сетевое окружение
Поиск всех компрьютеров в сети (сетевое окружение) и добавление их в ListBox: использую такой код... Option Explicit Public Type NETRESOURCE dwScope As Long dwType As Long dwDisplayType As Long dwUsage As Long lpLocalName As Long lpRemoteName As Long lpComment As Long lpProvider As Long End Type Public Declare Function WNetOpenEnum Lib "mpr.dll" Alias "WNetOpenEnumA" (ByVal dwScope As Long, ByVal dwType As Long, ByVal dwUsage As Long, lpNetResource As Any, lphEnum As Long) As Long Public Declare Function WNetEnumResource Lib "mpr.dll" Alias "WNetEnumResourceA" (ByVal hEnum As Long, lpcCount As Long, ByVal lpBuffer As Long, lpBufferSize As Long) As Long Public Declare Function WNetCloseEnum Lib "mpr.dll" (ByVal hEnum As Long) As Long Public Const RESOURCE_CONNECTED = &H1 Public Const RESOURCE_GLOBALNET = &H2 Public Const RESOURCE_REMEMBERED = &H3 Public Const RESOURCETYPE_ANY = &H0 Public Const RESOURCETYPE_DISK = &H1 Public Const RESOURCETYPE_PRINT = &H2 Public Const RESOURCETYPE_UNKNOWN = &HFFFF Public Const RESOURCEUSAGE_CONNECTABLE = &H1 Public Const RESOURCEUSAGE_CONTAINER = &H2 Public Const RESOURCEUSAGE_RESERVED = &H80000000 Private Const GMEM_FIXED = &H0 Private Const GMEM_ZEROINIT = &H40 Private Const GPTR = (GMEM_FIXED Or GMEM_ZEROINIT) Private Declare Function GlobalAlloc Lib "KERNEL32" (ByVal wFlags As Long, ByVal dwBytes As Long) As Long Private Declare Function GlobalFree Lib "KERNEL32" (ByVal hMem As Long) As Long Private Declare Sub CopyMemory Lib "KERNEL32" Alias "RtlMoveMemory" (hpvDest As Any, hpvSource As Any, ByVal cbCopy As Long) Private Declare Function CopyPointer2String Lib "KERNEL32" Alias "lstrcpyA" (ByVal NewString As String, ByVal OldString As Long) As Long Public Sub DoNetEnum() Dim hEnum As Long, lpBuff As Long, NR As NETRESOURCE Dim cbBuff As Long, cCount As Long Dim p As Long, res As Long, i As Long 'Setup the NETRESOURCE input structure. NR.lpRemoteName = 0 cbBuff = 10000 cCount = &HFFFFFFFF 'Open a Net enumeration operation handle: hEnum. res = WNetOpenEnum(RESOURCE_GLOBALNET, RESOURCETYPE_ANY, 0, NR, hEnum) If res = 0 Then 'Create a buffer large enough for the results. '10000 bytes should be sufficient. lpBuff = GlobalAlloc(GPTR, cbBuff) 'Call the enumeration function. res = WNetEnumResource(hEnum, cCount, lpBuff, cbBuff) If res = 0 Then p = lpBuff 'WNetEnumResource fills the buffer with an array of 'NETRESOURCE structures. Walk through the list and print 'each local and remote name. For i = 1 To cCount ' All we get back are the Global Network Containers --- Enumerate each of these CopyMemory NR, ByVal p, LenB(NR) Form1.List1.AddItem "Network Name " & PointerToString(NR.lpRemoteName) DoNetEnum2 NR p = p + LenB(NR) Next i End If If lpBuff <> 0 Then GlobalFree (lpBuff) WNetCloseEnum (hEnum) 'Close the enumeration End If End Sub Private Function PointerToString(p As Long) As String 'The values returned in the NETRESOURCE structures are pointers to 'ANSI strings so they need to be converted to Visual Basic Strings. Dim s As String s = String(255, Chr$(0)) CopyPointer2String s, p PointerToString = Left(s, InStr(s, Chr$(0)) - 1) End Function Public Sub DoNetEnum2(NR As NETRESOURCE) Dim hEnum As Long, lpBuff As Long Dim cbBuff As Long, cCount As Long Dim p As Long, res As Long, i As Long 'Setup the NETRESOURCE input structure. cbBuff = 10000 cCount = &HFFFFFFFF 'Open a Net enumeration operation handle: hEnum. res = WNetOpenEnum(RESOURCE_GLOBALNET, RESOURCETYPE_ANY, 0, NR, hEnum) If res = 0 Then 'Create a buffer large enough for the results. '10000 bytes should be sufficient. lpBuff = GlobalAlloc(GPTR, cbBuff) 'Call the enumeration function. res = WNetEnumResource(hEnum, cCount, lpBuff, cbBuff) If res = 0 Then p = lpBuff 'WNetEnumResource fills the buffer with an array of 'NETRESOURCE structures. Walk through the list and print 'each remote name. For i = 1 To cCount CopyMemory NR, ByVal p, LenB(NR) Form1.List1.AddItem "Network Computer #" & i & " " & PointerToString(NR.lpRemoteName) p = p + LenB(NR) Next i End If If lpBuff <> 0 Then GlobalFree (lpBuff) WNetCloseEnum (hEnum) 'Close the enumeration End If End Sub 'Place follow code to form section Private Sub Form_Load() DoNetEnum End Sub Матюхаеться на этом самом красном месте....??? Почему??? ... |
| 01.08.2003, 16:06 |
сетевое окружение
замени public на private ... |
| 01.08.2003, 16:48 |
