powered by simpleCommunicator - 2.0.59     © 2026 Programmizd 02
Форумы / WPF, Silverlight [игнор отключен] [закрыт для гостей] / button tamplate
2 сообщений из 2, страница 1 из 1
button tamplate
    #37452789
AneP
Доброе утро. Помогите навичку!
Есть темплэйт кнопки, нужно при нажатии кнопки что бы появлялся другой Path, подскажите как это реализовать. Заранее всем благодарен.
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
    <Style x:Key="btnPlay" TargetType="{x:Type Button}">
        <Setter Property="Template">
            <Setter.Value>
                <ControlTemplate TargetType="{x:Type Button}">
                    <Grid>
                        <Viewbox Stretch="Fill">
                            <Canvas x:Name="play" UseLayoutRounding="False" Height="68" Width="67">
                                <Path Data="F1M8.2178,29.4941C8.1578,26.4131,8.0978,23.3331,8.0848,20.1711C8.0758,20.0141,8.0748,19.8521,8.0838,19.6911C8.3908,14.1241,11.8158,12.2981,16.6418,12.5641C22.1048,12.8661,29.8068,16.9751,33.5988,18.9971C33.8418,19.1271,34.0628,19.2451,34.7708,19.6111C35.9898,20.2401,37.8638,21.0551,40.0098,21.9861C49.0658,25.9211,62.1878,31.6221,61.5508,39.3511C61.5238,39.7891,61.4288,40.2301,61.2588,40.6611C59.9838,43.8821,54.0908,46.1461,47.3298,48.7431C40.7598,51.2661,33.1628,54.1841,31.3058,56.5591C27.5518,61.3631,21.4318,60.9991,16.4388,60.7021C15.4948,60.6461,14.5998,60.5921,14.0718,60.5871C8.5878,60.5371,7.0788,58.3321,7.1108,54.7501C7.1208,53.5981,7.3868,52.7011,7.6858,51.6971C7.8678,51.0821,8.0748,50.3891,8.1018,49.8981C8.4808,43.0461,8.3488,36.2661,8.2178,29.4941 M16.5608,21.0681C16.5808,23.7931,16.6348,26.5771,16.6878,29.3611C16.8238,36.3541,16.9598,43.3561,16.5718,50.3631C16.5348,51.0291,16.4448,51.6361,16.3268,52.1961L16.9378,52.2311C19.9418,52.4111,23.6248,52.6301,24.6288,51.3441C27.9248,47.1291,36.7098,43.7551,44.3068,40.8371C48.0478,39.4001,51.3258,38.3481,52.6858,37.8431C50.7808,35.9111,42.5318,32.3281,36.6208,29.7601C34.3148,28.7581,32.3008,27.8831,30.8848,27.1511C30.8338,27.1261,30.3308,26.8551,29.6128,26.4721C26.4858,24.8041,20.2428,21.4741,16.5608,21.0681" Fill="#FFD1D1D1" Height="48.316" Canvas.Left="7.11" Stretch="Fill" Canvas.Top="12.539" Width="54.463"/>
                                <Path Data="F1M8.2178,24.5093C8.1578,21.4283,8.0978,18.3483,8.0848,15.1873C8.0758,15.0293,8.0748,14.8683,8.0838,14.7063C8.3908,9.1393,11.8158,7.3133,16.6418,7.5793C22.1048,7.8813,29.8068,11.9903,33.5988,14.0123C33.8418,14.1423,34.0628,14.2603,34.7708,14.6263C35.9898,15.2563,37.8638,16.0703,40.0098,17.0023C49.0658,20.9363,62.1878,26.6373,61.5508,34.3663C61.5238,34.8043,61.4288,35.2453,61.2588,35.6763C59.9838,38.8973,54.0908,41.1613,47.3298,43.7583C40.7598,46.2813,33.1628,49.1993,31.3058,51.5743C27.5518,56.3783,21.4318,56.0143,16.4388,55.7173C15.4948,55.6613,14.5998,55.6083,14.0718,55.6033C8.5878,55.5523,7.0788,53.3473,7.1108,49.7653C7.1208,48.6133,7.3868,47.7163,7.6858,46.7133C7.8678,46.0973,8.0748,45.4043,8.1018,44.9133C8.4808,38.0613,8.3488,31.2813,8.2178,24.5093 M16.5608,16.0833C16.5808,18.8083,16.6348,21.5923,16.6878,24.3773C16.8238,31.3693,16.9598,38.3713,16.5718,45.3783C16.5348,46.0443,16.4448,46.6513,16.3268,47.2123L16.9378,47.2473C19.9418,47.4263,23.6248,47.6453,24.6288,46.3593C27.9248,42.1443,36.7098,38.7703,44.3068,35.8523C48.0478,34.4153,51.3258,33.3633,52.6858,32.8583C50.7808,30.9263,42.5318,27.3433,36.6208,24.7753C34.3148,23.7733,32.3008,22.8993,30.8848,22.1673C30.8338,22.1413,30.3308,21.8703,29.6128,21.4873C26.4858,19.8193,20.2428,16.4893,16.5608,16.0833" Fill="Black" Height="48.316" Canvas.Left="7.11" Stretch="Fill" Canvas.Top="7.554" Width="54.463"/>
                                <Path x:Name="path" Data="M12.3184,14.938C12.3534,24.988,12.8974,35.026,12.3374,45.145C12.1504,48.524,9.3424,51.325,14.1054,51.369C18.2894,51.407,25.0384,52.715,27.9684,48.967C32.6604,42.965,55.9824,37.457,57.3064,34.114C58.0464,28.071,38.8694,21.516,32.8274,18.396C28.8604,16.347,12.7564,7.019,12.3184,14.938z" Fill="#FF89DD16" Height="41.803" Canvas.Left="10.354" StrokeStartLineCap="Flat" Stretch="Fill" StrokeEndLineCap="Flat" Stroke="#FFFEFEFE" StrokeThickness="1.984" StrokeMiterLimit="22.926" StrokeLineJoin="Miter" Canvas.Top="10.81" Width="47.965"/>
                            </Canvas>
                        </Viewbox>
                    </Grid>
                    <ControlTemplate.Triggers>
                        <Trigger Property="IsMouseOver" Value="True">
                            <Setter Property="Fill" TargetName="path" Value="#FF66AD05"/>
                        </Trigger>
                        <Trigger Property="IsPressed" Value="True">
                            <Setter Property="Fill" TargetName="path">
                                <Setter.Value>
                                    <LinearGradientBrush EndPoint="0.5,1" StartPoint="0.5,0">
                                        <GradientStop Color="#FF38B800" Offset="0"/>
                                        <GradientStop Color="#FFE5FFDA" Offset="1"/>
                                    </LinearGradientBrush>
                                </Setter.Value>
                            </Setter>
                        </Trigger>
                        <Trigger Property="IsMouseOver" Value="True"/>
                        <Trigger Property="IsPressed" Value="True"/>
                        <Trigger Property="IsEnabled" Value="False"/>
                    </ControlTemplate.Triggers>
                </ControlTemplate>
            </Setter.Value>
        </Setter>
    </Style>
button tamplate
    #37455616
Фотография aleks-sam
Path в этой же кнопке? Или какой то другой? В Expression blend'е работали?
