pered kazdoi strochkoi v dataGrid ili DataList postavit tag
mne nyzna vot kakay vesch. pered kazdoi strochkoi v dataGrid ili DataList postavit naprimer xml tag. to est kak cherez datalist ya znay, mozno li eto sdelat cherez dataGrid, mne takze nado delat sorting. kak mozno sdelat inheritance from DataList i dobavit tyda property chto pered sozdaniem novoi strochki dobav kakoi to tag, i v konce zakroi tag. ... |
| 01.05.2004, 13:38:02 |
Very easy: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. I hope you can undersatnd the main idea. Good luck! P.S. Sorry for English. ... |
| 02.05.2004, 16:47:12 |
no problem with English :-) Thanks. I implemented Repeater with my Control. In my Control I build table and before add new records I write xml tag. you can't understand me. I want to do anything as <xml name="kostya"></xml>first record from SQL<xml name="end_kostya"></xml> <xml name="kostya"></xml>second record from SQL<xml name="end_kostya"></xml> etc. in datagrid you can't add xml tag before row. you can't go step before. ... |
| 03.05.2004, 21:59:49 |
авторin datagrid you can't add xml tag before row. you can't go step before. Probably I do not understand you exactly, sorry... I thought that you need customized columns in Grid... Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. Sorry... ... |
| 04.05.2004, 22:35:21 |
start [/forum/topic.php?fid=18&gotonew=1&tid=1395702]: |
29ms |
49ms |
109ms |
| others: | 329ms |
| total: | 593ms |
