ORACLE и WebSphere. Интеграция.
Добрый день. Какие есть способы взаимодействия? Как проще всего интегрировать? Буду благодарен за любую информацию и ссылки. ... |
| 20.01.2006, 09:19 |
What you mean WebSphere??? WebSphere is a brand. WebSphere Application Server is analog oracle application server WebSphere Customer Center like Oracle Data Hub WebSphere Product center it like some part of Retek WebSphere MQ is like Oracle AQ but much more prefomance and capabilities. WebSphere MessageBroker is a intergation engine based on MQ you recive message from some where and route this to application, files databases WebSphere Process Server like Message broker but different, I not expert and can't say where is a difference WebSphere portal - Portal application based on Application Server WebSphere DataStage - ETL (Extract transform Load) .... All of this work with oracle. What you mean integration???? :) ... |
| 20.01.2006, 18:37 |
MQ и Oracle ... |
| 23.01.2006, 12:17 |
Application Developer’s Guide - Fundamentals. Глава Working with Transaction Monitors with Oracle XA WebSphere(R) MQ System Administration Guide Chapter 11. Transactional support -> Oracle configuration ... |
| 23.01.2006, 17:34 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1605571]: |
49ms |
51ms |
| others: | 260ms |
| total: | 417ms |
