Не могу послать почту командой mail
echo text | mail -s "subj" xxxx@vckp.spb.ru письмо не приходит. Результат: авторFrom MAILER-DAEMON Mon May 6 11:16:12 2013 Return-Path: <> X-Original-To: oracle@vckpeas1.vckp.ru Delivered-To: oracle@vckpeas1.vckp.ru Received: by vckpeas1.vckp.ru (Postfix) id 71B885C04D3; Mon, 6 May 2013 11:16:12 +0400 (MSD) Date: Mon, 6 May 2013 11:16:12 +0400 (MSD) From: MAILER-DAEMON@vckpeas1.vckp.ru (Mail Delivery System) Subject: Undelivered Mail Returned to Sender To: oracle@vckpeas1.vckp.ru Auto-Submitted: auto-replied MIME-Version: 1.0 Content-Type: multipart/report; report-type=delivery-status; boundary="553F35C04C3.1367824572/vckpeas1.vckp.ru" Message-Id: <20130506071612.71B885C04D3@vckpeas1.vckp.ru> Status: O This is a MIME-encapsulated message. --553F35C04C3.1367824572/vckpeas1.vckp.ru Content-Description: Notification Content-Type: text/plain; charset=us-ascii This is the mail system at host vckpeas1.vckp.ru. I'm sorry to have to inform you that your message could not be delivered to one or more recipients. It's attached below. For further assistance, please send mail to postmaster. If you do so, please include this problem report. You can delete your own text from the attached returned message. The mail system <xxxx@vckp.spb.ru>: Host or domain name not found. Name service error for name=vckp.spb.ru type=AAAA: Host found but no data record of requested type --553F35C04C3.1367824572/vckpeas1.vckp.ru Content-Description: Delivery report Content-Type: message/delivery-status Reporting-MTA: dns; vckpeas1.vckp.ru X-Postfix-Queue-ID: 553F35C04C3 X-Postfix-Sender: rfc822; oracle@vckpeas1.vckp.ru Arrival-Date: Mon, 6 May 2013 11:16:12 +0400 (MSD) Final-Recipient: rfc822; xxxx@vckp.spb.ru Action: failed Status: 5.4.4 Diagnostic-Code: X-Postfix; Host or domain name not found. Name service error for name=vckp.spb.ru type=AAAA: Host found but no data record of requested type --553F35C04C3.1367824572/vckpeas1.vckp.ru Content-Description: Undelivered Message Content-Type: message/rfc822 Return-Path: <oracle@vckpeas1.vckp.ru> Received: by vckpeas1.vckp.ru (Postfix, from userid 502) id 553F35C04C3; Mon, 6 May 2013 11:16:12 +0400 (MSD) Date: Mon, 06 May 2013 11:16:12 +0400 To: xxxx@vckp.spb.ru Subject: subj User-Agent: Heirloom mailx 12.4 7/29/08 MIME-Version: 1.0 Content-Type: text/plain; charset=us-ascii Content-Transfer-Encoding: 7bit Message-Id: <20130506071612.553F35C04C3@vckpeas1.vckp.ru> From: oracle@vckpeas1.vckp.ru text --553F35C04C3.1367824572/vckpeas1.vckp.ru-- You have mail in /var/spool/mail/oracle [oracle@vckpeas1 ~]$ mail set folder-hook-imap://user@host/INBOX=junkfilter Подозреваю, что до меня никто почту на сервере не использовал. Почтовых демонов на сервере нет. Администратор Linux уволился, я рута не имею, мне надо найти решение и послать его администратору, который сам ничего не знает. Что надо настроить и запустить? Помогите люди добрые. ... |
| 06.05.2013, 11:32:07 |
oc Linux ... |
| 06.05.2013, 11:33:49 |
Aliona, какие-то проблемы с DNS, который использует почтовый сервер. Попробуй на нём выполнить Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. ... |
| 06.05.2013, 11:59:09 |
$ cat /etc/hosts 127.0.0.1 localhost localhost.localdomain localhost4 localhost4.localdomain4 ::1 localhost localhost.localdomain localhost6 localhost6.localdomain6 $ ping vckp.spb.ru ping: unknown host vckp.spb.ru $ nslookup -type=MX vckp.spb.ru Server: 192.168.112.12 Address: 192.168.112.12#53 *** Can't find vckp.spb.ru: No answer ... |
| 06.05.2013, 12:15:24 |
Либо разбираться с разрешением DNS либо закрутить всю почту через Smart Relay Есть у вас почтарь в компании с SMTP открытым? Как релай прописать в постфиксе не знаю, а в сендмайле делается элементарно. ... |
| 06.05.2013, 13:30:56 |
ИхтиандрЛибо разбираться с разрешением DNS либо закрутить всю почту через Smart Relay Есть у вас почтарь в компании с SMTP открытым? Как релай прописать в постфиксе не знаю, а в сендмайле делается элементарно. Я к администрированию сетей, DNS и Линкусов отношения не имею. Мне надо послать заявку в соответствующий отдел, что нужно сделать, они сами без моей подсказки сделать ничего не могут. Не могли бы вы написать, как надо настроить sendmail, чтобы я могла написать официальную заявку. Они мне почту уже третью неделю настраивают. :( ... |
| 06.05.2013, 15:46:16 |
Так сказали же что вероятная проблема в ДНС. И этоавтор*** Can't find vckp.spb.ru: No answer тому подтверждение. Причины могут быть разные вплоть до закрытия 53 порта UDP файрволлом. А на сервере точно sendmail используется (а не какой-то другой МТА), или это всего лишь предположение? автор они сами без моей подсказки сделать ничего не могутГнать надо таких в шею ... |
| 06.05.2013, 16:29:01 |
AlionaНе могли бы вы написать, как надо настроить sendmail, чтобы я могла написать официальную заявку. Так у вас же Postfix? Настроить надо DNS на вашем хосте. /etc/resolv.conf search your.domain.name nameserver IP вашего первичного DNS сервера nameserver IP вашего вторичного DNS сервера Что вообще в этом файле у вас? ... |
| 06.05.2013, 16:51:47 |
автор/etc/resolv.conf В некоторых системах его нельзя править ручками - изменения затрутся после перезагрузки. В таком случае для правки может быть команда вроде resolvconf. Этот момент следует уточнить. ... |
| 06.05.2013, 23:47:44 |
ИхтиандрAlionaНе могли бы вы написать, как надо настроить sendmail, чтобы я могла написать официальную заявку. Так у вас же Postfix? Настроить надо DNS на вашем хосте. /etc/resolv.conf search your.domain.name nameserver IP вашего первичного DNS сервера nameserver IP вашего вторичного DNS сервера Что вообще в этом файле у вас? Стоп , стоп , стоп !!! Если у вас есть оракл на хосте, 7 раз подумайте , стоит ли доверять недостоверному NS. А то недай Бог . в v$session появистся левачееег ... |
| 07.05.2013, 00:57:06 |
Всем спасибо. Нашла линуксовый сервер на котором команда mail работает. Указала его админам для сравнения. После этого они наладили почту на нужном сервере, но естественно, не говорят, что сделали. ... |
| 07.05.2013, 11:14:51 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1482991]: |
37ms |
80ms |
| others: | 377ms |
| total: | 572ms |
