Переделать макрос для работы только в 2-х листах
Помогите пожалуйста переделать макрос для работы только в 2-х из 20-ти листов. Имена листов "Master" и " Officer" Sub Count() Dim intI As Integer Dim rng As Range Dim cel As Range For intI = 2 To 20 With Worksheets(intI) Set rng = Worksheets(intI).Range("C38, F38") For Each cel In rng Select Case cel.Value Case 0 cel.Offset(0, 1).Value = "(Nil)" Case 1 cel.Offset(0, 1).Value = "(One)" Case 2 cel.Offset(0, 1).Value = "(Two)" Case 3 cel.Offset(0, 1).Value = "(Three)" Case 4 cel.Offset(0, 1).Value = "(Four)" Case 5 cel.Offset(0, 1).Value = "(Five)" Case 6 cel.Offset(0, 1).Value = "(Six)" Case 7 cel.Offset(0, 1).Value = "(Seven)" Case 8 cel.Offset(0, 1).Value = "(Eight)" Case 9 cel.Offset(0, 1).Value = "(Nine)" Case 10 cel.Offset(0, 1).Value = "(Ten)" Case 11 cel.Offset(0, 1).Value = "(Eleven)" Case 12 cel.Offset(0, 1).Value = "(Twelve)" Case 13 cel.Offset(0, 1).Value = "(Thirteen)" Case 14 cel.Offset(0, 1).Value = "(Fourteen)" Case 15 cel.Offset(0, 1).Value = "(Fifteen)" Case 16 cel.Offset(0, 1).Value = "(Sixteen)" Case 17 cel.Offset(0, 1).Value = "(Seventeen)" Case 18 cel.Offset(0, 1).Value = "(Eighteen)" Case 19 cel.Offset(0, 1).Value = "(Nineteen)" Case 20 cel.Offset(0, 1).Value = "(Twenty)" Case 21 cel.Offset(0, 1).Value = "(Twenty one)" Case 22 cel.Offset(0, 1).Value = "(Twenty two)" Case 23 cel.Offset(0, 1).Value = "(Twenty three)" Case 24 cel.Offset(0, 1).Value = "(Twenty four)" Case 25 cel.Offset(0, 1).Value = "(Twenty five)" Case 26 cel.Offset(0, 1).Value = "(Twenty six)" Case 27 cel.Offset(0, 1).Value = "(Twenty seven)" Case 28 cel.Offset(0, 1).Value = "(Twenty eight)" Case 29 cel.Offset(0, 1).Value = "(Twenty nine)" Case 30 cel.Offset(0, 1).Value = "(Thirty)" Case 31 cel.Offset(0, 1).Value = "(Thirty one)" End Select Next cel End With Next intI End Sub ... |
| 27.09.2005, 13:58:41 |
Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68. 69. 70. 71. 72. 73. 74. 75. 76. 77. 78. 79. 80. ... |
| 27.09.2005, 14:28:14 |
Sub Count() Dim intI as Integer Dim rng As Range Dim cel As Range dim int2 as String int2 ="Master" For intI = 1 To 2 With Worksheets(int2) Set rng = Worksheets(int2).Range("C38, F38") For Each cel In rng Select Case cel.Value Case 0 cel.Offset(0, 1).Value = "(Nil)" Case 1 cel.Offset(0, 1).Value = "(One)" Case 2 cel.Offset(0, 1).Value = "(Two)" Case 3 cel.Offset(0, 1).Value = "(Three)" Case 4 cel.Offset(0, 1).Value = "(Four)" Case 5 cel.Offset(0, 1).Value = "(Five)" Case 6 cel.Offset(0, 1).Value = "(Six)" Case 7 cel.Offset(0, 1).Value = "(Seven)" Case 8 cel.Offset(0, 1).Value = "(Eight)" Case 9 cel.Offset(0, 1).Value = "(Nine)" Case 10 cel.Offset(0, 1).Value = "(Ten)" Case 11 cel.Offset(0, 1).Value = "(Eleven)" Case 12 cel.Offset(0, 1).Value = "(Twelve)" Case 13 cel.Offset(0, 1).Value = "(Thirteen)" Case 14 cel.Offset(0, 1).Value = "(Fourteen)" Case 15 cel.Offset(0, 1).Value = "(Fifteen)" Case 16 cel.Offset(0, 1).Value = "(Sixteen)" Case 17 cel.Offset(0, 1).Value = "(Seventeen)" Case 18 cel.Offset(0, 1).Value = "(Eighteen)" Case 19 cel.Offset(0, 1).Value = "(Nineteen)" Case 20 cel.Offset(0, 1).Value = "(Twenty)" Case 21 cel.Offset(0, 