Сохранение файлов на сервере
Народ поможите чем могете :-) Есть таблица CustomerEngName, поле Files тип image Загрузка файла на сервер Private Sub Command2_Click() Dim mstream As New ADODB.Stream Dim rs As New ADODB.Recordset rs.Open "SELECT Files FROM CustomerEngName WHERE ID=1", "Provider=SQLOLEDB.1;Integrated Security=SSPI;Persist Security Info=False;Initial Catalog=UnionDB;Data Source=SRVAPP1", adOpenKeyset, adLockOptimistic mstream.Type = adTypeBinary mstream.Open mstream.LoadFromFile "c:\test.jpeg" rs.Fields("Files").Value = mstream.Read rs.Update End Sub Проверка Private Sub Command1_Click() Dim mstream As New ADODB.Stream Dim rs As New ADODB.Recordset rs.Open "SELECT Files FROM CustomerEngName WHERE ID=1", "Provider=SQLOLEDB.1;Integrated Security=SSPI;Persist Security Info=False;Initial Catalog=UnionDB;Data Source=SRVAPP1", adOpenKeyset, adLockOptimistic mstream.Type = adTypeBinary mstream.Open mstream.Write rs.Fields("Files").Value mstream.SaveToFile "c:\test1.jpeg", adSaveCreateOverWrite End Sub Пытаюсь посмотреть "http://SRVAPP1/unionDB?sql=SELECT FILES FROM CustomerEngName where ID=1" Нифига не получается!!!!!!!!!!!!!!! В чём грабли? ... |
| 17.06.2003, 16:14 |
start [/forum/topic.php?desktop=1&fid=60&tid=2171138]: |
572ms |
| others: | 207ms |
| total: | 827ms |
