Object variable or with block variable not set
Dim db_file As String Dim conn As ADODB.Connection Dim rs As ADODB.Recordset db_file = IniMassivPrivate("База", App.Path & "\conn.ini") Set conn = New ADODB.Connection conn.Open "Provider=vfpoledb.1; Data Source=" & db_file & "; mode=share deny none; extended properties =""; user id=""; password=""; mask password=false; cache authentication=false; encrypt password=false; collating sequence=machine; DSN=""" rs.Source = "prihod" rs.Open rs.addnew rs.Fields("type") = Combo1.Text rs.Fields("kol_p") = txtkol_p rs.Fields("data_p") = DTPicker1 rs.update rs.Close conn.Close Подскажите пожалуйста варианы решения этой проблемы ... |
| 16.03.2005, 12:46:05 |
| 16.03.2005, 12:47:36 |
lilo12Dim db_file As String Dim conn As ADODB.Connection Dim rs As ADODB.Recordset db_file = IniMassivPrivate("База", App.Path & "\conn.ini") Set conn = New ADODB.Connection conn.Open "Provider=vfpoledb.1; Data Source=" & db_file & "; mode=share deny none; extended properties =""; user id=""; password=""; mask password=false; cache authentication=false; encrypt password=false; collating sequence=machine; DSN=""" rs.Source = "prihod" rs.Open rs.addnew rs.Fields("type") = Combo1.Text rs.Fields("kol_p") = txtkol_p rs.Fields("data_p") = DTPicker1 rs.update rs.Close conn.Close Подскажите пожалуйста варианы решения этой проблемы попробуй так Dim ssql As String Dim strsnn As String Dim strid As String Dim i Dim b Set cnn1 = New ADODB.Connection strcnn = "driver={SQL Server};server=имя сервера;" & _ "uid=пользователь;pwd=пароль;database=имя базы" cnn1.Open strcnn Set rsSotrudniki = New ADODB.Recordset rsSotrudniki.add new . . . . . ... |
| 16.03.2005, 12:50:22 |
Валерий_26RUS lilo12Dim db_file As String Dim conn As ADODB.Connection Dim rs As ADODB.Recordset db_file = IniMassivPrivate("База", App.Path & "\conn.ini") Set conn = New ADODB.Connection conn.Open "Provider=vfpoledb.1; Data Source=" & db_file & "; mode=share deny none; extended properties =""; user id=""; password=""; mask password=false; cache authentication=false; encrypt password=false; collating sequence=machine; DSN=""" rs.Source = "prihod" rs.Open rs.addnew rs.Fields("type") = Combo1.Text rs.Fields("kol_p") = txtkol_p rs.Fields("data_p") = DTPicker1 rs.update rs.Close conn.Close Подскажите пожалуйста варианы решения этой проблемы попробуй так Dim ssql As String Dim strsnn As String Dim strid As String Dim i Dim b Set cnn1 = New ADODB.Connection strcnn = "driver={SQL Server};server=имя сервера;" & _ "uid=пользователь;pwd=пароль;database=имя базы" cnn1.Open strcnn Set rsSotrudniki = New ADODB.Recordset rsИМЯ ТАБЛИЦЫ.addnew . . . . . ... |
| 16.03.2005, 12:52:45 |
start [/forum/topic.php?desktop=1&fid=60&tid=2168093]: |
48ms |
25ms |
| others: | 183ms |
| total: | 286ms |
