Вопрос
Подскажите как записывать и доставать функции в файл ini ... |
| 22.03.2004, 14:26:58 |
Вопрос
попробуй (все в модуле): Option Explicit Public Declare Function GetPrivateProfileStringByKeyName& Lib "kernel32" Alias "GetPrivateProfileStringA" (ByVal lpApplicationName$, ByVal lpszKey$, ByVal lpszDefault$, ByVal lpszReturnBuffer$, ByVal cchReturnBuffer&, ByVal lpszFile$) Public Declare Function GetPrivateProfileStringKeys& Lib "kernel32" Alias "GetPrivateProfileStringA" (ByVal lpApplicationName$, ByVal lpszKey&, ByVal lpszDefault$, ByVal lpszReturnBuffer$, ByVal cchReturnBuffer&, ByVal lpszFile$) Public Declare Function GetPrivateProfileStringSections& Lib "kernel32" Alias "GetPrivateProfileStringA" (ByVal lpApplicationName&, ByVal lpszKey&, ByVal lpszDefault$, ByVal lpszReturnBuffer$, ByVal cchReturnBuffer&, ByVal lpszFile$) ' This first line is the declaration from win32api.txt Public Declare Function WritePrivateProfileStringByKeyName& Lib "kernel32" Alias "WritePrivateProfileStringA" (ByVal lpApplicationName As String, ByVal lpKeyName As String, ByVal lpString As String, ByVal lplFileName As String) Public Declare Function WritePrivateProfileStringToDeleteKey& Lib "kernel32" Alias "WritePrivateProfileStringA" (ByVal lpApplicationName As String, ByVal lpKeyName As String, ByVal lpString As Long, ByVal lplFileName As String) Public Declare Function WritePrivateProfileStringToDeleteSection& Lib "kernel32" Alias "WritePrivateProfileStringA" (ByVal lpApplicationName As String, ByVal lpKeyName As Long, ByVal lpString As Long, ByVal lplFileName As String) Public Declare Function WritePrivateProfileSection Lib "kernel32" Alias "WritePrivateProfileSectionA" (ByVal lpAppName As String, ByVal lpString As String, ByVal lpfilename As String) As Long Function VBGetPrivateProfileString(section$, key$, File$) As String Dim KeyValue$ Dim characters As Long KeyValue$ = String$(128, 0) characters = GetPrivateProfileStringByKeyName(section$, key$, "", KeyValue$, 127, File$) If characters > 1 Then KeyValue$ = left$(KeyValue$, characters) End If VBGetPrivateProfileString = KeyValue$ End Function Public Function GetSectionNames(FileName As String, SectionNames As Variant) As Integer 'GetSectionNames Return Number of Section in file 'SectionNames return all section names Dim characters As Long Dim SectionList As String Dim ArrSection() As String Dim i As Integer Dim NullOffset% SectionList = String$(128, 0) ' Retrieve the list of keys in the section characters = GetPrivateProfileStringSections(0, 0, "", SectionList, 127, FileName) ' Load sections into Arrey i = 0 Do NullOffset% = InStr(SectionList, Chr$(0)) If NullOffset% > 1 Then ReDim Preserve ArrSection(i) ArrSection(i) = Mid$(SectionList, 1, NullOffset% - 1) SectionList$ = Mid$(SectionList, NullOffset% + 1) i = i + 1 End If Loop While NullOffset% > 1 GetSectionNames = i - 1 SectionNames = ArrSection End Function Public Function GetKeyNames(SectionName As String, FileName As String, KeyNames As Variant) As Integer 'GetKeyNames Return Number of key in section 'KeyNames Return list of keyNames in section Dim characters As Long Dim KeyList As String Dim ArrKey() As String Dim i As Integer KeyList = String$(128, 0) ' Retrieve the list of keys in the section characters = GetPrivateProfileStringKeys(SectionName, 0, "", KeyList, 127, FileName) ' Load Keys into Arrey Dim NullOffset% i = 0 Do NullOffset% = InStr(KeyList, Chr$(0)) If NullOffset% > 1 Then ReDim Preserve ArrKey(i) ArrKey(i) = Mid$(KeyList, 1, NullOffset% - 1) KeyList$ = Mid$(KeyList, NullOffset% + 1) i = i + 1 End If Loop While NullOffset% > 1 GetKeyNames = i - 1 KeyNames = ArrKey End Function Public Function DeleteKey(KeyName As String, SectionName As String, FileName As String) As Long 'Return 0 if Deletion not sucsesful ' Delete the selected key DeleteKey = WritePrivateProfileStringToDeleteKey(SectionName, KeyName, 0, FileName$) End Function Public Function WriteKey(SectionName As String, KeyName As String, KeyValue As String, FileName As String) As Long If Len(KeyValue) = 0 Then KeyValue = " " WriteKey = WritePrivateProfileStringByKeyName(SectionName, KeyName, KeyValue, FileName) End Function Public Function WriteSection(SectionName As String, FileName As String) As Long WriteSection = WritePrivateProfileSection(SectionName, "", FileName) End Function Public Function DeleteSection(SectionName, FileName) As Long DeleteSection = WritePrivateProfileStringToDeleteSection(SectionName, 0&, 0&, FileName) End Function ... |
