Проблемы с установкой VFP 9.0
Prerequisites - проходит нормально Непосредственная установка с ошибками: Setup Failed View error log View installation log View error log: [06/28/07,10:59:42] setup.exe: [2] ISetupComponent::Pre/Post/Install() failed in ISetupManager::InstallManagerHelper() [06/28/07,10:59:42] setup.exe: [2] Component error string not specified in ISetupManager::AddToActionResultCollection() ***EndOfSession*** View installation log .... .... .... [06/28/07,10:59:44] vs70uimgr: Entering RunningComponent() method. [06/28/07,10:59:44] Setup.exe: ISetupManager::RunInstallFromList(IP_POSTINSTALL) completed [06/28/07,10:59:44] Setup.exe: ISetupManager::RunInstallLists() completing [06/28/07,10:59:45] vs70uimgr: Entering RunningComponent() method. [06/28/07,10:59:45] VS70pgui: Failed to increment max steps for small progress. Logging as event not error ... noncritical. [06/28/07,10:59:45] Setup.exe: IsRunningUnattended [06/28/07,10:59:45] vs70uimgr: Entering DisplayFinal() method. [06/28/07,10:59:45] Setup.exe: GetGlobalCustomProperty({710A502B-4669-405C-A985-BA21545509BA}) [06/28/07,10:59:45] vs70uimgr: ISetupManager::GetGlobalCustomProperty() failed to find global prop in CUIMgr::GetGlobalProperty() [06/28/07,10:59:46] Setup.exe: GetGlobalCustomProperty({47EAF7DE-458C-4C05-B3E1-82B9C563679B}) [06/28/07,10:59:46] vs70uimgr: ISetupManager::GetGlobalCustomProperty() failed to find global prop in CUIMgr::GetGlobalProperty() [06/28/07,10:59:46] vs70uimgr: Entering Next() method. [06/28/07,10:59:46] VS70pgui: Entered CPageHeaderDynamic::OnShowWindow method [06/28/07,10:59:46] Setup.exe: GetGlobalCustomProperty({710A502B-4669-405C-A985-BA21545509BA}) [06/28/07,10:59:46] VS70pgui: ISetupManager::GetGlobalCustomProperty() failed to find global prop in CFinishPage::GetGlobalProperty() [06/28/07,10:59:46] Setup.exe: AddGlobalCustomProperty Подскажите в чем проблема ? ... |
| 28.06.2007, 11:46 |
Для правильного ответа на Ваш вопрос Вам надо указать следующее: - Версия ОС - Версия FoxPro - Ваши права на машине на которой Вы пытаетсь установит FoxPro (предпочтительно Administrator) ... |
| 28.06.2007, 12:08 |
Windows XP Права администратора Visual FoxPro 9.0 Причем на других компах устанавливается без проблем (причем там бесправные) ... |
| 28.06.2007, 12:20 |
start [/forum/topic.php?fid=41&gotonew=1&tid=1589081]: |
73ms |
42ms |
| others: | 228ms |
| total: | 390ms |
