 15:00:02 KAIO: error in kaio_READ, kaiocbp = 0xeec1818, errno = 0 15:00:02 fildes = 1692 (gfd 3), buf = 0x0F1AD400, nbytes = 4096, offset = 8192 15:00:02 Assert Warning: chunk failed sanity check 15:00:03 IBM Informix Dynamic Server Version 11.50.TC1 15:00:03 Who: Session(1, informix@informix, 0, 00000000) Thread(6, main_loop(), 0, 1) File: rspartn.c Line: 9291 15:00:03 Results: Chunk 1 is being taken OFFLINE. 15:00:03 Action: For all spaces other than temporary dbspaces, restore the space containing the chunk from the archive. If this chunk belongs to a temporary dbspace and if it is not the only chunk in that dbspace, then drop and re-create the chunk. Otherwise drop and re-create the temporary dbspace. 15:00:03 stack trace for pid 1028 written to C:\PROGRA~1\ibm\IBMINF~1\11.50\tmp\af.3ee55b2 15:00:03 See Also: C:\PROGRA~1\ibm\IBMINF~1\11.50\tmp\af.3ee55b2 15:00:04 Releasing server from system block 15:00:07 chunk failed sanity check 15:00:07 chunk failed sanity check 15:00:07 I/O error, Primary Chunk 'C:\IFMXDATA\ol_svr_custom\rootdbs_dat.000' -- Offline (sanity) 15:00:07 IBM Informix Dynamic Server Stopped. помогите исправить ошибки... ... |
| 14.09.2010, 16:22 |
а сервер рабочий или только установлен? Что произошло вообще? проблема в 15:00:07 I/O error, Primary Chunk 'C:\IFMXDATA\ol_svr_custom\rootdbs_dat.000' -- Offline (sanity) файл вообще такой есть? ... |
| 14.09.2010, 16:31 |
информикс только установлен, файл C:\IFMXDATA\ol_svr_custom\rootdbs_dat.000 есть... ... |
| 14.09.2010, 16:42 |
содержимое файла C:\PROGRA~1\ibm\IBMINF~1\11.50\tmp\af.3ee55b2 покажите ... |
| 14.09.2010, 16:48 |
а вообще, информикс хоть раз инициализировался на этой машине? ... |
| 14.09.2010, 16:49 |
| 14.09.2010, 16:55 |
да, но удалял его вместе с регистрами ... |
| 14.09.2010, 16:55 |
C:\PROGRA~1\ibm\IBMINF~1\11.50\bin\onstat -d: IBM Informix Dynamic Server Version 11.50.TC1 -- Initialization -- Up 00:00:08 -- 78208 Kbytes Dbspaces address number flags fchunk nchunks pgsize flags owner name 0 active, 2047 maximum Chunks address chunk/dbs offset size free bpages flags pathname 0EDD8970 1 0 0 51200 0 PO-- C:\IFMXDATA\ol_svr_custom\rootdbs_dat.000 1 active, 32766 maximum informix не инициализировался еще на этом сервере. т.е., если знаете что это такое, нужно выполнить oninit -i Если не знаете - то для начала посмотрите что это такое. ... |
| 14.09.2010, 18:42 |
Перед тем, как чинить Informix полечите диск: весьма озможно, что посыпалась файловая система. Перед тем, как дать oninit -i существующий чанк переименуйте, дождитесь завершения инициализации informix и только потом стирайте: это позволит избавится от проблемы, если она вызвана битым кластером. ... |
| 14.09.2010, 22:02 |
start [/forum/topic.php?fid=44&fpage=21&tid=1607492]: |
40ms |
57ms |
| others: | 204ms |
| total: | 351ms |
