ППЛЗ, где можно найти все команды, которые посылает Апишка [b]mciSendString[/b]
<тема>, искал по инету, но ненашёл. ... |
| 09.12.2004, 16:47:21 |
Multimedia Command Strings The following command strings are used with multimedia. break capability capture close configure copy cue cut delete escape freeze index info list load mark monitor open paste pause play put quality realize record reserve restore resume save seek set setaudio settimecode settuner setvideo signal spin status step stop sysinfo undo unfreeze update where window ... |
| 09.12.2004, 17:15:54 |
start [/forum/topic.php?desktop=1&fid=60&tid=2168469]: |
39ms |
| others: | 240ms |
| total: | 336ms |
