Magic Quadrant for Cloud Database Management Systems 2024
#40140527
| 07.04.2025, 11:17 |
Market Definition/Description Gartner defines the market for cloud database management systems (DBMSs) as the market for software products that store and manipulate data and that are primarily delivered as software as a service (SaaS) in the cloud. Cloud DBMSs may optionally be capable of running on-premises, or in hybrid, multicloud or intercloud configurations. They can be used for transactional and/or analytical work. They may have features that enable them to participate in a wider data ecosystem. They typically persist data using proprietary components in a durable manner, enabling a full range of create, read, update and delete operations. всё описание по ссылке https://www.gartner.com/doc/reprints?id=1-2JRODSP8&ct=241220&st=sb ... |
| 07.04.2025, 11:18 |
start [/forum/topic.php?fid=35&gotonew=1&tid=2187233]: |
174ms |
47ms |
| others: | 242ms |
| total: | 508ms |
