Properties для Excel
1. Есть xls-файл (Excel 2002) Book1 с листом List1. И есть код Private Sub Form_Load() On Error GoTo mError: Dim cnn As ADODB.Connection Dim cat As ADOX.Catalog Dim tbl As ADOX.Table Set cnn = New ADODB.Connection cnn.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=D:\A\Work\Excel\Book1.xls;Extended Properties=Excel 8.0;Persist Security Info=False" Set cat = New ADOX.Catalog cat.ActiveConnection = cnn Dim vTableName As String Dim vPropVal As Variant Dim sPropName As String Dim sPropType As String Set tbl = cat.Tables(0) vTableName = tbl.Name sName = tbl.Properties(0).Name sType = tbl.Properties(0).Type vVal = tbl.Properties(0).Value mError: Dim lErrNumber As Long Dim sDescription As String Dim sSource As String lErrNumber = Err.Number sDescription = Err.Description sSource = Err.Source End Sub Точка останова ставилась на End Sub. При попытке выполнить vVal = tbl.Properties(0).Value выскакивал Exception. Результата работы в окне Watches следующий: Expression Value lErrNumber -2147467259 sDescription "Неопознанная ошибка" sSource "Microsoft JET Database Engine" sName "Temporary Table" sType 11 vTableName "List1$" vVal Empty Возможно ли считывание свойств Microsoft JET Database Engine для Excel и если да, то как это сделать. ... |
| 19.01.2004, 14:21:31 |
См. ADO API Reference, Properties Collection: Contains all the Property objects for a specific instance of an object. Remarks Some ADO objects have a Properties collection made up of Property objects. Each Property object corresponds to a characteristic of the ADO object specific to the provider. Note See the Property object topic for a more detailed explanation of how to use Property objects. The Dynamic Properties of the Recordset object go out of scope (become unavailable) when the Recordset is closed. See Also Properties, Methods, and Events | Property Object | Appendix A: Providers ... |
| 21.01.2004, 19:29:50 |
start [/forum/topic.php?desktop=1&fid=60&tid=2170190]: |
120ms |
49ms |
| others: | 247ms |
| total: | 470ms |