| 22.03.2004, 14:43:10 |
Вопрос
А я по-простому делаю. Так я читаю. Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. ... |
| 22.03.2004, 20:14:54 |
Вопрос
Подерживаю johnnybo . Сам пользуюсь подобным модулем. Уже вылизан. Если нужно - могу сбросить на мыло. 2 мадама Просто и со вкусом :) А если в файле сотни секций и тысячи ключей? Все перебирать? :) Я уж лучше по-сложному :) Magnus ... |
| 22.03.2004, 22:57:45 |
Вопрос
Есть такая библиотека осходников, под названием Source+ В ней чудный класс для работы с ini. Гораздо удобнее чем модуль. '***************************************************************************************** '* Class : CIniFile '* Description : Class for working with initialization (*.ini) file. '* Notes : Use this class to give your application the capability to store and '* retrieve its settings to and from an initialization file. '* For advanced use, please see the Source+ Library online documentation '* in the Source+ Explorer (the "Documentation" tab). '***************************************************************************************** Option Explicit ' Error handling definitions Private Const E_ERR_BASE = 17680 + vbObjectError Public Enum EErrIniFile eErrIniFile_InvalidFileName = E_ERR_BASE + 1 eErrIniFile_FileNotFound eErrIniFile_NotInitialized eErrIniFile_InvalidSection eErrIniFile_InvalidKey eErrIniFile_ComponentFailure End Enum Private Const S_ERR_InvalidFileName = "Invalid file name" Private Const S_ERR_FileNotFound = "File not found" Private Const S_ERR_NotInitialized = "Object not properly initialized" Private Const S_ERR_InvalidSection = "Invalid section" Private Const S_ERR_InvalidKey = "Invalid key" Private Const S_ERR_ComponentFailure = "CIniFile component failure" ' Private class constants Private Const MAX_LENGTH = 1024 Private Const INVALID_HANDLE_VALUE = -1 Private Const MAX_LENGTH_EX = 512 ' Private class type definitions Private Type FILETIME dwLowDateTime As Long dwHighDateTime As Long End Type Private Type WIN32_FIND_DATA dwFileAttributes As Long ftCreationTime As FILETIME ftLastAccessTime As FILETIME ftLastWriteTime As FILETIME nFileSizeHigh As Long nFileSizeLow As Long dwReserved0 As Long dwReserved1 As Long cFileName As String * MAX_LENGTH_EX cAlternate As String * 14 End Type ' Private class API function declarations Private Declare Function FindFirstFile Lib "kernel32" Alias "FindFirstFileA" (ByVal lpFileName As String, lpFindFileData As WIN32_FIND_DATA) As Long Private Declare Function FindClose Lib "kernel32" (ByVal hFindFile As Long) As Long Private Declare Function WritePrivateProfileString Lib "kernel32.dll" Alias "WritePrivateProfileStringA" (ByVal lpApplicationName As String, ByVal lpKeyName As Any, ByVal lpString As Any, ByVal lpFileName As String) As Long Private Declare Function GetPrivateProfileString Lib "kernel32.dll" Alias "GetPrivateProfileStringA" (ByVal lpApplicationName As Any, ByVal lpKeyName As Any, ByVal lpDefault As Any, ByVal lpReturnedString As String, ByVal nSize As Long, ByVal lpFileName As String) As Long Private Declare Function GetPrivateProfileInt Lib "kernel32" Alias "GetPrivateProfileIntA" (ByVal lpApplicationName As String, ByVal lpKeyName As String, ByVal nDefault As Long, ByVal lpFileName As String) As Long ' Private variables for internal class use Private m_lError As Long Private m_sKey As String Private m_sSection As String Private m_sDefault As String ' Private variables to hold property values Private m_sFile As String '***************************************************************************************** '* Sub : Init '* Notes : Use this routine for basic object initialization. '***************************************************************************************** Public Sub Init(FileName As String) On Error GoTo hComponentFailure If Len(FileName) = 0 Then On Error GoTo 0 Err.Raise eErrIniFile_InvalidFileName, App.EXEName & ".CIniFile", S_ERR_InvalidFileName End If m_sFile = FileName Exit Sub hComponentFailure: Err.Raise eErrIniFile_ComponentFailure, App.EXEName & ".CIniFile", S_ERR_ComponentFailure End Sub '***************************************************************************************** '* Property : FileName '* Notes : Returns or sets the name of the initialization (*.ini) file. '***************************************************************************************** Public Property Let FileName(Value As String) On Error GoTo hComponentFailure If Len(Value) = 0 Then On Error GoTo 0 Err.Raise eErrIniFile_InvalidFileName, App.EXEName & ".CIniFile", S_ERR_InvalidFileName End If m_sFile = Value Exit Property hComponentFailure: Err.Raise eErrIniFile_ComponentFailure, App.EXEName & ".CIniFile", S_ERR_ComponentFailure End Property Public Property Get FileName() As String On Error GoTo hComponentFailure FileName = m_sFile Exit Property hComponentFailure: Err.Raise eErrIniFile_ComponentFailure, App.EXEName & ".CIniFile", S_ERR_ComponentFailure End Property '***************************************************************************************** '* Function : DeleteKey '* Notes : Deletes a key setting from a specified section of the initialization file. '* Returns true if the key was deleted and false otherwise. '***************************************************************************************** Public Function DeleteKey(ByVal Section As String, ByRef Key As String) As Boolean On Error GoTo hComponentFailure Dim iRet As Long If Len(m_sFile) = 0 Then On Error GoTo 0 Err.Raise eErrIniFile_NotInitialized, App.EXEName & ".CIniFile", S_ERR_NotInitialized End If If Not FileExists(m_sFile) Then On Error GoTo 0 Err.Raise eErrIniFile_FileNotFound, App.EXEName & ".CIniFile", S_ERR_FileNotFound End If If Len(Section) = 0 Then On Error GoTo 0 Err.Raise eErrIniFile_InvalidSection, App.EXEName & ".CIniFile", S_ERR_InvalidSection End If If Len(Key) = 0 Then On Error GoTo 0 Err.Raise eErrIniFile_InvalidKey, App.EXEName & ".CIniFile", S_ERR_InvalidKey End If iRet = WritePrivateProfileString(Section, Key, 0&, m_sFile) WritePrivateProfileString vbNullString, vbNullString, vbNullString, m_sFile DeleteKey = (iRet <> 0) Exit Function hComponentFailure: Err.Raise eErrIniFile_ComponentFailure, App.EXEName & ".CIniFile", S_ERR_ComponentFailure End Function '***************************************************************************************** '* Function : DeleteSection '* Notes : Deletes a section of the initialization file. '* Returns true if the section was deleted and false otherwise. '***************************************************************************************** Public Function DeleteSection(ByVal Section As String) As Boolean On Error GoTo hComponentFailure Dim iRet As Long If Len(m_sFile) = 0 Then On Error GoTo 0 Err.Raise eErrIniFile_NotInitialized, App.EXEName & ".CIniFile", S_ERR_NotInitialized End If If Not FileExists(m_sFile) Then On Error GoTo 0 Err.Raise eErrIniFile_FileNotFound, App.EXEName & ".CIniFile", S_ERR_FileNotFound End If If Len(Section) = 0 Then On Error GoTo 0 Err.Raise eErrIniFile_InvalidSection, App.EXEName & ".CIniFile", S_ERR_InvalidSection End If iRet = WritePrivateProfileString(Section, 0&, 0&, m_sFile) DeleteSection = (iRet <> 0) WritePrivateProfileString vbNullString, vbNullString, vbNullString, m_sFile Exit Function hComponentFailure: Err.Raise eErrIniFile_ComponentFailure, App.EXEName & ".CIniFile", S_ERR_ComponentFailure End Function '***************************************************************************************** '* Function : EnumerateAllKeys '* Notes : Retrieves all the keys (in a an array of strings) belonging to a section '* of an initialization file. '* Returns the number of retrieved keys. '***************************************************************************************** Public Function EnumerateAllKeys(Section As String, ByRef Key() As String) As Long On Error GoTo hComponentFailure Dim lApi_Ret As Long Dim lCount As Long Dim lNextPos As Long Dim lPos As Long Dim lSize As Long Dim buffer As String Dim sCur As String Dim sSections As String If Len(m_sFile) = 0 Then On Error GoTo 0 Err.Raise