Create table AS table1 .... ERROR ! помогите! плз!!!
выдается ошибка на создание таблицы из под запроса...в чем я не прав???? код: Dim cmd As ADODB.Command dbpath = "C:\sql_Statements\sqldb1.mdb" src = "CREATE TABLE table4 as SELECT * FROM table1" scn = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source =" & dbpath & ";Persist Security Info=False" Set cn = New ADODB.Connection cn.Open scn Set cmd = New ADODB.Command cmd.ActiveConnection = cn cmd.CommandText = src cmd.Execute Set cmd = Nothing cn.Close Set cn = Nothing ... |
| 05.12.2002, 17:37 |
CREATE TABLE table4 as SELECT * FROM table1 Код: plaintext ... |
| 05.12.2002, 17:58 |
серовно syntax error in CREATE TABLE statement :( ... |
| 05.12.2002, 18:33 |
start [/forum/topic.php?desktop=1&fid=60&tid=2171545]: |
145ms |
53ms |
| others: | 231ms |
| total: | 472ms |
