adaptec и vmWare
нашел pdf по установке adapteca на vmWare прошу обьясните где взять два .vib файла ? я их не нашел точнее нашел только один . Use the following procedure to install the . vib files for a VMware ESX 4.1 system only . The installation can be done on an ESX 4.1 console or from a remote system running a T elnet/SSH client. 1. Insert the Adaptec Installation DVD. 2. Mount the Adaptec Installation DVD. 3. Copy the following files to your local ESX 4.1 /tmp directory: • vmware-esx-provider-arcconf . vib • vmware-esx-provider-arcsmis.vib The arcconf . vib is for command line communication. The arcsmis.vib is for remote management communication. 4. Stop operations. /etc/init.d/./sfcbd-watchdog stop 5. Check for an existing installation of arcconf . esxupdate --vib-view query | grep arcconf 6. Remove the existing installation of arcconf . esxupdate -b < arcconf module name > --maintenancemode remove When the package is removed, you receive the message "The update completed successfully , but the system needs to be rebooted for the changes to be effective". 7. Check for an existing installation of arcsmis. esxupdate --vib-view query | grep arcsmis 8. Remove the existing installation of arcsmis. esxupdate -b < arcsmis module name > --maintenancemode remove When the package is removed, you receive the message "The update completed successfully , but the system needs to be rebooted for the changes to be effective." 9. Reboot the system. 10. Stop operations. /etc/init.d/./sfcbd-watchdog stop 11. Install the arcconf package. esxupdate -b /tmp/vmware-esx-provider-arcconf.vib --nodeps --nosigcheck --maintenancemode update When the package is installed, you receive the message "The update completed successfully , but the system needs to be rebooted for the changes to be effective." 12. Install the arcsmis package. esxupdate -b /tmp/vmware-esx-provider-arcsmis.vib --nodeps --nosigcheck --maintenancemode update When the package is installed, you receive the message "The update completed successfully , but the system needs to be rebooted for the changes to be effective." 13. Reboot the system. ... |
| 10.11.2014, 13:44:51 |
adaptec и vmWare
а нет извиняюсь вот нужная Installing on VMware ESXi 5.x Use the following procedure to install the . vib files for a VMware ESXi 5.x system only . The installation must be done from a remote system running a T elnet/SSH client. Use a terminal emulator to access the ESXi 5.x server remotely . 1. Insert the Adaptec Installation DVD. 2. Mount the Adaptec Installation DVD. 3. Copy the following files to your local ESXi 5.x /tmp directory: • vmware-esx-provider-arcconf . vib • vmware-esx-provider-arcsmis.vib The arcconf . vib is for command line communication. The arcsmis.vib is for remote management communication. 4. Stop operations. /etc/init.d/./sfcbd-watchdog stop 5. Check for existing installation of arcconf . esxcli software vib list | grep arcconf 6. Remove the existing arcconf package. esxcli software vib remove -n arcconf When the package is removed, you receive the message "Reboot Required: false." 7. Check for an existing installation of arcsmis. esxcli software vib list | grep arcsmis 8. Remove the existing arcsmis package. esxcli software vib remove -n arcsmis When the package is removed, you receive the message "Reboot Required: false." 9. Set the acceptance level if this is the first installation of arcconf and arcsmis: esxcli software acceptance set –-level=CommunitySupported 10. Install the arcconf package. esxcli software vib install --maintenance-mode --no-sig-check -v /tmp/vmware-esx-provider-arcconf.vib When the package is installed, you receive the message "Reboot Required: false." 11. Install the arcsmis package. esxcli software vib install --maintenance-mode --no-sig-check -v /tmp/vmware-esx-provider-arcsmis.vib When the package is installed, you receive the message "Reboot Required: false." 12. Reboot the system. ... |
| 10.11.2014, 14:31:32 |
adaptec и vmWare
Владимир, а где искали? И что за Adaptec, какая модель? ... |
| 17.11.2014, 08:48:23 |
adaptec и vmWare
Scott Tiger, Прошу прощения уже нашел , но теперь проблема следующая нужна с помощью программы кешмакс сделать из двух ссд дисков кеш для 5го рейда из 5 хдд по 3 тб ... |
| 17.11.2014, 09:40:12 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1482295]: |
27ms |
73ms |
25ms |
103ms |
| others: | 428ms |
| total: | 711ms |
