Не парсится JSON
Имеется json подобный: Код: javascript 1. пытаюсь парсить так: Код: javascript 1. получаю ошибку авторVM395:1 Uncaught SyntaxError: Unexpected number В чём ошибка?? ... |
| 31.03.2016, 08:39 |
Не парсится JSON
Areostarполучаю ошибку авторVM395:1 Uncaught SyntaxError: Unexpected number В чём ошибка?? Приведенные тобой данные корректны. Все работает... <!DOCTYPE html> <html> <head> <meta http-equiv='Content-Type' content='text/html; charset=windows-1251' /> <script src='http://code.jquery.com/jquery-latest.js'></script> <!-- <script src=" https://code.angularjs.org/1.3.9/angular.min.js"></script> <script src=" https://code.angularjs.org/1.3.9/angular-route.js"></script> --> <style type='text/css'> </style> <script type='text/javascript'> var str='[["2016-03-31 05:33:45","0.73905"],["2016-03-31 05:33:46","0.739045"],["2016-03-31 05:33:47","0.739045"],["2016-03-31 05:33:48","0.739045"],["2016-03-31 05:33:49","0.739045"],["2016-03-31 05:33:50","0.73904"],["2016-03-31 05:33:51","0.738995"],["2016-03-31 05:33:52","0.738995"],["2016-03-31 05:33:53","0.73904"],["2016-03-31 05:33:54","0.73904"],["2016-03-31 05:33:55","0.73898"],["2016-03-31 05:33:56","0.73898"],["2016-03-31 05:33:57","0.73898"],["2016-03-31 05:33:58","0.73898"],["2016-03-31 05:33:59","0.73898"],["2016-03-31 05:34:00","0.73898"],["2016-03-31 05:34:01","0.73898"],["2016-03-31 05:34:02","0.73898"],["2016-03-31 05:34:03","0.73898"],["2016-03-31 05:34:04","0.73898"],["2016-03-31 05:34:05","0.738975"],["2016-03-31 05:34:06","0.738975"],["2016-03-31 05:34:07","0.738975"],["2016-03-31 05:34:08","0.738975"],["2016-03-31 05:34:09","0.738975"],["2016-03-31 05:34:10","0.738975"],["2016-03-31 05:34:11","0.73898"],["2016-03-31 05:34:12","0.73898"],["2016-03-31 05:34:13","0.73898"],["2016-03-31 05:34:14","0.73898"],["2016-03-31 05:34:15","0.738975"],["2016-03-31 05:34:16","0.738975"],["2016-03-31 05:34:17","0.738975"],["2016-03-31 05:34:18","0.738975"],["2016-03-31 05:34:19","0.738975"],["2016-03-31 05:34:20","0.738975"],["2016-03-31 05:34:21","0.738965"],["2016-03-31 05:34:22","0.738965"],["2016-03-31 05:34:23","0.738965"],["2016-03-31 05:34:24","0.738965"],["2016-03-31 05:34:25","0.73896"],["2016-03-31 05:34:26","0.73896"],["2016-03-31 05:34:27","0.73896"],["2016-03-31 05:34:28","0.73896"],["2016-03-31 05:34:29","0.73896"],["2016-03-31 05:34:30","0.73896"],["2016-03-31 05:34:31","0.738955"],["2016-03-31 05:34:32","0.738955"],["2016-03-31 05:34:33","0.73896"],["2016-03-31 05:34:34","0.73896"],["2016-03-31 05:34:35","0.73896"],["2016-03-31 05:34:36","0.738985"],["2016-03-31 05:34:37","0.738985"],["2016-03-31 05:34:38","0.738985"],["2016-03-31 05:34:39","0.738985"],["2016-03-31 05:34:40","0.738985"],["2016-03-31 05:34:41","0.738985"],["2016-03-31 05:34:42","0.738985"],["2016-03-31 05:34:43","0.738975"],["2016-03-31 05:34:44","0.73897"],["2016-03-31 05:34:45","0.738975"]]'; var a=$.parseJSON(str); alert(a.length); </script> </head> <body> </body> </html> ... |
| 31.03.2016, 09:06 |
Не парсится JSON
Код: javascript 1. 2. 3. 4. 5. 6. 7. 8. странно но в алерте получаю данные через запятую и без [ ] ???? Может запрашиваю не так? ... |
| 31.03.2016, 09:10 |
Не парсится JSON
Areostar Код: javascript 1. При таком варианте ты сразу должен получать JS массив или объект, а не строчку... ... |
| 31.03.2016, 09:12 |
Не парсится JSON
Areostarстранно но в алерте получаю данные через запятую и без [ ] ???? Так? Код: html 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. ... |
| 31.03.2016, 09:14 |
start [/forum/topic.php?fid=22&gotonew=1&tid=1445335]: |
68ms |
56ms |
| others: | 236ms |
| total: | 411ms |
