Как из VB6 определить тип ОС
Нужно определить тип ОС (Win98,Win2000,XP) программно. Помогите плиз. ... |
| 28.03.2006, 14:12:17 |
API функции GetVersion, GetVersionEx ... |
| 28.03.2006, 14:33:47 |
1. How to determine which 32-bit Windows version is being used . 2. Через WMI. Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. ... |
| 28.03.2006, 14:35:25 |
Через компонент Microsoft SysInfo Control Select Case SysInfo.OSPlatform Case 0 lblPlatform = "Unidentified" Case 1 lblPlatform = "Windows 95, ver. " & CStr(SysInfo.OSVersion) & " build " & CStr(SysInfo.OSBuild) Case 2 lblPlatform = "Windows NT, ver. " & CStr(SysInfo.OSVersion) & " build " & CStr(SysInfo.OSBuild) End Select ... |
| 28.03.2006, 14:43:09 |
start [/forum/topic.php?desktop=1&fid=60&tid=2166159]: |
275ms |
50ms |
| others: | 200ms |
| total: | 572ms |