1).Value = "(Twenty one)" Case 22 cel.Offset(0, 1).Value = "(Twenty two)" Case 23 cel.Offset(0, 1).Value = "(Twenty three)" Case 24 cel.Offset(0, 1).Value = "(Twenty four)" Case 25 cel.Offset(0, 1).Value = "(Twenty five)" Case 26 cel.Offset(0, 1).Value = "(Twenty six)" Case 27 cel.Offset(0, 1).Value = "(Twenty seven)" Case 28 cel.Offset(0, 1).Value = "(Twenty eight)" Case 29 cel.Offset(0, 1).Value = "(Twenty nine)" Case 30 cel.Offset(0, 1).Value = "(Thirty)" Case 31 cel.Offset(0, 1).Value = "(Thirty one)" End Select Next cel End With int2 ="Officer" Next intI End Sub ... |
| 27.09.2005, 14:48:31 |
Спасибо, все работает. Не много ошибся в определении задачи - в кол-ве листов, нужно было три, (еще один "CREW"). Сам я не очень соображаю в этом. Первый макрос переделал, а второй не получается, (просто интересно) Если кому ни будь будет не в лом, подскажите. Заранее благодарю ... |
| 27.09.2005, 21:41:39 |
смысл в следующем зачем бегать по всем листам если нужно по трем красным выделено то что надо заменить или добавить а проще скопируй и замени все от Sub count до end sub Sub Count() Dim intI As Integer Dim rng As Range Dim cel As Range Dim List(1 To 3) As String Dim int2 As String List(1) = "Master" List(2) = "Officer" List(3) = "CREW" For intI = 1 To 3 int2 = List(intI) With Worksheets(int2) Set rng = Worksheets(int2).Range("C38, F38") For Each cel In rng Select Case cel.Value Case 0 cel.Offset(0, 1).Value = "(Nil)" Case 1 cel.Offset(0, 1).Value = "(One)" Case 2 cel.Offset(0, 1).Value = "(Two)" Case 3 cel.Offset(0, 1).Value = "(Three)" Case 4 cel.Offset(0, 1).Value = "(Four)" Case 5 cel.Offset(0, 1).Value = "(Five)" Case 6 cel.Offset(0, 1).Value = "(Six)" Case 7 cel.Offset(0, 1).Value = "(Seven)" Case 8 cel.Offset(0, 1).Value = "(Eight)" Case 9 cel.Offset(0, 1).Value = "(Nine)" Case 10 cel.Offset(0, 1).Value = "(Ten)" Case 11 cel.Offset(0, 1).Value = "(Eleven)" Case 12 cel.Offset(0, 1).Value = "(Twelve)" Case 13 cel.Offset(0, 1).Value = "(Thirteen)" Case 14 cel.Offset(0, 1).Value = "(Fourteen)" Case 15 cel.Offset(0, 1).Value = "(Fifteen)" Case 16 cel.Offset(0, 1).Value = "(Sixteen)" Case 17 cel.Offset(0, 1).Value = "(Seventeen)" Case 18 cel.Offset(0, 1).Value = "(Eighteen)" Case 19 cel.Offset(0, 1).Value = "(Nineteen)" Case 20 cel.Offset(0, 1).Value = "(Twenty)" Case 21 cel.Offset(0, 1).Value = "(Twenty one)" Case 22 cel.Offset(0, 1).Value = "(Twenty two)" Case 23 cel.Offset(0, 1).Value = "(Twenty three)" Case 24 cel.Offset(0, 1).Value = "(Twenty four)" Case 25 cel.Offset(0, 1).Value = "(Twenty five)" Case 26 cel.Offset(0, 1).Value = "(Twenty six)" Case 27 cel.Offset(0, 1).Value = "(Twenty seven)" Case 28 cel.Offset(0, 1).Value = "(Twenty eight)" Case 29 cel.Offset(0, 1).Value = "(Twenty nine)" Case 30 cel.Offset(0, 1).Value = "(Thirty)" Case 31 cel.Offset(0, 1).Value = "(Thirty one)" End Select Next cel End With Next intI End Sub ... |
| 28.09.2005, 08:48:06 |
Для первого варианта: Код: plaintext 1. 2. Для второго: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. ... |
| 28.09.2005, 09:03:35 |
start [/forum/topic.php?desktop=1&fid=60&tid=2167109]: |
38ms |
36ms |
| others: | 232ms |
| total: | 340ms |
