Backup Online DB2
Подскажите по восстановлению базы DB2 Имеем след параметры: db2 update database configuration for wash using LOGARCHMETH1 LOGRETAIN db2 get db cfg for wash | grep LOGARCH First log archive method (LOGARCHMETH1) = LOGRETAIN Options for logarchmeth1 (LOGARCHOPT1) = Second log archive method (LOGARCHMETH2) = OFF Options for logarchmeth2 (LOGARCHOPT2) = Делаем backup: db2 backup database wash online to /archive/wash/ compress Backup successful. The timestamp for this backup image is : 20170505130120 Восстанавливаем backup: db2 restore database wash from /archive/wash/ DB20000I The RESTORE DATABASE command completed successfully. При попытке соединения получаем такую ошибку: db2 connect to wash SQL1117N A connection to or activation of database "WASH" cannot be made because of ROLL-FORWARD PENDING. SQLSTATE=57019 Подскажите, что необходимо сделать (данные после начала backup нам не нужны) ... |
| 05.05.2017, 13:06:12 |
Backup Online DB2
Alexander Ivanov, Надо выполнить команду ниже и сделать то, что написано в ее выводе. db2 "? SQL1117N" ... |
| 05.05.2017, 13:46:11 |
Backup Online DB2
db2 "? SQL1117N" SQL1117N A connection to or activation of database "<name>" cannot be made because of ROLL-FORWARD PENDING. Explanation: The specified database is enabled for roll-forward recovery and it has been restored but not rolled forward. No connection was made. Federated system users: this situation can also be detected by the data source. User response: Roll forward the database or indicate that you do not wish to roll forward by using the ROLLFORWARD command. Note that if you do not roll forward the database, the records written since the last backup of the database will not be applied to the database. Federated system users: if necessary isolate the problem to the data source rejecting the request (see the Troubleshooting Guide for procedures to follow to identify the failing data source) and take recovery action appropriate to that data source to bring the data source to a point of consistency. sqlcode: -1117 sqlstate: 57019 ... |
| 05.05.2017, 13:58:04 |
Backup Online DB2
Возможно ли восстановление без логов в моём случае? ... |
| 05.05.2017, 15:18:46 |
Backup Online DB2
Alexander IvanovВозможно ли восстановление без логов в моём случае?Из онлайнового архива нельзя восстановиться без наката по логам. Вы должны накатиться хотя бы до точки во времени, соответствующей окончанию взятия архива. В онлайновый архив по-умолчанию включаются все необходимые логи для такого rollforward to end of backup. Вы можете извлечь их из архива, указав в команде restore опцию LOGS (т.е. извлечь только логи) и LOGTARGET (куда именно в файловой системе извлечь эти логи). Указанный путь вы можете использовать в команде rollforward. Если у вас есть и другие логи с номерами после этих извлеченных без пропусков нумерации, то вы можете накатываться и дальше (to end of logs или до желаемой точки). ... |
| 05.05.2017, 15:54:10 |
Backup Online DB2
Alexander Ivanov, db2 rollforward db mydb to end of backup and complete ... |
| 06.05.2017, 09:38:18 |
Backup Online DB2
Mark BarinsteinAlexander IvanovВозможно ли восстановление без логов в моём случае?Из онлайнового архива нельзя восстановиться без наката по логам. Подождите, а как же опция WITHOUT ROLLING FORWARD? ... |
| 10.05.2017, 10:35:12 |
Backup Online DB2
mahaon2000Подождите, а как же опция WITHOUT ROLLING FORWARD?Только для восстановления из offline архива. ... |
| 10.05.2017, 12:32:34 |
Backup Online DB2
упс, точно, извините, невнимательно прочел. ... |
| 10.05.2017, 14:26:25 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1600446]: |
445ms |
51ms |
| others: | 205ms |
| total: | 755ms |
