Tomcat и SOAP
Мне необходимо подключиться к информационной системе через SOAP. У меня есть Apache Tomcat 6. Есть библиотека jakarta-taglibs-io-20060829.zip. <!doctype html public "-//w3c//dtd html 4.0 transitional//en"> <%@ taglib uri="/WEB-INF/taglibs-io.tld" prefix="io" %> <io:soap url="+http://...+" SOAPAction="+http://+"> <io:body> <soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd"> <soap:Header><SourceInfo xmlns="+http://....+"> </soap:Header> <soap:Body> .... </soap:Body> </soap:Envelope> </io:body> </io:soap> После подключения Tomcat выдает такую ошибку HTTP Status 500 - -------------------------------------------------------------------------------- type Exception report message description The server encountered an internal error () that prevented it from fulfilling this request. exception org.apache.jasper.JasperException: javax.servlet.ServletException: javax.servlet.jsp.JspException: Server returned HTTP response code: 405 for URL: +http:....+ org.apache.jasper.servlet.JspServletWrapper.handleJspException(JspServletWrapper.java:527) org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:401) org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:313) org.apache.jasper.servlet.JspServlet.service(JspServlet.java:260) javax.servlet.http.HttpServlet.service(HttpServlet.java:717) root cause javax.servlet.ServletException: javax.servlet.jsp.JspException: Server returned HTTP response code: 405 for URL: +http://....+ org.apache.jasper.runtime.PageContextImpl.doHandlePageException(PageContextImpl.java:862) org.apache.jasper.runtime.PageContextImpl.handlePageException(PageContextImpl.java:791) org.apache.jsp.Processing_005fUnblocking_005fPayment_jsp._jspService(Processing_005fUnblocking_005fPayment_jsp.java:305) org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70) javax.servlet.http.HttpServlet.service(HttpServlet.java:717) org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:377) org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:313) org.apache.jasper.servlet.JspServlet.service(JspServlet.java:260) javax.servlet.http.HttpServlet.service(HttpServlet.java:717) Подскажите в чем может быть проблема? Заранее благодарю за ответы. ... |
| 21.09.2010, 12:14:27 |
Tomcat и SOAP
drno, Processing_005fUnblocking_005fPayment_jsp.java:305 вот открой посмотри. из этой функции полезла ошибка. как тут можно сказать что не правильно? нету ответа для этого вопроса. потому что тут передается текст, текст парсится,возникают ошибки. ... |
| 21.09.2010, 12:39:11 |
Tomcat и SOAP
AlexeiK, спасибо что откликнулись. Processing_005fUnblocking_005fPayment_jsp - это название моей jsp страницы. Меня в принципе интересует то, что будет ли работать SOAP через библиотеку jakarta-taglibs-io-20060829.zip с Apache Tomcat 6. 29.08.2006 03:14 109я898 io-doc.war 29.08.2006 03:14 60я280 io-examples.war 29.08.2006 03:14 27я343 taglibs-io.jar 29.08.2006 03:14 15я857 taglibs-io.tld ... |
| 21.09.2010, 14:13:54 |
Tomcat и SOAP
drno, дак онечно будет. там ж даже sopa formatter свой можно написать . ... |
| 21.09.2010, 14:31:12 |
Tomcat и SOAP
AlexeiK, сможете пример какой-нибудь написать? ... |
| 21.09.2010, 15:07:30 |
Tomcat и SOAP
AlexeiK, каким другим прикладным ПО вообще можно протестировать SOAP? ... |
| 21.09.2010, 17:25:19 |
Tomcat и SOAP
Спасибо за ответы. Задачу решил. Проблема была зарыта в том, что значение url и в теге wsa:To были разными url="http://....." <wsa:To>http://.....</wsa:To> ... |
| 22.09.2010, 17:19:49 |
Tomcat и SOAP
drnoСпасибо за ответы. Задачу решил. Проблема была зарыта в том, что значение url и в теге wsa:To были разными url="http://....." <wsa:To>http://.....</wsa:To> вот и сделай вывод, как плохо ты задаешь вопросы. ... |
| 22.09.2010, 17:25:43 |
Tomcat и SOAP
Конечно, вышло не совсем понятно как хотелось бы. Но это дело для меня было новое и не освоенное. :-) Мне сложно было задавать вопрос, т.к. я не мог дословно указывать код. Попутно хотел бы узнать, параметры како-нибудь WEB сервера, к которому можно подключаться, запрашивать данные, т.е. тестировать работу SOAP протокола? ... |
| 23.09.2010, 16:36:30 |
start [/forum/topic.php?fid=19&gotonew=1&tid=1397590]: |
49ms |
62ms |
| others: | 196ms |
| total: | 364ms |
