Progressbar Need help!
Необходимо для замутить в программе разбивалке файла на части - progressbar чтоб был виден прогресс. Я с баром никогда не работал так что объясните как это сделать. Мож какие мануалы есть. Вот код дробилки: Private Sub cmdgo_Click() Dim recPos, lenMod, lenDiv As Long Dim readF As Byte Dim c, lenOfFile, AmountOfBytes As Long Dim fileName, folderName, fn As String Dim mass() As Byte Dim Counta fn = "001" recPos = 1 fileName = Text2.Text lenOfFile = FileLen(fileName) AmountOfBytes = Val(txtKusok.Text) folderName = ExtractFolderName(fileName) If optSubDir Then folderName = folderName & "\" & txtPapka & "\" Dim fEx fEx = Dir(folderName, vbDirectory) If fEx = "" Then MkDir folderName End If Else folderName = folderName & "\" End If Open folderName & "Infa.inf" For Output As #4 Print #4, ExtractFileName(fileName) Close #4 If lenOfFile <= Val(txtKusok.Text) Then MsgBox "×àñòü äîëæíà áûòü ìåíüøå ÷åì ôàéë. Èçìåíèòå ðàçìåð ÷àñòè â íàñòðîéêàõ", vbCritical, "Îøèáî÷êà âûøëà..." Exit Sub End If lenDiv = lenOfFile \ AmountOfBytes If lenDiv > 999 Then MsgBox "ÌÀÊÑÈÌÓÌ 999 ×ÀÑÒÅÉ!", vbCritical, "Îøèáêà!!!" Exit Sub End If lenMod = lenOfFile Mod AmountOfBytes If lenMod = 0 Then Open fileName For Binary As #1 Open folderName & fn & ".DMS" For Binary As #3 ReDim mass(AmountOfBytes - 1) c = 1 Do While c < lenOfFile - 1 Get #1, c, mass Put #3, 1, mass c = c + AmountOfBytes Close #3 If c < lenOfFile - 1 Then IncFn fn Open folderName & fn & ".DMS" For Binary As #3 End If Loop Close #3 Close #1 Else Open fileName For Binary As #1 Open folderName & fn & ".DMS" For Binary As #3 ReDim mass(AmountOfBytes - 1) c = 1 Do While c < (lenDiv * AmountOfBytes) - 1 Get #1, c, mass Put #3, 1, mass c = c + AmountOfBytes Close #3 If c < (lenDiv * AmountOfBytes) - 1 Then IncFn fn Open folderName & fn & ".DMS" For Binary As #3 End If Loop Close #3 IncFn fn recPos = 1 Open folderName & fn & ".DMS" For Binary As #3 ReDim mass(lenMod - 1) Get #1, (lenDiv * AmountOfBytes) + 1, mass Put #3, 1, mass Close #3 Close #1 End If MsgBox "Ãîòîâî! Âûáðàííûé ôàéë " & fileName & " áûë ðàçáèò íà " & Val(fn) & " ÷àñòè(åé)!", vbInformation, "Óðà!!!!" End Sub Помогите Плиз!!! ... |
| 28.08.2006, 20:47 |
http://alldata.by.ru/files/Manual21ActiveX.zip - мануал с примерами (1 Mb) http://alldata.by.ru/files/ActiveXsOffice97DE.rar - мануал (35 Kb) ... |
| 28.08.2006, 21:32 |
start [/forum/topic.php?desktop=1&fid=60&tid=2165383]: |
191ms |
26ms |
| others: | 248ms |
| total: | 505ms |
