Массив
Cуществует ли какая нить функция очистки массива? ... |
| 10.09.2004, 08:54:41 |
Массив
Erase (с выражением лица) ... |
| 10.09.2004, 10:17:40 |
Массив
Долго мы будем сюда MSDN копировать? Use Dynamic Arrays and Erase to Reclaim Memory Consider using dynamic arrays instead of fixed arrays. When you no longer need the data in a dynamic array, use Erase or ReDim Preserve to discard unneeded data, and reclaim the memory used by the array. For example, you can reclaim the space used by a dynamic array with the following code: Erase MyArray Whereas Erase completely eliminates the array, ReDim Preserve makes the array smaller without losing its contents: ReDim Preserve MyArray(10, smallernum) Erasing a fixed-size array will not reclaim the memory for the array — it simply clears out the values of each element of the array . If each element was a string, or a Variant containing a string or array, then erasing the array would reclaim the memory from those strings or Variants, not the memory for the array itself. (c) MSDN April 2001 ... |
| 10.09.2004, 10:18:06 |
start [/forum/topic.php?desktop=1&fid=60&tid=2168901]: |
34ms |
| others: | 210ms |
| total: | 304ms |
