keybd_event
Может у кого то есть коды для символьных клавиш (A-Z, a-z) очень надо для keybd_event Private Const VK_ADD = &H6B Private Const VK_ATTN = &HF6 Private Const VK_BACK = &H8 Private Const VK_CANCEL = &H3 Private Const VK_CAPITAL = &H14 Private Const VK_CLEAR = &HC Private Const VK_CONTROL = &H11 Private Const VK_CRSEL = &HF7 Private Const VK_DECIMAL = &H6E Private Const VK_DELETE = &H2E Private Const VK_DIVIDE = &H6F Private Const VK_DOWN = &H28 Private Const VK_END = &H23 Private Const VK_EREOF = &HF9 Private Const VK_ESCAPE = &H1B Private Const VK_EXECUTE = &H2B Private Const VK_EXSEL = &HF8 Private Const VK_F1 = &H70 Private Const VK_F10 = &H79 Private Const VK_F11 = &H7A Private Const VK_F12 = &H7B Private Const VK_F13 = &H7C Private Const VK_F14 = &H7D Private Const VK_F15 = &H7E Private Const VK_F16 = &H7F Private Const VK_F17 = &H80 Private Const VK_F18 = &H81 Private Const VK_F19 = &H82 Private Const VK_F2 = &H71 Private Const VK_F20 = &H83 Private Const VK_F21 = &H84 Private Const VK_F22 = &H85 Private Const VK_F23 = &H86 Private Const VK_F24 = &H87 Private Const VK_F3 = &H72 Private Const VK_F4 = &H73 Private Const VK_F5 = &H74 Private Const VK_F6 = &H75 Private Const VK_F7 = &H76 Private Const VK_F8 = &H77 Private Const VK_F9 = &H78 Private Const VK_HELP = &H2F Private Const VK_HOME = &H24 Private Const VK_INSERT = &H2D Private Const VK_LBUTTON = &H1 Private Const VK_LCONTROL = &HA2 Private Const VK_LEFT = &H25 Private Const VK_LMENU = &HA4 Private Const VK_LSHIFT = &HA0 Private Const VK_MBUTTON = &H4 ' NOT contiguous with L RBUTTON Private Const VK_MENU = &H12 Private Const VK_MULTIPLY = &H6A Private Const VK_NEXT = &H22 Private Const VK_NONAME = &HFC Private Const VK_NUMLOCK = &H90 Private Const VK_NUMPAD0 = &H60 Private Const VK_NUMPAD1 = &H61 Private Const VK_NUMPAD2 = &H62 Private Const VK_NUMPAD3 = &H63 Private Const VK_NUMPAD4 = &H64 Private Const VK_NUMPAD5 = &H65 Private Const VK_NUMPAD6 = &H66 Private Const VK_NUMPAD7 = &H67 Private Const VK_NUMPAD8 = &H68 Private Const VK_NUMPAD9 = &H69 Private Const VK_OEM_CLEAR = &HFE Private Const VK_PA1 = &HFD Private Const VK_PAUSE = &H13 Private Const VK_PLAY = &HFA Private Const VK_PRINT = &H2A Private Const VK_PRIOR = &H21 Private Const VK_PROCESSKEY = &HE5 Private Const VK_RBUTTON = &H2 Private Const VK_RCONTROL = &HA3 Private Const VK_RETURN = &HD Private Const VK_RIGHT = &H27 Private Const VK_RMENU = &HA5 Private Const VK_RSHIFT = &HA1 Private Const VK_SCROLL = &H91 Private Const VK_SELECT = &H29 Private Const VK_SEPARATOR = &H6C Private Const VK_SHIFT = &H10 Private Const VK_SNAPSHOT = &H2C Private Const VK_SPACE = &H20 Private Const VK_SUBTRACT = &H6D Private Const VK_TAB = &H9 Private Const VK_UP = &H26 Private Const VK_ZOOM = &HFB ... |
| 10.05.2006, 11:27 |
keybd_event
Эта таблица у меня есть но это не совсем то или я непонимаю чтото, почему в примере пробел обозначается "Private Const VK_SPACE = &H20" а в таблице код пробела "32"?? ... |
| 10.05.2006, 11:41 |
keybd_event
Запускаете стандартный виндовый калькулятор в инженерном виде и играетесь с переключателем HEX <-> DEC. ... |
| 10.05.2006, 12:05 |
keybd_event
пробовал уже получается ерунда. а -Dex (97) - Hex (61) вот код можете проверить Private Declare Sub keybd_event Lib "user32" (ByVal bVk As Byte, ByVal bScan As Byte, ByVal dwFlags As Long, ByVal dwExtraInfo As Long) Private Const VK_a = &H61 Private Sub Command1_Click() Text1.SetFocus Call keybd_event(VK_a, 0, 0, 0) End Sub Должно дать маленькую букву "а" а даёт "1" Почему???? ... |
| 10.05.2006, 12:33 |
keybd_event
Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. ... |
| 10.05.2006, 12:53 |
start [/forum/topic.php?desktop=1&fid=60&tid=2165893]: |
29ms |
29ms |
| others: | 208ms |
| total: | 298ms |
