Проблема с API функцией
Почему в windows XP не работает функция GetUserName. Вызываю ее так Private Declare Function GetUserName Lib "advapi32.dll" Alias "GetUserNameA" (ByVal lpBuffer As String, nSize As Long) As Long Public Function UserName() As String Dim cn As String Dim ls As Long Dim res As Long cn = String(1024, 0) ls = 1024 res = GetUserName(cn, ls) If res <> 0 Then UserName = Mid(cn, 1, InStr(cn, Chr(0)) - 1) Else UserName = "" End If End Function ... |
| 01.02.2004, 07:04:44 |
Vot eta rabotaet 100%. Private Declare Function getUserName Lib "advapi32.dll" Alias "GetUserNameA" (ByVal lpBuffer As String, nSize As Long) As Long Private Sub Form_Load() Dim myUserName AS String myUserName = UserName() End Sub Private Function UserName() As String Dim User As String Dim retcode As Long User = String(255, " ") retcode = getUserName(User, Len(User)) UserName = Left(User, Len(Trim(User)) - 1) End Function ... |
| 01.02.2004, 11:57:24 |
start [/forum/topic.php?desktop=1&fid=60&tid=2170144]: |
63ms |
| others: | 192ms |
| total: | 297ms |
