Ошибка синтаксиса MySQL?
masterdelphi Код: php 1. 2. ошибка: авторYou have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'key) VALUES ('user1','user1@gmail.com','usrpsw','0','0')' at line 1 поле key int(11) NULL(no) DEFAULT 0 ... |
| 24.04.2012, 16:02:37 |
Stasonix, даже если уберу кавычки: авторYou have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'key) VALUES ('user1','user1@gmail.com','usrpsw','0',0)' at line 1 ... |
| 24.04.2012, 16:07:47 |
Stasonix, после этой сроки сделайте var_dump($sql); ... |
| 24.04.2012, 16:21:09 |
Stasonixmasterdelphi Код: php 1. 2. ошибка: авторYou have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'key) VALUES ('user1','user1@gmail.com','usrpsw','0','0')' at line 1 поле key int(11) NULL(no) DEFAULT 0 ... |
| 24.04.2012, 16:29:16 |
start [/forum/topic.php?fid=23&gotonew=1&tid=1465242]: |
211ms |
37ms |
| others: | 226ms |
| total: | 530ms |