сетевое окружение
пробовал....матюхается уже вот тута... Option Explicit Public Type NETRESOURCE dwScope As Long dwType As Long dwDisplayType As Long dwUsage As Long lpLocalName As Long lpRemoteName As Long lpComment As Long lpProvider As Long End Type Public Declare Function WNetOpenEnum Lib "mpr.dll" Alias "WNetOpenEnumA" (ByVal dwScope As Long, ByVal dwType As Long, ByVal dwUsage As Long, lpNetResource As Any, lphEnum As Long) As Long Public Declare Function WNetEnumResource Lib "mpr.dll" Alias "WNetEnumResourceA" (ByVal hEnum As Long, lpcCount As Long, ByVal lpBuffer As Long, lpBufferSize As Long) As Long Public Declare Function WNetCloseEnum Lib "mpr.dll" (ByVal hEnum As Long) As Long Private Const RESOURCE_CONNECTED = &H1 Private Const RESOURCE_GLOBALNET = &H2 Private Const RESOURCE_REMEMBERED = &H3 Private Const RESOURCETYPE_ANY = &H0 Private Const RESOURCETYPE_DISK = &H1 Private Const RESOURCETYPE_PRINT = &H2 Private Const RESOURCETYPE_UNKNOWN = &HFFFF Private Const RESOURCEUSAGE_CONNECTABLE = &H1 Private Const RESOURCEUSAGE_CONTAINER = &H2 Private Const RESOURCEUSAGE_RESERVED = &H80000000 Private Const GMEM_FIXED = &H0 Private Const GMEM_ZEROINIT = &H40 Private Const GPTR = (GMEM_FIXED Or GMEM_ZEROINIT) Private Declare Function GlobalAlloc Lib "KERNEL32" (ByVal wFlags As Long, ByVal dwBytes As Long) As Long Private Declare Function GlobalFree Lib "KERNEL32" (ByVal hMem As Long) As Long Private Declare Sub CopyMemory Lib "KERNEL32" Alias "RtlMoveMemory" (hpvDest As Any, hpvSource As Any, ByVal cbCopy As Long) Private Declare Function CopyPointer2String Lib "KERNEL32" Alias "lstrcpyA" (ByVal NewString As String, ByVal OldString As Long) As Long Public Sub DoNetEnum() Dim hEnum As Long, lpBuff As Long, NR As NETRESOURCE Dim cbBuff As Long, cCount As Long Dim p As Long, res As Long, i As Long 'Setup the NETRESOURCE input structure. NR.lpRemoteName = 0 cbBuff = 10000 cCount = &HFFFFFFFF 'Open a Net enumeration operation handle: hEnum. res = WNetOpenEnum(RESOURCE_GLOBALNET, RESOURCETYPE_ANY, 0, NR, hEnum) If res = 0 Then 'Create a buffer large enough for the results. '10000 bytes should be sufficient. lpBuff = GlobalAlloc(GPTR, cbBuff) 'Call the enumeration function. res = WNetEnumResource(hEnum, cCount, lpBuff, cbBuff) If res = 0 Then p = lpBuff 'WNetEnumResource fills the buffer with an array of 'NETRESOURCE structures. Walk through the list and print 'each local and remote name. For i = 1 To cCount ' All we get back are the Global Network Containers --- Enumerate each of these CopyMemory NR, ByVal p, LenB(NR) Form1.List1.AddItem "Network Name " & PointerToString(NR.lpRemoteName) DoNetEnum2 NR p = p + LenB(NR) Next i End If If lpBuff <> 0 Then GlobalFree (lpBuff) WNetCloseEnum (hEnum) 'Close the enumeration End If End Sub Private Function PointerToString(p As Long) As String 'The values returned in the NETRESOURCE structures are pointers to 'ANSI strings so they need to be converted to Visual Basic Strings. Dim s As String s = String(255, Chr$(0)) CopyPointer2String s, p PointerToString = Left(s, InStr(s, Chr$(0)) - 1) End Function Public Sub DoNetEnum2(NR As NETRESOURCE) Dim hEnum As Long, lpBuff As Long Dim cbBuff As Long, cCount As Long Dim p As Long, res As Long, i As Long 'Setup the NETRESOURCE input structure. cbBuff = 10000 cCount = &HFFFFFFFF 'Open a Net enumeration operation handle: hEnum. res = WNetOpenEnum(RESOURCE_GLOBALNET, RESOURCETYPE_ANY, 0, NR, hEnum) If res = 0 Then 'Create a buffer large enough for the results. '10000 bytes should be sufficient. lpBuff = GlobalAlloc(GPTR, cbBuff) 'Call the enumeration function. res = WNetEnumResource(hEnum, cCount, lpBuff, cbBuff) If res = 0 Then p = lpBuff 'WNetEnumResource fills the buffer with an array of 'NETRESOURCE structures. Walk through the list and print 'each remote name. For i = 1 To cCount CopyMemory NR, ByVal p, LenB(NR) Form1.List1.AddItem "Network Computer #" & i & " " & PointerToString(NR.lpRemoteName) p = p + LenB(NR) Next i End If If lpBuff <> 0 Then GlobalFree (lpBuff) WNetCloseEnum (hEnum) 'Close the enumeration End If End Sub 'Place follow code to form section Private Sub Form_Load() DoNetEnum End Sub Мол.... cannot define a Public user-defined type within a private object module ... |
| 01.08.2003, 17:33 |
start [/forum/topic.php?desktop=1&fid=60&tid=2170956]: |
47ms |
35ms |
| others: | 243ms |
| total: | 362ms |
