Dbcombo
Kak mojno wyswetit dannye iz odnogo polya tablisy w DBcombo ispolzuya ADO. Baza nahoditsya w SQL SERVER 2000. U menya kod takoy : Dim ado As Recordset Private Sub Form_Load() Dim db As Connection Set db = New Connection db.CursorLocation = adUseClient db.Open "PROVIDER=MSDASQL;dsn=p;uid=;pwd=;" Set ado = New Recordset ado.Open "select imya from Polzowateli", db, adOpenStatic, adLockOptimistic Set DBCombo1.RowSource = ado DBCombo1.ListField = "imya" End Sub Wyhodit takoe soobshenie: Object variable or with block variable not set Spasibo zaranee ... |
| 06.05.2004, 14:07:49 |
start [/forum/topic.php?desktop=1&fid=60&tid=2169614]: |
59ms |
48ms |
| others: | 191ms |
| total: | 339ms |