eErrIniFile_NotInitialized, App.EXEName & ".CIniFile", S_ERR_NotInitialized End If If Not FileExists(m_sFile) Then On Error GoTo 0 Err.Raise eErrIniFile_FileNotFound, App.EXEName & ".CIniFile", S_ERR_FileNotFound End If If Len(Section) = 0 Then On Error GoTo 0 Err.Raise eErrIniFile_InvalidSection, App.EXEName & ".CIniFile", S_ERR_InvalidSection End If lCount = 0 Erase Key If (Len(Section) > 0) Then buffer = Space$(8192) lSize = Len(buffer) lApi_Ret = GetPrivateProfileString(Section, 0&, m_sDefault, buffer, lSize, m_sFile) If (lSize > 0) Then sSections = Left$(buffer, lApi_Ret) Else sSections = "" End If lPos = 1 lNextPos = InStr(lPos, sSections, Chr$(0)) Do While lNextPos <> 0 sCur = Mid$(sSections, lPos, (lNextPos - lPos)) If (sCur <> Chr$(0)) Then lCount = lCount + 1 ReDim Preserve Key(1 To lCount) As String Key(lCount) = Mid$(sSections, lPos, (lNextPos - lPos)) lPos = lNextPos + 1 lNextPos = InStr(lPos, sSections, Chr$(0)) End If Loop End If EnumerateAllKeys = lCount Exit Function hComponentFailure: Err.Raise eErrIniFile_ComponentFailure, App.EXEName & ".CIniFile", S_ERR_ComponentFailure End Function '***************************************************************************************** '* Sub : EnumerateAllSections '* Notes : Retrieves all the sections belonging to an initialization file. '* Returns the number of retirved sections. '***************************************************************************************** Public Function EnumerateAllSections(ByRef Sections() As String) As Long On Error GoTo hComponentFailure Dim lApi_Ret As Long Dim lCount As Long Dim lNextPos As Long Dim lPos As Long Dim lSize As Long Dim sCur As String Dim buffer As String Dim sSections As String If Len(m_sFile) = 0 Then On Error GoTo 0 Err.Raise eErrIniFile_NotInitialized, App.EXEName & ".CIniFile", S_ERR_NotInitialized End If If Not FileExists(m_sFile) Then On Error GoTo 0 Err.Raise eErrIniFile_FileNotFound, App.EXEName & ".CIniFile", S_ERR_FileNotFound End If lCount = 0 Erase Sections If (Len(m_sFile) > 0) Then buffer = Space$(8192) lSize = Len(buffer) lApi_Ret = GetPrivateProfileString(0&, 0&, m_sDefault, buffer, lSize, m_sFile) If (lSize > 0) Then sSections = Left$(buffer, lApi_Ret) Else sSections = "" End If lPos = 1 lNextPos = InStr(lPos, sSections, Chr$(0)) Do While lNextPos <> 0 If (lNextPos <> lPos) Then sCur = Mid$(sSections, lPos, (lNextPos - lPos)) lCount = lCount + 1 ReDim Preserve Sections(1 To lCount) As String Sections(lCount) = sCur End If lPos = lNextPos + 1 lNextPos = InStr(lPos, sSections, Chr$(0)) Loop End If EnumerateAllSections = lCount Exit Function hComponentFailure: Err.Raise eErrIniFile_ComponentFailure, App.EXEName & ".CIniFile", S_ERR_ComponentFailure End Function '***************************************************************************************** '* Function : GetNumericValue '* Notes : Returns an integer value containing the key setting stored in the '* specified section of an initialization file. '***************************************************************************************** Public Function GetNumericValue(Section As String, Key As String) As Integer On Error GoTo hComponentFailure If Len(m_sFile) = 0 Then On Error GoTo 0 Err.Raise eErrIniFile_NotInitialized, App.EXEName & ".CIniFile", S_ERR_NotInitialized End If If Not FileExists(m_sFile) Then On Error GoTo 0 Err.Raise eErrIniFile_FileNotFound, App.EXEName & ".CIniFile", S_ERR_FileNotFound End If GetNumericValue = GetPrivateProfileInt(Section, Key, -1, m_sFile) Exit Function hComponentFailure: Err.Raise eErrIniFile_ComponentFailure, App.EXEName & ".CIniFile", S_ERR_ComponentFailure End Function '***************************************************************************************** '* Function : GetStringValue '* Notes : Returns a string value containing the key setting stored in the specified '* section of an initialization file. '***************************************************************************************** Public Function GetStringValue(Section As String, Key As String) As String On Error GoTo hComponentFailure Dim lResult As Long Dim sText As String If Len(m_sFile) = 0 Then On Error GoTo 0 Err.Raise eErrIniFile_NotInitialized, App.EXEName & ".CIniFile", S_ERR_NotInitialized End If If Not FileExists(m_sFile) Then On Error GoTo 0 Err.Raise eErrIniFile_FileNotFound, App.EXEName & ".CIniFile", S_ERR_FileNotFound End If sText = String$(255, 0) lResult = GetPrivateProfileString(Section, Key, "", sText, Len(sText), m_sFile) If lResult = 0 Then GetStringValue = "" Else GetStringValue = Left$(sText, InStr(sText, Chr$(0)) - 1) End If Exit Function hComponentFailure: Err.Raise eErrIniFile_ComponentFailure, App.EXEName & ".CIniFile", S_ERR_ComponentFailure End Function '***************************************************************************************** '* Sub : SaveNumericValue '* Notes : Saves a key with a numeric value in the specified section of an '* initialization file. '***************************************************************************************** Public Sub SaveNumericValue(Section As String, Key As String, iData As Integer) On Error GoTo hComponentFailure Dim sData As String If Len(m_sFile) = 0 Then On Error GoTo 0 Err.Raise eErrIniFile_NotInitialized, App.EXEName & ".CIniFile", S_ERR_NotInitialized End If If Len(Section) = 0 Then On Error GoTo 0 Err.Raise eErrIniFile_InvalidSection, App.EXEName & ".CIniFile", S_ERR_InvalidSection End If If Len(Key) = 0 Then On Error GoTo 0 Err.Raise eErrIniFile_InvalidKey, App.EXEName & ".CIniFile", S_ERR_InvalidKey End If sData = iData WritePrivateProfileString Section, Key, sData, m_sFile WritePrivateProfileString vbNullString, vbNullString, vbNullString, m_sFile Exit Sub hComponentFailure: Err.Raise eErrIniFile_ComponentFailure, App.EXEName & ".CIniFile", S_ERR_ComponentFailure End Sub '***************************************************************************************** '* Sub : SaveStringValue '* Notes : Saves a key containing a string value in the specified section of an '* initialization file. '***************************************************************************************** Public Sub SaveStringValue(Section As String, Key As String, sText As String) On Error GoTo hComponentFailure If Len(m_sFile) = 0 Then On Error GoTo 0 Err.Raise eErrIniFile_NotInitialized, App.EXEName & ".CIniFile", S_ERR_NotInitialized End If If Len(Section) = 0 Then On Error GoTo 0 Err.Raise eErrIniFile_InvalidSection, App.EXEName & ".CIniFile", S_ERR_InvalidSection End If If Len(Key) = 0 Then On Error GoTo 0 Err.Raise eErrIniFile_InvalidKey, App.EXEName & ".CIniFile", S_ERR_InvalidKey End If WritePrivateProfileString Section, Key, sText, m_sFile WritePrivateProfileString vbNullString, vbNullString, vbNullString, m_sFile Exit Sub hComponentFailure: Err.Raise eErrIniFile_ComponentFailure, App.EXEName & ".CIniFile", S_ERR_ComponentFailure End Sub '***************************************************************************************** '* Function : FileExists '* Notes : API-based routine to check for a file's existence. '* Returns True if the specified file exists, False otherwise. '***************************************************************************************** Private Function FileExists(FileName As String) As Boolean On Error GoTo hComponentFailure Dim wfd As WIN32_FIND_DATA Dim hFile As Long FileExists = False hFile = FindFirstFile(FileName, wfd) If hFile <> INVALID_HANDLE_VALUE Then FileExists = True If FindClose(hFile) = 0 Then On Error GoTo 0 Err.Raise eErrIniFile_ComponentFailure, App.EXEName & ".CIniFile", S_ERR_ComponentFailure End If End If Exit Function hComponentFailure: Err.Raise eErrIniFile_ComponentFailure, App.EXEName & ".CIniFile", S_ERR_ComponentFailure End Function '***************************************************************************************** '* Sub : Class_Initialize '* Notes : Class data space initialization. '***************************************************************************************** Private Sub Class_Initialize() On Error GoTo hComponentFailure m_sFile = App.Path & "\MyFileSettings.ini" Exit Sub hComponentFailure: Err.Raise eErrIniFile_ComponentFailure, App.EXEName & ".CIniFile", S_ERR_ComponentFailure End Sub ... |
| 23.03.2004, 09:33:31 |
start [/forum/topic.php?desktop=1&fid=60&tid=2169890]: |
85ms |
40ms |
| others: | 244ms |
| total: | 419ms |
