Переход по DataGrid
Есть поле там указывается номер строки и при нажатии клавиши в DataGrid должна стать активной та строка которая указана . ... |
| 16.01.2006, 10:00:19 |
Переход по DataGrid
Moves the position of the current record in a Recordset object. Syntax recordset.Move NumRecords, Start Parameters NumRecords A signed Long expression specifying the number of records the current record position moves. Start Optional. A String or Variant that evaluates to a bookmark. You can also use one of the following BookmarkEnum values: Constant Description adBookmarkCurrent Default. Start at the current record. adBookmarkFirst Start at the first record. adBookmarkLast Start at the last record. ... |
| 16.01.2006, 15:42:48 |
start [/forum/topic.php?desktop=1&fid=60&tid=2166564]: |
93ms |
52ms |
| others: | 231ms |
| total: | 427ms |
