Замена ComboBox на DataCombo
Здравствуйте все!!! Помогите пожалуйста переделать процедуру автоподстановки в Combo. Есть процедура на ComboBox, а надо DataCombo процедура: Private Sub ComboAutoComplete(cmb As ComboBox) Dim txt As String, pos As Long, txtlen As Long Dim matchcount As Long, complword As String Dim maxi As Long, i As Long, cmbindex As Long txt = cmb.Text txtlen = Len(txt) pos = cmb.SelStart maxi = cmb.ListCount - 1 For i = 0 To maxi If StrComp(txt, Left$(cmb.List(i), txtlen), vbTextCompare) = 0 Then matchcount = matchcount + 1 If matchcount = 1 Then complword = cmb.List(i) cmbindex = i End If End If Next If matchcount >= 1 Then cmb.ListIndex = cmbindex cmb.SelStart = pos cmb.SelLength = Len(complword) - pos End If End Sub ... |
| 02.12.2005, 08:45:33 |
start [/forum/topic.php?desktop=1&fid=60&tid=2166765]: |
34ms |
29ms |
| others: | 195ms |
| total: | 301ms |
