Ошибка - Время ожмдания истекло
Привет. У меня программа вызывает хранимую процедуру в MSSQLServer2000. авторPrivate Sub Start_Stored_Proc(cn As ADODB.Connection, dd$, mm$, yy$) Dim cm As ADODB.Command Dim p As ADODB.Parameter, p1 As ADODB.Parameter Set cm = New ADODB.Command Set cm.ActiveConnection = cn cm.CommandType = adCmdStoredProc cm.CommandText = "PerevodM70" Set p = cm.CreateParameter("SelectDate", adVarChar, adParamInput, 4, mm$ & yy$) Set p1 = cm.CreateParameter("UseDay", adVarChar, adParamInput, 2, dd$) cm.Parameters.Append p cm.Parameters.Append p1 cm.Execute For i% = 1 To 8 k$ = Choose(i%, "m03u", "m30", "arenda", "vmd_sut", "m70", "ar_p", "ar_v", "upv") SetINI App.path & "\Set.ini", "Kontrol_files", k$, "0" Next i% End Sub Время от времени (в последне время почти всегда) возникает ошибка: авторRun-time error '-2147217871 (80040e31)': Время ожидания истекло ... |
| 22.02.2007, 06:50 |
cm.TimeOut=... ... |
| 22.02.2007, 07:08 |
cm.TimeOut=... а по подробнее можно. Какие параметры и в чем в секундах или милесекундах. ... |
| 22.02.2007, 08:01 |
Типичный поиск в Google ADO Command Timeout Нашел следующее: wwwCommandTimeout Property Indicates how long to wait while executing a command before terminating the attempt and generating an error. Settings and Return Values Sets or returns a Long value that indicates, in seconds, how long to wait for a command to execute. Default is 30. Remarks Use the CommandTimeout property on a Connection object or Command object to allow the cancellation of a command due to delays from network traffic or heavy server use. If the time from the CommandTimeout property setting elapses prior to execution of the command, an error occurs and ADO cancels the command. If you set the property to zero, ADO will wait indefinitely until the execution is complete. Make sure the provider and data source to which you are writing code supports the CommandTimeout functionality. For Connection objects, the CommandTimeout property is read/write. When you use CommandTimeout on a Connection object, you set a global value for all commands executed and all recordsets opened on that connection. You can override this value for a specific command by setting the CommandTimeout property of the appropriate Command object. http://%5D%5B/url]http://] ... |
| 22.02.2007, 08:39 |
start [/forum/topic.php?desktop=1&fid=60&tid=2164461]: |
51ms |
37ms |
| others: | 231ms |
| total: | 369ms |
