(javascript) ne date()
делаю: Код: plaintext 1. Код: plaintext ... |
| 02.06.2008, 10:58 |
Читай про Date. Месяца-то от нуля нумеруются! ... |
| 02.06.2008, 11:56 |
правильно 31 июня = 1 июля =) месяцы считаются с 0. и осторожно с ведущими нулями! С нуля начинаются восьмеричные числа ... |
| 02.06.2008, 11:57 |
ShSergeЧитай про Date. Месяца-то от нуля нумеруются! А дни с единицы. доки Date Object Enables basic storage and retrieval of dates and times. dateObj = new Date() dateObj = new Date(dateVal) dateObj = new Date(year, month, date[, hours[, minutes[, seconds[,ms]]]]) Arguments dateObj Required. The variable name to which the Date object is assigned. dateVal Required. If a numeric value, dateVal represents the number of milliseconds in Universal Coordinated Time between the specified date and midnight January 1, 1970. If a string, dateVal is parsed according to the rules in the parse method. The dateVal argument can also be a VT_DATE value as returned from some ActiveX® objects. year Required. The full year, for example, 1976 (and not 76). month Required. The month as an integer between 0 and 11 (January to December). date Required. The date as an integer between 1 and 31. hours Optional. Must be supplied if minutes is supplied. An integer from 0 to 23 (midnight to 11pm) that specifies the hour. minutes Optional. Must be supplied if seconds is supplied. An integer from 0 to 59 that specifies the minutes. seconds Optional. Must be supplied if milliseconds is supplied. An integer from 0 to 59 that specifies the seconds. ms Optional. An integer from 0 to 999 that specifies the milliseconds. ... |
| 02.06.2008, 15:29 |
krvsaА дни с единицы. А нулевой день - последний день предыдущего месяца ... |
| 02.06.2008, 15:33 |
start [/forum/topic.php?fid=22&gotonew=1&tid=1456398]: |
172ms |
41ms |
| others: | 206ms |
| total: | 466ms |
