Почему уменьшается размер устройства подкачки на томе ZFS
Solaris 10 Установил утсройство подкачки: авторbash-3.00$ zfs create -V 64G rpool/swap2 bash-3.00$ swap -a /dev/zvol/dsk/rpool/swap2 bash-3.00$ df -h Filesystem size used avail capacity Mounted on /dev/dsk/c1t0d0s0 5,5G 4,7G 776M 87% / /devices 0K 0K 0K 0% /devices ctfs 0K 0K 0K 0% /system/contract proc 0K 0K 0K 0% /proc mnttab 0K 0K 0K 0% /etc/mnttab swap 65G 1,5M 21G 1% /etc/svc/volatile objfs 0K 0K 0K 0% /system/object /platform/SUNW,T5140/lib/libc_psr/libc_psr_hwcap2.so.1 5,5G 4,7G 776M 87% /platform/sun4v/lib/libc_psr.so.1 /platform/SUNW,T5140/lib/sparcv9/libc_psr/libc_psr_hwcap2.so.1 5,5G 4,7G 776M 87% /platform/sun4v/lib/sparcv9/libc_psr.so.1 fd 0K 0K 0K 0% /dev/fd swap 65G 7,6M 21G 1% /tmp swap 65G 40K 21G 1% /var/run /dev/dsk/c1t1d0s7 135G 127G 6,5G 96% /u0 /dev/dsk/c1t3d0s0 130G 101G 27G 79% /u2 /dev/dsk/c1t2d0s0 134G 103G 30G 78% /u1 /dev/dsk/c1t0d0s7 129G 104G 24G 82% /export/home /dev/dsk/c4t60A9800044314F6A523F444A4A322D52d0s2 492G 288G 199G 60% /u3 bash-3.00$ Но на другой день: авторbash-3.00$ df -h Filesystem size used avail capacity Mounted on /dev/dsk/c1t0d0s0 5,5G 4,7G 776M 87% / /devices 0K 0K 0K 0% /devices ctfs 0K 0K 0K 0% /system/contract proc 0K 0K 0K 0% /proc mnttab 0K 0K 0K 0% /etc/mnttab swap 21 G 1,5M 21G 1% /etc/svc/volatile objfs 0K 0K 0K 0% /system/object /platform/SUNW,T5140/lib/libc_psr/libc_psr_hwcap2.so.1 5,5G 4,7G 776M 87% /platform/sun4v/lib/libc_psr.so.1 /platform/SUNW,T5140/lib/sparcv9/libc_psr/libc_psr_hwcap2.so.1 5,5G 4,7G 776M 87% /platform/sun4v/lib/sparcv9/libc_psr.so.1 fd 0K 0K 0K 0% /dev/fd swap 21G 7,6M 21G 1% /tmp swap 21G 40K 21G 1% /var/run /dev/dsk/c1t1d0s7 135G 127G 6,5G 96% /u0 /dev/dsk/c1t3d0s0 130G 101G 27G 79% /u2 /dev/dsk/c1t2d0s0 134G 103G 30G 78% /u1 /dev/dsk/c1t0d0s7 129G 104G 24G 82% /export/home /dev/dsk/c4t60A9800044314F6A523F444A4A322D52d0s2 492G 288G 199G 60% /u3 bash-3.00$ Почему уменьшился SWAP и нужно ли с этим бороться? ... |
| 16.11.2013, 11:23:13 |
Прошу прощения сразу после установки было: авторbash-3.00$ df -h .............. swap 65G 1,5M 65G 1% /etc/svc/volatile swap 65G 7,6M 65G 1% /tmp swap 65G 40K 65G 1% /var/run .............. bash-3.00$ ... |
| 16.11.2013, 11:25:48 |
Потому что "df -h" показывает размер файловых систем (/etc/svc/volatile, /tmp и /var/run в этом примере), а не размер swap-устройств. В Solaris своп виртуальный, он запросто может быть и больше, чем суммарный объём swap-устройств). Используйте команду "swap -l". Вот, например, система со своп-устройством размером 2Гб и 8Гб оперативной памяти: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. ... |
| 16.11.2013, 14:00:12 |
А вот такую строку нужно ставить в /etc/vfstab ? автор/dev/zvol/dsk/rpool/swap2 - - swap - no - ... |
| 17.11.2013, 06:15:43 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1482731]: |
23ms |
82ms |
59ms |
| others: | 357ms |
| total: | 587ms |
