Как эмулировать двойной клик?
Для одного клика использую - mouse_event. А как эмулировать двойной? ... |
| 29.09.2005, 12:30:01 |
MSDN DblClick Event Occurs when the user presses and releases a mouse button and then presses and releases it again over an object. For a form, the DblClick event occurs when the user double-clicks a disabled control or a blank area of a form. For a control, it occurs when the user: Double-clicks a control with the left mouse button. Double-clicks an item in a ComboBox control whose Style property is set to 1 (Simple) or in a FileListBox, ListBox, DataCombo, or DataList control. Syntax Private Sub Form_DblClick ( ) Private Sub object_DblClick (index As Integer) ...etc... ... |
| 29.09.2005, 15:50:20 |
start [/forum/topic.php?desktop=1&fid=60&tid=2167102]: |
48ms |
25ms |
| others: | 225ms |
| total: | 337ms |
